Old 03-19-2013, 04:54 PM   #1
Scott>72-GMC
Scott>72-GMC's Avatar
Pipe wrench?
Any of you lose the key to one of these. Know an easy way to remove ?
Sorry it's upside down but u get the idea
72 GMC super custom.
Scott>72-GMC is offline   Reply With Quote
Old 03-19-2013, 05:05 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Wink Re: Pipe wrench?
Remove slowly says it right there on the cap silly....
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 03-19-2013, 05:23 PM   #3
Scott>72-GMC
Re: Pipe wrench?
Lol. Leaning towards channel locks or pipe wrench but don't want to hurt the tank neck
Old 03-19-2013, 05:25 PM   #4
Gumby
Gumby's Avatar
Re: Pipe wrench?
drill out the lock so the pin n springs come lose, remove as normal.
Gumby is offline   Reply With Quote
Old 03-19-2013, 05:28 PM   #5
Scott>72-GMC
Re: Pipe wrench?
Drill but same size as key assembly?
Old 03-19-2013, 05:28 PM   #6
71K20chevy
71K20chevy's Avatar
Re: Pipe wrench?
I'd say drill it out, but you want to be careful to not get shavings in the tank if you go too far
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 03-19-2013, 05:30 PM   #7
Rich916
Rich916's Avatar
Re: Pipe wrench?
Call a lock smith, drilling may cause your tumblers to fall into the tank.
71 Short Step Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=429946
Rich916 is offline   Reply With Quote
Old 03-19-2013, 05:35 PM   #8
truckster
truckster's Avatar
Re: Pipe wrench?
Drilling around fuel vapor is not my favorite idea.
I would try a screwdriver first. The metal those caps are made out of is not very stout. I'd bet you could force the lock with a screwdriver. If not, I'd try prying it off with a screwdriver.
truckster is offline   Reply With Quote
Old 03-19-2013, 06:14 PM   #9
Gumby
Gumby's Avatar
Re: Pipe wrench?
run a 1/4" bit down the center about 3/4-1" deep, then run the drill backwards, then grab the large screwdriver.
nothing will get in the tank[less ya drill farther then 2-3in in], if it did, it would do nothing, only gas soluble particles can make it past the pick up sock in the tank. metal don't dissolve in gas.
truckster, the guy uses a gas tank for a back rest [he has no fear], all sort of electronics, probably people smoking, done would of blown up long ago or drove off the road from them being sucked into the window 3in away or door jam with a 40yr old seal, if he has vapor problems that a drill would make it explode.
Old 03-19-2013, 06:27 PM   #10
Gumby
Gumby's Avatar
Re: Pipe wrench?
Though yes better safe then sorry but, a gas tank 4in from your seat back takes a set of brass ones to begin with and would take a perfect storm of condition to even consider a drill making it explode, if he doesn't think twice about resting his head on the tank for comfort, I can't see a one in a million chance of blowing up is even a concern
Old 03-19-2013, 06:28 PM   #11
Scott>72-GMC
Re: Pipe wrench?
It's a 72 witch should be vented so I don't think it's built up with pressure but ya I wondered bout drilling on a gas cap rather not burn up lol. Wondering about locksmith since my ignition key is missing too and i have heard the doors and ignition were the same key on these trucks if its all original witch I believe it is
Old 03-19-2013, 06:34 PM   #12
Scott>72-GMC
Re: Pipe wrench?
Guess I have always loved the cab tanks since I was a kid and. Probly the wrong way to think but if it has lasted this long with no problem must work ok unlike ford pintos original gas tank witch exploded when rearended lol
Old 03-19-2013, 06:43 PM   #13
jhwkns
Registered Cruiser
jhwkns's Avatar
Re: Pipe wrench?
Those are pretty cheap locks. Try any key that will go into the keyway. It might open. I'm certain I could easily pick that lock.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 03-19-2013, 07:29 PM   #14
bigbadchev72
People know me
bigbadchev72's Avatar
Re: Pipe wrench?
Prefferably a torch or plasma cutter if you have one, If not a grinder with a cut off wheel.
Or you could just use a pair of channel locks, they are not very stout and come off easy
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 03-19-2013, 07:34 PM   #15
JOJABOY
Re: Pipe wrench?
I have one just like it on a shelf in the garage. If you haven't tried anything yet....I can go take a look at it and maybe see what I can do with it..........
JOJABOY is offline   Reply With Quote
Old 03-19-2013, 07:43 PM   #16
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Pipe wrench?
I screw a slide hammer down into the lock and thump it a few times. Pieces go flying everywhere.
Tx Firefighter is offline   Reply With Quote
Old 03-19-2013, 07:46 PM   #17
Hutch
Hutch's Avatar
Re: Pipe wrench?
Scott>72-GMC
Ask member LockDoc he probably has some ideas
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 03-19-2013, 07:56 PM   #18
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: Pipe wrench?
Tow truck drivers have a pick for gas caps in their lock out kit. Most gas cap locks are two or three tumblers fairly easy to pick. I have one in my tool box but I aint crazy enough to drive that far
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 03-19-2013, 07:57 PM   #19
Scott>72-GMC
Re: Pipe wrench?
I haven't tried a thing yet
Old 03-19-2013, 08:03 PM   #20
JOJABOY
Re: Pipe wrench?
Let me go see. It's on top of my tool box
Old 03-19-2013, 08:05 PM   #21
jocko
jocko's Avatar
Re: Pipe wrench?
what they said.
Old 03-19-2013, 08:09 PM   #22
Tinkermc
Re: Pipe wrench?
I have done it twice the same way Txfirefighter said should work. It does work and just like he said parts go FLYING!!!!
Tinkermc is offline   Reply With Quote
Old 03-19-2013, 08:13 PM   #23
JOJABOY
Re: Pipe wrench?
Dremel will work best. Cut around the red ring. Metal is only about 1/16" think. If you don't have a Dremel....drill little holes and connect the dots.
There's about 1/8" between that metal cap and the rubber seal. So no worries.
Once you get outter ring cut off cap you can cut back rubber grommet with a knife and then just stick two small screw drivers in and depress the tabs.
The tabs are at 12:00 and 6:00 looking at the key hole.
Old 03-19-2013, 08:18 PM   #24
JOJABOY
Re: Pipe wrench?
Old 03-19-2013, 08:19 PM   #25
Scott>72-GMC
Re: Pipe wrench?
Awesome thanks
