03-29-2013, 08:26 PM | #26 |
Re: Gauges used for LSx swaps
Crash, you have any trouble with the tach signal? I want vhx for my swap but had trouble with my 67 Camaro with vhx getting a tach signal. tried pull up resistor and all, no luck. had to tap off the coil. just didn't want to go through that again.thanx
03-29-2013, 08:30 PM | #27 |
No problems, using the Dakota Digital BIM module, it connects to the PCM and receives all the tach, speed, water temp, etc digitally from the PCM.
Mark ----------------------- Crash's 69 4x4 SWB Crash's Roof over Lake Home Crash's 1988 Land Cruiser Build |
04-02-2013, 04:10 PM | #28 |
We used a cluster out of a 01 camaro. Cost $60 and the PCM controls everything but the fuel gauge. We epoxied the original fuel gauge armature into the camaro one. A piece of lexan cut to fit, and painted black from behind and ready to go.
04-03-2013, 12:04 PM | #29 |
That's SWEET!
04-03-2013, 02:00 PM | #30 |
So if I understand you correctly, you didn't use any of the sensors provided with the gauges? You just pulled everything from the PCM using the BIM? What year is your motor and computer? What EFI wiring harness did you use?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-03-2013, 02:05 PM | #31 |
The only sensor used was the oil pressure. Everthing else comes from the PCM (speed, tach, and water temp). 2005 5.3, with the factory harness I modified.
04-03-2013, 02:26 PM | #32 |
Interesting thread, taking notes
------------ Scott |
04-03-2013, 03:31 PM | #33 |
I made my own dash. Used the phantom gauges and was really easily (except fuel gauge, but thats the sending unit thats bad) Used bolts with green led's for the turn signal and just a simple blue led for the brights to make it look clean.
Blazer Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=483399 |
04-04-2013, 04:21 PM | #34 |
I just got My Gauges in the mail today!! Can't wait to build the gauge panel!!
Speedo (with high beam indicator) Tach (with check engine light) Fuel level (can bus) Oil Pressure (can bus) Tranny Temp (can bus) Water Temp (can bus) Volts (can bus) Looks to be super simple to wire it all up!
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE Last edited by jorgensensc; 04-04-2013 at 04:30 PM. |
04-04-2013, 09:14 PM | #35 | |
04-04-2013, 09:17 PM | #36 |
I'm going to use a late model stock fuel pump modulator with a fuel level sender on it. That gets run through the wiring to the computer, that then sends it via can bus signal out. At least that is the way it's supposed to work according to PSI. they verified for me that the fuel level signal was sent to the computer and then out to the gauges via can bus rather than coming to the gauges a different way.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
04-04-2013, 09:18 PM | #37 | |
04-04-2013, 09:20 PM | #38 |
Thanks! The wiring looks really simple. I would have gone with a can bus speedo and tach, but they don't have them in the right size yet. And no amount of bribing by me was going to get them built anytime soon.
09-10-2013, 05:29 AM | #39 | |
I figured out my gauge cluster, it was a little misunderstanding of the wiring list. I was using a post that TchncnDen put up (thanks man) and pin B5 says " B5---ppl/wht----fused ignition feed" and it actually just needs to be hot only when the starter is engaged, I had it hot at all times when key was in run. Cut that wire, and it is all good to go, except my fuel gauge but that is a separate problem. I have the third member out welding it up, since I spin everytime I look at the gas pedal now. (I know most people are 100% against welding up rear ends, but I have had great luck with it in the past and will run it until it breaks)
09-10-2013, 08:37 AM | #40 | |
Rob
09-10-2013, 08:52 AM | #41 | |
It may be captured in the PCM, but it appears that the DD gauges does not have a the ability to use it. It was not an option on the oil pressure setup in the DD VHX menu. This may have changed since I did mine, if so please let me know.
09-10-2013, 09:05 AM | #42 |
Will do!
09-10-2013, 10:30 AM | #43 |
Were you able to pull up the oil pressue on the "Message Center" window?
09-10-2013, 10:40 AM | #44 |
No..
09-10-2013, 10:56 AM | #45 |
09-10-2013, 11:01 AM | #46 |
I did Dakota digital and they work great!
really clean 72! http://67-72chevytrucks.com/vboard/showthread.php?t=531183[/url] also 1972 2wd blaze. |
09-10-2013, 11:03 AM | #47 |
Yes and no.. I did have both, but removed the sensor to add the DD oil gauge.
09-10-2013, 01:58 PM | #48 |
Was the sensor there when you originally tried to pull up the oil pressure via the BIM-01-1?
09-10-2013, 09:06 PM | #49 |
Yes...
09-12-2013, 12:02 PM | #50 |
Mark - I hope I didn't come off as questioning your intellegince on this. I'm just trying to figure why you couldn't get the oil pressure to show up. I spoke to DD and they told me that if the engine and computer capture the parameter, then it should be able to be seen in the message center. I'm should have my setup running in the next couple of weeks, and hopefully I will be able to figure this all out. Thanks for the info!
