Old 05-19-2013, 07:15 PM   #1
pritch
pritch's Avatar
How close is your speedometer?
When mine is on 60 I am doing more like 64-65. I base this on several of those radar speed signs they have before sharp turns on the Interstate. I know these are probably not the most accurate radars, but there are 3 of them that I drive past routinely and they always agree, always the same.
Point is, I need to get new tires soon. Would I need a little taller tire or a little shorter to dial in my speedo?
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 05-19-2013, 07:21 PM   #2
rogergodding
rogergodding's Avatar
Re: How close is your speedometer?
I'd say a little shorter.... mine is right at 10 mph off, but that didn't change with tire size...
rogergodding is offline   Reply With Quote
Old 05-19-2013, 07:28 PM   #3
hyatt
If you have a I Phone there is a free speedometer app It will show you exactly how fast you are going
1946 car hauler
1948 surburban
1937 chevy sedan
1940 olds sedan (project)
1967 ss396 chevelle
1999 dually crewcab(24000 miles)
hyatt is offline   Reply With Quote
Old 05-19-2013, 07:39 PM   #4
69GWC
Yeap speedo app, mine is off 15mph with my 33s.
69GWC is offline   Reply With Quote
Old 05-19-2013, 08:02 PM   #5
Tbruz
Once you fgure out how fast or slow your Speedo actually is via phone app, pace car or GPS, you can add a speedometer ratio adapter for about $40 between the end of your speedo cable and where the speedo cable screws into your tranny housing.
Tell them your actual speed and what the speedo reads(or distance for that matter) and they can build proper ratio adapter.
Did it with my Blazer, speedo and GPS reading are now within 1%
Tbruz
Tbruz is offline   Reply With Quote
Old 05-19-2013, 08:10 PM   #6
Indyuke
Mines about 1-2 mph off at 60... very close. But I have the truck set up pretty close to stock.
Indyuke is offline   Reply With Quote
Old 05-19-2013, 08:11 PM   #7
MidLifer
MidLifer's Avatar
You can also change the speedometer gear - here is a calculator to help figure out which gear you need:
http://www.tciauto.com/tc/speedometer-gear-calculator/
MidLifer is offline   Reply With Quote
Old 05-19-2013, 08:19 PM   #8
turp mcspray
turp mcspray's Avatar
FYI...On a th350, or any other trans with the small driven gear, 1 tooth difference = 1/2 tenth on the odometer. (or 5% change) On a th400, or anything else that uses the large driven gear, 2 teeth = 1/2 tenth.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 05-19-2013, 10:38 PM   #9
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I buried my speedo one tme and figured I couldn't be going be going that fast cause the truck rode and handled perfectly. Got the GPS out and with my speedo showing 95mph the GPS showed just under 94.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 05-20-2013, 08:04 AM   #10
Andy4639
Old member
Andy4639's Avatar
Talking Re: How close is your speedometer?
Well if you buy a speed hut GPS speedo from them you will be spot on no matter what size tire. gear, transmission you have. I have a full setup in my 71 and love them.
U can also just buy the GPS speed o and hook the hot wire and ground up and your done. Instant speed directions 1/4 mile speeds
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-20-2013, 09:07 PM   #11
pritch
pritch's Avatar
I may be out of luck. No smart phone or GPS. Oh well.
'68 Panel
'68 C-10
Ol' Green
Old 05-20-2013, 09:18 PM   #12
LockDoc
The Older Generation
LockDoc's Avatar
with what Andy4639 said.... Here is the install of mine. Doesn't matter what tire, rear ratio, trans, or anything else you are running it is always right on the money...
http://67-72chevytrucks.com/vboard/s...d.php?t=421745
LockDoc
Leon
Old 05-21-2013, 08:49 PM   #13
pritch
pritch's Avatar
That is a good idea. Now I remember your original thread on this. I might do something like this on my Panel, but for my beater truck, I don't know if I want to go to the trouble. Thanks, for the reminder, though
'68 Panel
'68 C-10
Ol' Green
Old 05-21-2013, 09:40 PM   #14
How close is my speedometer? From where,my eyes? I'd have to measure,but prolly right about 24" Is my guess.
Ok seriously,mine have always been accurate till I go to bigger tires,such as on my 4wds.
Old 05-22-2013, 12:18 AM   #15
bugmasta
bugmasta's Avatar
Don't know, not connected. Bounces all over the place when I connect the cable. Just try and go with the flow of traffic and make sure some one is always passing me.
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130
Club longbed ...cause girls like'em long!!!!!
bugmasta is offline   Reply With Quote
Old 05-22-2013, 12:47 AM   #16
AustinScott
AustinScott's Avatar
My speed-o was close -5mph when I had the TH400 and 3.08 setup.
Then I changed to a TH2004r and 3.73.. my speedo was a bit off.. +10-15 mph.
When I did my valve body & governor swap on the 2004r I got the correct speedo gear for my current setup.. Man now the thing is perfect at all speeds... well within 1 mph when tested against I-phone app.
I had to swap from RED TO GREEN on the trans gear... pretty easy fix if you ask me
Scott
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi,
My 68-SWB Photo Build Thread
All my Google Albums
AustinScott is offline   Reply With Quote
Old 05-22-2013, 06:40 AM   #17
70cst
70cst's Avatar
Good thread. I never thought about this
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 05-22-2013, 06:51 AM   #18
Andy4639
Old member
Andy4639's Avatar
Wink Re: How close is your speedometer?
www.speedhut.com has a small speedo also. I have been thinking about buying it for my golf carts so I can swap it out to whichever cart I'm using at the time. It's like a tach mounted on the steering column.
Old 05-22-2013, 08:01 AM   #19
Speedos don't get off by a set amount of MPH,they get off by a percent. So the mph difference increases with speed. When I put 37" tires on my 4.10 truck it reads 10% off,or says 50 when I'm doing 55. I pass 9 mile markers and my odo says 10 miles.
I got pulled over for doing 40 in a 25 going downhill the first night I put the tires on. I told the officers that and that I hadn't had a chance to figure the difference it made or have my speedo recalibrated. We discussed how it worked and the one was saying it would be off by a set amount of mph and I said the number would increase with speed. They offered to follow me to this less traveled road where they would have me drive by at 25 and they'd read my actual speed. So,I drove by doing about 36 on my speedo and they got about a 40 mph reading and let me off the hook
That was back when no one had tires that big yet.
Old 05-22-2013, 09:09 AM   #20
Mr Handy
Mr Handy's Avatar
That's funny!
Mine is off about 7mph at 60/70
I downloaded one of the iphone apps and I paced my wife home one night...
I think when I put new tires on I'm going to go to 235/75 r15. If my math is right that should shorten the gap by about 2mph and put me 5 under at 70ish. I have worn out 225/75s on right now.
Mr Handy is offline   Reply With Quote
Old 05-22-2013, 02:48 PM   #21
bugmasta
bugmasta's Avatar
did the exact same thing once with the local ticket writer after putting 35's on my bronco. let me go with a fixit ticket to have the speedo recalibrated.
Old 05-22-2013, 04:23 PM   #22
srvivor71
srvivor71's Avatar
SWEET! Android has it too. This will come in handy because mine is way off - it shows at least 10 MPH under actual speed.
srvivor71 is offline   Reply With Quote
Old 05-22-2013, 07:47 PM   #23
74baggedbug
Tbruz
Where did you get the adapter at? Thanks
74baggedbug is offline   Reply With Quote
Old 05-22-2013, 08:13 PM   #24
LockDoc
LockDoc's Avatar
Not sure where he got his but they are available here...
http://www.transmissioncenter.net/sp...n_______va.htm
Plus a lot of other stuff & info on the site.
LockDoc
Leon
Old 05-22-2013, 10:18 PM   #25
knomadd
knomadd's Avatar
My GTO had about 5 mph difference. Wound up changing the speedometer gear in the transmission. can't remember if it's the drive or driven gear. It has a TH400, but I found something online that helped me determine which gear I needed. TCI has quite a few different gears to swap yours if that's what you want to do.
If you still want to change tire height, taller is faster, shorter is slower. Check out this website. http://www.rimsntires.com/specs.jsp You can compare a size you have with a size you will consider switching to. It even tells you how much difference the new tire will make in your speedo.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
