05-30-2013, 09:31 PM | #1 |
SAVING ONE TRUCK AT A TIME
2006 d-max glow plugs
so my truck threw a code for 2,3,5 glow plug.replaced the plugs and still the same code.i have read a recall for the gp control module.anyone had a similar problem.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
05-30-2013, 11:10 PM | #2 |
Re: 2006 d-max glow plugs
did the glow plugs cycle after you installed them.codes wont clear till glow plugs cycle.and did you replace thr correct glow plugs-odd bank is on the right side and even bank is the left side.
05-31-2013, 12:17 AM | #3 |
replaced glow pugs.pulled negative to batteries.waited 30 minutes then fired.light is still on.tomorrow i will have a obd2 to verify.
06-02-2013, 11:42 AM | #4 |
Code won't clear with batteries unhooked. Need a scanner. If the glowplugs didn't cycle the code won't clear either. If they do cycle it could take s few key cycles for the light to go off.
Posted via Mobile Device |
06-02-2013, 05:38 PM | #5 |
cleared the cel with a scanner.everything good so far.thanks
