Moderator
![]() Join Date: Dec 2012
Just finished cutting my TREX bed wood!
Went well. Thought TREX would be a great choice for a truck that will sit out in the elements. Got a great deal on overstock that was sitting unused outside. Used the dimensions from GMCPaul's site. This is for my LWB 65 C10 Fleetside. The boards were 1"x8"x12'. Took about three hours total for measuring, cutting to length, ripping, and grooving. Boards were cut to length with a circular saw, but all other dimensions were done with a radial arm saw (ripping blade, and a dado blade).
Can't wait to install it! ![]() ![]() ![]() Wood, non-polished strips/bolts will be a nice upgrade: ![]() |
Re: Just finished cutting my TREX bed wood!
Looks good man!
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
Junior Member
I wanna see how this turns out... How much did you pay for it??
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome." |
![]() Join Date: Oct 2012
I'm looking at trex for John Lee Jr this summer. How does it mill? I'm gonna use carbide dado head on the table saw. Was wondering if it'd gum up the blades or cut smooth.
I plan to use the 3/4" thick trim boards so the fit is the same and add a couple cross ties to put it all on 16" centers. |
Looks great. If your mufflers are under your bed, really look at installing a heat shield.
Looks great! I wish I was better with wood and had the tools to do it.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
Moderator
I will be running a stock muffler, and I will build a heat shield for it.
I paid 25/board. List was 60ea! Expensive, but no sanding, no priming, no stain/paint. Ever. It cuts easily. Easier than lumber, I would say. No "gumming", the waste just spiraled off. No problem for the old circ saw blade, and it just glided through the radial arm with no pressure. With two people, the long boards were easy to push/pull through. Toughest part was getting them down the basement to the workshop! We cut them all to length in the garage, no way 12' would have made it. I decided to go this way after doing lots of research on this forum. A few have done it, so I wanted to try as well. |
Okay, its decided then. John Lee Jr is getting trex this summer!
I'm going to powdercoat the strips and get new shiny bolts. Just an idea for ya.
66 shorty ![]() |
![]() Join Date: Aug 2004
Only thing with Trex is it comes in 6" width only. more boards but if it lasts as it should, your truck will never need new boards again.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Actually, the trim boards from trex and various other makers come in 1x12 dimension and actually measure 3/4" by 11+" inches wide. Perfect for milling and cutting out bed boards. Add a couple cross ties though cause even the inch trex needs to be on 16" centers and theres a couple spots in the bed where more support would be needed. I plan to use the Grey trim boards from lowes. They are not trex but are only $27 each for the 12 footers at 3/4" by about 11 1/2" wide.
Moderator
Trex comes in many different sizes now. My boards are 1"x8"x12' (dimensional, as Sharps pointed out), the perfect size to match OEM boards. Also, my boards aren't "decking", they are "facia" boards.
Looking forward to seeing the project as it progresses.
x2....I'd definitely put heat shield on. Easy and cheap insurance.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#15 |
meowMEOWmeowMEOW
I did a bed with trex a bit back, and it's held up great so far, tho I used the decking style pieces not fascia. I didn't mill them to accept the trim strips, instead I made psuedo-trim strips to fit the gaps. I plan on bedlining the whole thing to give it one contiguos look.
Did you plan on painting/coating yours?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#16 |
Moderator
No, I purposely picked grey so it looked like old weathered wood. It will be appropriate for the truck.
#17 |
I stand correct, my apologies. I looked at my local Lowes and they only show the 6" deck boards. I didnt even know they had facia boards or ones that are 1X12's. Good to know, thanks guys!
#18 |
Moderator
#19 |
![]() Join Date: May 2007
outstanding
#20 |
Awesome....Mine is looking good so far...only about a month old but I like the way when its dirty, a drive in the rain pretty much cleans it off, no scrubbing!
#21 |
check this out 3/4x 11 1/4 x 8' $30 lowes choicedek foundation http://www.lowes.com/Decking/Composi.../N-1z10sn3/pl#!
#22 |
That's what I used on John Lee Jr. Its advertised at 3/4" but its true thickness is 5/8". Seems sturdy enough. I got it on sale, $18 or so per board. Looks wonnerful in the bed.
#23 |
Moderator
#24 |
Damn nice.
#25 |
Moderator
Those are unpolished strips. They will be the nicest parts on the whole truck! Black would have fit better, but it's going to sit outside in the snow, so I thought stainless would be a better choice than steel.
