Old 06-11-2013, 08:47 AM   #1
Eliminator4life
I think my truck might be a numbers matching
Is there anyway to 100 percent sure. I ran the numbers on my block it says 283 out of a 1965 Chevy. My truck is a 1965 C10 any help would be appreciated thanks.
Eliminator4life is offline   Reply With Quote
Old 06-11-2013, 11:00 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: I think my truck might be a numbers matching
There should be a pad on the pass. side front of the block, right where the head meets the block. Typically there would be a stamped number there and part of this number would match part of the VIN number (like the last part). If these match up, this would be a numbers matching otherwise it would be date code match.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-11-2013, 11:38 AM   #3
rideblue00
rideblue00's Avatar
The top drivers side of the frame near the motor mount has a number stamped on it that should also match the vin on the cab.
rideblue00 is offline   Reply With Quote
Old 06-11-2013, 12:06 PM   #4
Eliminator4life
So here are my numbers
Cab C1445Z146996
Front of the head F0309GF
Frame 5Z146996
Old 06-11-2013, 01:16 PM   #5
1963c-10
1963c-10's Avatar
Looks right to me
1964 Short bed trailer
Old 06-11-2013, 04:54 PM   #6
geezer#99
geezer#99's Avatar
So your frame matches your cab vin. That's good!
Should be more numbers on the front pad. to be a match.
Do you have a powerglide tranny?
Old 06-11-2013, 04:59 PM   #7
Eliminator4life
No it's a turbo 350
Old 06-11-2013, 05:15 PM   #8
geezer#99
geezer#99's Avatar
THe suffix code GF says it should be a powerglide. Originally. Probably swapped.
You need the 146996 on the pad for the match to your vin.
Old 06-11-2013, 05:24 PM   #9
oldtrux
oldtrux's Avatar
I could be wrong but i dont think they numbers matched our years in trucks!you can only date match it.if you have buildsheet or spid you can prove that it came out of the box with a 283!also another matching serial number on the top of frame under cab!cheers
oldtrux is offline   Reply With Quote
Old 06-11-2013, 08:03 PM   #10
gimmy 64
I thought numbers didn't match until 66. at least that's what I have read on here before
gimmy 64 is offline   Reply With Quote
Old 06-11-2013, 08:15 PM   #11
padresag
this is what you would have if you had matching nbrs. this is off my 64 4 x 4 panel
ron
padresag is offline   Reply With Quote
Old 06-11-2013, 09:07 PM   #12
LT1 Burb
LT1 Burb's Avatar
They weren't as diligent about numbers down here as they were up there Ron. They did not stamp vin numbers on 283's so your truck will only have the code.
LT1 Burb is offline   Reply With Quote
Old 06-11-2013, 09:24 PM   #13
padresag
I really don't know what it had orig for an eng. it had that 4 cyl in it when I got it. it would be neat though if one had the orig eng and if it did have that nbr stamped in it. the early chevs had then that way as my 32 chev tag was also the same way and did have the corresponding nbr stamped on the eng. the all had that at one time, don't know when they stopped it. mind you they never had the production nbrs up here that were down there.
but that would have been a true nbrs matching
ron
Old 06-11-2013, 10:24 PM   #14
Eliminator4life
So what your saying is its almost impossible to see if its a numbers matching.
Old 06-11-2013, 10:32 PM   #15
LT1 Burb
LT1 Burb's Avatar
Without the build sheet it is impossible to know, that's why documentation is everything.
Old 06-11-2013, 10:35 PM   #16
geezer#99
geezer#99's Avatar
You could check the casting date. It should end in a 5. Here's a link to check it.
http://www.nastyz28.com/sbchevy/sblock.php
Old 06-12-2013, 12:55 PM   #17
Eliminator4life
Cab C1445Z146996
Frame 5Z146996
I just decoded the number on the front of the head.
F0309GF
F = Flint
03= March
09= the 9th
GF= 1965 with a 283 power glide
I'm not sure what tranny I have. I assumed it was a turbo 350. I guess I will pull the numbers and look it up. Things are looking better and better.
Old 06-12-2013, 01:35 PM   #18
1963c-10
1963c-10's Avatar
Is the trans a 2, 3 or 4 speed?
Old 06-12-2013, 01:45 PM   #19
Eliminator4life
It feels like it shifts 3 times. I just usually put it in D and drive away.
Old 06-12-2013, 01:48 PM   #20
geezer#99
geezer#99's Avatar
You still need to check the casting date and the block casting number.
If it's a powerglide it should have a rod for the kickdown like in the first pic in this link.
A turbo 350 uses a cable.
Here's a link to determine what tranny you have.
http://www.maliburacing.com/auto_tranny_id.htm
http://67-72chevytrucks.com/vboard/s...d.php?t=523578
Old 06-12-2013, 01:56 PM   #21
Eliminator4life
Thanks for the info ill check it out this evening.
Old 06-12-2013, 07:40 PM   #22
LT1 Burb
LT1 Burb's Avatar
How did you decode that motor because I have a 65 C10 with a 283 powerglide and it codes as a WE which in my manual is exactly right. I don't even see a GF anywhere in the factory manual for numbers.
Old 06-12-2013, 07:49 PM   #23
Eliminator4life
Your we looks like a 283 with a m/t which I'm guessing means manual transmission.
Old 06-12-2013, 09:20 PM   #24
LT1 Burb
LT1 Burb's Avatar
I am going right out of the chevy manual and I took the motor out still bolted to the powerglide so am 100% sure its right.
Old 06-12-2013, 09:56 PM   #25
Eliminator4life
Well you see the facts I posted I don't know what to tell you.
