Old 07-14-2013, 07:31 PM   #1
slow-1
slow-1's Avatar
Unhappy Why cant I bleed my rear brakes?
Had to replace a brake line that I tried to move away from the exhaust. Tried to bleed brakes after line put in, unable to do it using the pump the pedal method.
Went and bought a vacum brake bleeder, did front in just a couple minutes, sucked out all the old stuff until nice new clean fluid came through.
Tried to do the back, vacum pumps up to 25 inches on gauge, no fluid flows.
Took rubber hose off thinking it could be clogged, fine. Hooked vacum to line, pulled new fluid from res.
Put vacum back on bleeder valve on rear brake, same thing...25 inches of vacum, no fluid flow.
Undid line into rear brake, old fluid drips out, vacum still wont pull through the brake even with line loose from back.
Tried other side thinking cylinder went bad on this side, same thing.
What am I doing wrong?
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 07-14-2013, 07:40 PM   #2
Husker
Husker's Avatar
Re: Why cant I bleed my rear brakes?
Are the shoes adjusted to the drum?
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 07-14-2013, 07:45 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Many years I had a similar problem.
With assistant's stepping on the brake I loosened the line at the master cylinder going to rear brakes to make sure fluid was coming out of there. I followed the brake line all the way back and any where there was a fitting I would loosen it up and again check to make sure fluid came out. When I loosened the rubber line above the rear axle, it oozed out. It was swollen inside.
In your case, since you know that one is okay it may be the master cylinder piston or clogged somewhere else along the brake lines.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 07-14-2013, 07:53 PM   #4
LONGHAIR
Disc front, drum rear?
Sounds like the proportioning valve is popped. It is a safety system that "cuts off" one end or the other if a leak develops. It "balances" between the front and rear until one end loses pressure.
Bleeding the front first, especially with the problem in the rear, made it worse.
You need to get it re-centered first, then the rear will bleed.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-14-2013, 08:24 PM   #5
50mercfan
50mercfan's Avatar
assuming every thing was working fine before you replaced the line, here's what i would do.
always start at the wheel farthest from the master cylinder and work your way to it, in the order, right (passenger side) rear, left rear, right front, left front. tighten all bleeders and make sure the master cylinder is full.
have some one push the brake pedal, don't pump it up and down, just push it to the floor, open bleeder, close bleeder. do that several times until all fluid and no air bubble come out. do this at each wheel. make sure you don't run out of fluid in the master cylinder or you'll have to start over.
another thing you can do to get it started is gravity bleeding. take the cap off of the master cylinder and open all bleeders at once. watch until fluid starts coming out of each bleeder and then close them. this method can take a long time.
50mercfan is offline   Reply With Quote
Old 07-14-2013, 08:26 PM   #6
50mercfan
50mercfan's Avatar
also, when using the vacume bleeder, take the cap off of the master cylinder. it'll never pull any fluid if the system is closed.
Old 07-14-2013, 08:46 PM   #7
slow-1
slow-1's Avatar
Thanks for the replies.
It is disc/drum.
I can pull fluid to the line that goes to the backing plate with the vacum.
Fluid nor air will move through the brake itself...did both wheel cylinders freeze up? Shouldn't I be able to at least pull air through them?
I am at a loss...I am no mechanic, but a pretty good parts changer and this I have never run in to.
Keep the ideas coming!!!!!!!
Old 07-14-2013, 08:50 PM   #8
myyamr7
myyamr7's Avatar
I had the same issue with my 71. The problem was the bleeder was clogged. Take the bleeder out and stick a small piece of wire into the hole the bleeder came out of, do the same to the bleeder itself. Once I did that, my vacuum pump pulled fluid quick
Mark
71 C10 Cheyenne
12 Aprilia RSV4
myyamr7 is offline   Reply With Quote
Old 07-14-2013, 08:52 PM   #9
slow-1
slow-1's Avatar
Ron
I assume they are...I drove the truck to where it sits, only change is the brake line.
Old 07-14-2013, 08:57 PM   #10
88Ironduke
If its both left and right wheel cylinders I would start cracking lines at the proportioning valve out put to rear brakes and then work backwards. Where ever fluid flow stops is your problem. A frozen wheel cylinder will only stop working, the little cylinders have nothing to do with flow thru the body of cylinder for bleeding purposes.
88Ironduke
88Ironduke is offline   Reply With Quote
Old 07-14-2013, 09:02 PM   #11
slow-1
slow-1's Avatar
I took the bleeders out and they were open, but I did not probe the hole with a wire, I will try that next.
Old 07-14-2013, 09:04 PM   #12
slow-1
slow-1's Avatar
88Ironduke
Yep, I know the problem is between where the brake line goes into the backing plate and the bleeder.
Old 07-15-2013, 07:25 AM   #13
Sounds like proportioning valve issues,as others have said.
Old 07-15-2013, 07:30 AM   #14
ol_skool_chevy
ol_skool_chevy's Avatar
Replace the rubber hose in your brake line at the rear end..........it will look perfectly fine but it can be collapsed inside and you wont know it. I have had it happen many times.
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 07-15-2013, 08:09 AM   #15
71swb4x4
71swb4x4's Avatar
I agree with the others check the proportioning valve.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-15-2013, 09:42 AM   #16
da-burb
"Ochre Ogre"
da-burb's Avatar
I agree with ol skool, hose has collapsed. I have seen them work like a check valve, you can pump the brakes and the brakes lock up and never release because the hose lining has closed off.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 07-15-2013, 09:51 AM   #17
slow-1
slow-1's Avatar
Thanks for the continued replies!
I took the hose off, it is not clogged (gonna replace anyway while its off since its 40 years old).
I can pull fluid with vacum easily up to the backing plate so I dont think its the prop valve.
I'm hoping its the bleeding passage clogged, will check tonight.
Old 07-15-2013, 10:23 AM   #18
Daner
Daner's Avatar
I would rebuild the wheel cylinders while you have that stuff tore apart. If there is enough stuff in there to clog the bleeder I don't think it would hurt anything.
Dane
67 Chevy Fleet 250/4 speed 1/2 ton
68 Chevy 250/4 speed 1/2 ton for parts
49 GMC Grain truck 235 1 1/2 ton
76 Chevy 350/4 speed 1/2 ton
Daner is offline   Reply With Quote
Old 07-15-2013, 12:41 PM   #19
Sandemonium
Proud owner of a 55.1 AD
Sandemonium's Avatar
Sounds like rebuilt/new wheel cylinders are in your future.
Rebuild them yourself for about $4 each or new for about $10 each.
Sandemonium is offline   Reply With Quote
Old 07-15-2013, 01:25 PM   #20
cdowns
cdowns's Avatar
sooo many threads about this.. doesnt anybody read a service manual ever?? the CORRECT procedure is in there in detail
clamp the pin on the combination valve
Old 07-15-2013, 01:50 PM   #21
Sandemonium
It is disc/drum.
While there may be an issue in the proportioning valve, reading the above post stating that he can get fluid up to the backing plate, but not through the wheel cylinder to me looks like the problem resides in the wheel cylinders.
Keep us posted on the resolution. I am interested.
Old 07-15-2013, 02:26 PM   #22
JointTech
JointTech's Avatar
wheel cylinders are what $40? get new ones and be done with it.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 07-15-2013, 08:07 PM   #23
LONGHAIR
40 bucks? Heck no, calipers don't even cost that much. Wheel cylinders are less than 10$.
Old 07-15-2013, 10:59 PM   #24
slow-1
slow-1's Avatar
Winner winner chicken dinner.
Took out the bleeders, poked a small zip tie into the hole it came out of, old fluid started dripping out. There was a gel like substance on the ziptie when I removed it, I guess it is congealed brake fluid. Put it all back together and was able to pull nice clean fluid from the MC through the bleeder with the vacuum.
I haven't finished re-bleeding everything so not done yet, but on the right track.
Thanks for all the help.
Old 07-15-2013, 11:11 PM   #25
slow-1
slow-1's Avatar
How do you "recenter" the prop valve?
