#1 | |
Re: TCI to start new R&D Project with a C10!
![]() -J |
I'm just glad to be here!
That's looking good!
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
It is a good thing you are not using the modular spindle. They do not hold up to racing. The pin would actually deflect in the spindle. I went as far as welding them front and back on the pin to help this but it was not enough they still flex bad enough to cause brake knock back.
These trucks are really hard on parts in a autocross/road race environment. |
#4 | |
That's good to know. |
![]() Join Date: May 2007
Lots of learning on watching this one.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
We've made a few more revisions but the project is coming along quickly.
There was some discussion about which c-notch design we were going to use. The round style won out almost unanimously. ![]() ![]() Mocking up the anti-sway bar and a few other items. This crossmember is going to be one beefy dewd once it is all boxed in and fully welded. ![]() ![]() ![]() Torque Arm mount, I believe this is revision #2 ![]() -J |
Boosted Member
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#8 | |
![]() ![]() -J |
Boosted Member
If you guys were closer, I'd take you for a ride. There wouldn't be much more convincing necessary
Lookin' good! Really diggin' the front set-up. Have you done any FEA on supporting the rear end with the coilovers behind the C-Notch? A while ago, I ran across a thread that discussed how C-Notching can weaken the frame's integrity. It made some pretty good points. If I run across it again, I'll share the link here. Keep up the good work!
#11 | |
#12 | ||
![]() I hopped on Craigslist earlier today and found a LQ4/4L80 combo with less than 80K original miles for cheap so I forwarded the link over to them. ![]() Quote:
-J |
Glad to see you guys are doing your homework! If you haven't guessed by now, I'm in engineering for my day job, and run a part time speed shop on the side. Unfortunately, that means I'm hard to impress, but you guys are definitely putting the icing on the cake with this. Keep the documentation of the development coming, awesome stuff!
No worries, it's refreshing to hear good questions during this process. We are one of the few companies that doesn't mind posting pics of the "process".
Well, good news, The craigslist link I sent to Sal & Ed about the LQ4/4L80E actually worked. I go pick it up after lunch. -J |
#15 |
Boosted Member
Haha that's awesome. What is the going rate for that combo out by you?
#16 |
#17 |
![]() Join Date: Jan 2011
Looks good guys. I was into street rods in the 80's and used your stuff helping a friend build a couple of model A's. Nice to see you working on this era truck.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#18 |
Nice grab!
#19 |
Boosted Member
That's a bit higher than that combo goes for here, but it looks clean as a whistle, and complete. Awesome score. What's the plan with that? Boost!?
#20 | |
If the forced induction thing doesn't happen we'll probably just do cam only. I think The 317 heads will be a pretty good match for our intended usage. -J |
#21 |
C-10 Club Member
I'm excited for this package!!!
Keep building ![]() ![]()
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels 1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910 |
#22 |
#23 |
Have you looked at the Mast Motorsports Oil Pans?
http://www.mastmotorsports.com/view.php?id=160&c=49&s=7 Seems like I heard somewhere that they have a little more clearance than the F-Body pans. But it's always good to move the engine back like you mentioned for weight distribution. What did you come up with on the spindles? You had mentioned a few posts back that you were developing your own since the CPP MOD spindle didn't work out.... Everything is looking great BTW.!!!! |
#24 | |
We took a mod spindle, cut off the steering arm, machined two faces on the spindle and bolted on one of our steering arms. This will atleast get us where we need to be dimensionally for mock up. -J |
#25 |
Watching this progress gives a lot of insight into what our top notch vendors go through to make quality products available for us truck guys.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
