Re: What's your best theft deterrent ???
I made the first hood release so you have to pull a handle in the cab, theres a battery disconnect, and I have an electric fuel pump and I have a hiding kill switch, andi have already found out that with it off I only have to look a block away
I put the wrong shift knob on. If you put it in first gear according to the shifter you will be racing into reverse right into my garage. Thats where the 60lb pit comes into play.
Erik 1967 K10 SWB Big Window - Bone Stock 1955 JEEP CJ5 13K orig miles (Resto waiting patiently in the garage) |
#3 | |
71 swb 350/4sp manual 5/7 static drop |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Grant removable steering wheel..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
I only use a battery kill switch that has never been found by my friendsw with my permission to hunt 4 it
The little guy on the left...viscous, no ones getting any where near my truck... for those of you who may remember the Rabbit from Monty Python and the Holly Grail..
1953 Chevy 3100 1964 Chevy Impala 1966 Chevy El Camino 1970 Chevy C10 Fleet Long 1972 Chevy C10 Step long 1985 Chevy K10 Fleet Short |
Up on 4 cinder blocks, inside a fenced yard or locked garage.
Roll-back hauler can snag your rig. Towing scams common in Chicago. |
go shooting and pic up all the brass you see. (even if it isnt yours) and trow all of it in the bed of your truck, when they see that they will leave it alone. worked for me when we lived in vegas....
![]() Join Date: Feb 2002
German Shepherd Dog in the drivers seat.
Old member
I have 2 in my 71.
I have a battery kill switch and a Transmission lock out on the truck so even if they get it started they can't shift it into drive no matter what they do. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#13 | |
Old member
![]() Quote:
Yes it is on the truck and it works. I used it everynight on the 2013 Power Tour. Even though I didn't need to I felt better at the motels knowing I did. Newer model vehicles all have it on them. ![]() ![]()
You never said it was a "secret". Where can I buy one?
#15 |
![]() Join Date: Dec 2012
I had a friend who has now left us that used a "Club" that went from the brake pedal and locked the steering wheel in place for his Falcon. Someone still tried to tow the car out of his drive. Luckily he had the front wheels turned sharp enough that it would have towed in circles if no dolly was used....It would've taken too much time. They left. If they did get it how would he find it??
I have thought of 2 things to deter theft in my truck and handle an incident similar to the one above. 1. Install a horn relay that connects to the ignition wire that would have to be disabled before driving the truck. 2. Cell phone type tracking device if it does get snagged so I can find, as well as police, my truck. They are cheap with cheap service costs. Look Here. I am in no way affiliated with the GPS company. Vince
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
#16 | |
![]() Join Date: Jul 2009
#17 |
3 sticks of dynamite. "Touch those tanks and BOOM." LOL
I am going to look into the battery disconnect.... Mine is a 3 on the tree.....I have thought about backing it up against something, shifting into reverse, then removing the shifter. Mine comes out easily. Right now I have few worries: no seat, no gas tank, disconnected fuel line, no battery, and it seems my brakes are rusted up. |
#18 |
I'd like to find a way to lock hood w/o little or no drilling.
#19 |
![]() Join Date: Oct 2009
Meet Kill Switch (aka "Buster"). He cost me $20 at the local pound 12 years ago and nobody's stolen the truck, or him, yet
#20 |
There are a lot of aftermarket companys making remote operated relays. Easy to hide and have a new stile key fob. I have use several on old Harleys and plan on using one on my truck.
#21 |
I use the k-9. People seem to be naturally afraid of dobermans. At 110lbs mine thinks the vehicle is his. Get too close and he barks. Get closer the snarling growling starts. Reach through the window...
'69 K20 350/4 speed/Rockwell/D44/HO52. "orange rhymes with door hinge" |
#22 |
IMHO, the best, although not a deterrent, is a LoJack type device. At about $400 it's a hard check to write but the real question is, how much is you truck worth? Think real hard, is $400 bucks worth getting it back real fast? If it moves about 100 foot without the fob you get a text, call the police and its being tracked within about two minutes of being jacked.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#23 |
The mountain lion in Ricky Bobby's chevelle would be a pretty good deterrent. you may want to keep it in the bed though. On a serious note the club is about $30 and they have a great warranty; if your car gets stolen with it on they will send you a replacement free of charge.
71 K5, AC/Tilt, 4" lift 33" tires 5.3L/4L60E/NP 205 (Under Construction) 05 Dodge 2500 4x4 5.9 Cummins (Daily driver) "Common sense is not so common" My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=555879 |
#24 | |
I've never done the "Drive away without the fob" yet because I'm not sure what kind of commotion it'd cause, but I -would- like to verify that it works right. If I leave the fob at home and drive the truck, do I get a text message before the police are notified? I really don't want to raise a false alarm!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
#25 |
how their truck can't get stolen" in this type of setting.
