think I've decided on a suspension plan.....
My idea is to have a nicely drop DD with a good ride quality while getting rid of all the old worn out suspension/steering parts.
the plan Western Chassis Rear flip kit/no C-notch Western Chassis rear shock extenders DJM 3" front Upper and Lower Control Arms Moog Coil springs (stock replacement) (will fine tune ride height by cutting coils as needed) Stock length Bilstien Shocks all four corners Stock 1 1/4 front sway bar/Urethane Bushings Stock rear leaf springs/shackles with Urethane bushings/teflon lined Moog steering components McGaughys front wheel/brake rebuild kit please critique ![]()
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) Last edited by moregrip; 08-04-2013 at 04:00 PM. |
Re: think I've decided on a suspension plan.....
Avoid drop arms like the plague and do spindles instead. Leave the leaf spring bushings rubber otherwise you introduce bind on corners.
Depending on how low you go stock length bilsteins may not work. They didn't for my truck as I had to use van shocks from the same year vans. The fronts I'm unsure of, haven't tried stock bilsteins up front If you want you can get new coil springs up front just don't cut them for the first week till they settle down a little. Djm spindles seem ok but I wouldn't buy anything else from them again. I imagine your doing the popular 5-7/6 drop? Djm arms don't correct geometry. Just look cool and are like stock arms with low spring pockets. Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
67-72 parts collector,…
![]() Join Date: Nov 2002
X2^^^
Good advice!
I agree with insidious, you may not be able to use stock length shocks up front with the DJM lowers. If you did use the stock lowers with a stock spring (or close to stock) and a 3" drop spindle then I think you could use a stock length front shock. Plus, with a drop spindle you have more suspension travel and less metal hanging down to catch a speed bump, (as insidious pointed out) as you do with the lowered lower control arms. I think most everyone that is lowered has some type of drop spindle. Plus Plus if you go with a large wheel (18" or 20" even better) you avoid the danger associated with having any part of the truck below the bottom of the wheel rim which is common when using 15" wheels and drop spindles (and illegal in many states including california)
OK I said enough... One more thing, if you do a flip kit I would consider a bolt in c-notch. While they are a pain to install compared to everything else, that little bit of added travel will make a big difference in ride quality if you haul or tow anything at all. ok i'm finished...
![]() Last edited by wraprail; 08-04-2013 at 08:25 PM. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I'm running 3 inch spindles and one full coil cut off of used springs. All with stock front shocks. As a 250 pound corn fed guy, I can't bounce the front hard enough to bottom out the shocks. There's plenty of length to spare. My tires are short and they will hit the inner fender well before the shocks bottom.
Posted via Mobile Device |
I have done a flip kit on my stepside with no notch and it sucks. The axle hits the frame a lot, even with new shocks. Once I blow the truck apart I will be adding a notch, so just give that some thought.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
^^^^ X3, use drop spindles.....
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
Check out Project Platinum C10, I don't think he liked the arms he bought.
Are DJM 3" drop spindles any worse than the others?
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) |
#10 | |
based on your wisdom, here is the revised plan:
Western Chassis Rear flip kit with C-notch Western Chassis rear shock extenders DJM 3" Drop spindles CPP upper/lower control arms Moog Coil springs (stock replacement) (will fine tune ride height by cutting coils as needed) Stock length Bilstien Shocks all four corners Aftermarket 1 1/4 front sway bar/Urethane Bushings Stock rear leaf springs/shackles with Urethane bushings and teflon lined Moog steering components McGaughys front wheel/brake rebuild kit
Don't forget van shocks for the rear. I'm running those with shock extenders right now with no c notch and it will get me just an inch past the frame if I notched. I'm dropped 8 inches in the back.
Why do you want aftermarket control arms? Affordable ones just armrest able to do what we want them to and the others are just expensive. You can move the lower 3/4 of an inch forward to gain castor and it will handle better than most bolt on stuff Keep the inner sway bar bushing urethane and the outside rubber. The sway bar will bind with urethane ends as well Posted via Mobile Device
I am running same set up in front as TX firefighter. I replaced the entire front suspension and used new stock front shocks with no problems, rides great. I did have a slight problem with the DJM spindles and had to shave of a bit to get the calipers to fit, just fyi. Others on here are pretty adamant about spending the extra $100 on better drop spindles.
optomistic ah-so
If you plan to do anything Street/Strip or anything performance related, you'll get more results you'll like out of Cal-Tracs on the rear leafs instead of poly bushings.
You can also make adjustments to the rear by removing (or adding) leafs to the pack. Every suspension package should start with the point where the tire meets the road. Even if you are planning on using stock steel rims, determine what size, offset, etc they will be & how tall your tires will be. then determine the components that you have listed. Your recommendations may change if, for example, you have to move the wheel mounting surface in or out.
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. ![]() |
#15 |
I have a flip kit on the back, with the metal bump stops removed, and a little mushroom bump stop bolted in...i may have bottomed out the rear once or twice, but that was for not using common sense when driving. I don't quite have the heart to cut the frame for notches, and i haven't needed to.
#16 | |
#17 | |
What was the issue with the stock length rear shocks? My goal is to get in the 3/5 to 4/6 range.
#18 | |
#19 |
I have 3" djm drop spindles, stock shocks with 1.5" drop springs..Rides great..1 1/16 junkyard swaybar ($20) with black poly bushings made a huge difference.
Flip kit in the rear with no notch and no bumpstops. New leafs and drop shocks. Never bottomed out. Even driving carefully with an 800lbs. load. I think part of the reason some people say you need a notch is because they have worn leafs. |
#20 | |
![]() But when I converted my crew to a short bed, using the rear half of a 1/2 ton frame, I could stand on the frame rails and bounce up and down and make solid contact between axle and frame. If I were to replace the springs, I would end up doing something to bring it back down to where it is now, like shackles? I know it is apples and oranges, but I was told the same thing on my '06 GMC swb when doing hangars/shackles (4"), but it took all of about 3 days before I got so fed up with it hitting the frame I stopped driving it until I got it notched.
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
#21 | ||
Not arguing, just wanting to understand.
#22 | |
#23 | |
As for urethane in the leaf springs and such they move side to side in a small arc as well. Urethane makes them not want to articulate and makes a stiffer ride yet. Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 Last edited by INSIDIOUS '86; 08-05-2013 at 05:51 PM. |
#24 |
Any idea what the van shocks measured full open end to end?
#25 |
Hopefully getting closer, please critique Version 3:
McGaughys 4/6 lowering kit Porterbuilt 1" forward lower control arms/Stock upper control arms Stock rear leaf springs/shackles with Urethane bushings/teflon lined Moog steering components McGaughys front wheel/brake rebuild kit still shopping for shocks..............McGaughys specs a 13.5" front shock and a 18.5" rear shock for their kit.
