Old 08-07-2013, 06:10 PM   #1
scary gary
22" GM Transport Steel Wheels on Square body? Anyone?
First, I'll say that I've searched over the past 2 weeks.. here, other forums and google for answers or pictures, but come up empty.
I am curious to know if anyone has attempted to slide a set of these beautiful 22" GM transport steel wheels on a square body? Whether by using adapters or swapping rotors/axles/etc.. If anyone has experience with this, please shed some light.
That being said, I've already got a set on the way. I've done A LOT of calculations and its looking like its possible with about a 2" adapter (to make up for backspacing and center bore issues). And I am curious of the tire choice and clearance issues.
Perhaps I'll be the one to answer my own questions, but I figure I could ask since I couldn't find anything.
Any help is appreciated. Thank you
NOT MY PIC.. (just for reference)
scary gary is offline   Reply With Quote
Old 08-07-2013, 10:49 PM   #2
Ziegelsteinfaust
Re: 22" GM Transport Steel Wheels on Square body? Anyone?
I think your going to have to swap rotors, and axles. Or at least have them re-drilled.
From what I have seen online the back spacing will set them a bit inside compared to square body rims. I am referencing other GMT-900 rims on square bodies, and I can not imagine these being different.
So you may end up using spacers to get the right stance.
Ziegelsteinfaust is offline   Reply With Quote
Old 08-23-2013, 01:15 PM   #3
scary gary
Well after a lot more research online and using offset and fitment calculators, I went ahead and ordered the adapters. Yes, they are 2 piece. The 5x5 and 6x5.5 patterns share a stud. I was going to swap rotors and axles, but since the offset is so high, I would have to use a spacer. And, I still may do that down the road. I'm aware that adapters have a bad rep.. but I've driven over 100K miles with knockoff Dayton adapters that people have told me are very scary. In my experience, you just need to keep an eye on them and make sure they are tight.
I really just wanted to see if I can get them to fit my Blazer and still be able to lower it.
Here's are some photos of the adapters on my Blazer, the wheel mounted, and the wheels with 255/30s mounted on my friend's lowered 87 c10.
Looks like I'm going to be able to lower it. I have no problem trimming or rolling the fender lip if needed. They seem to clear the rear fine, and do not rub anywhere on the front when turning. I'm really excited
Old 08-23-2013, 01:31 PM   #4
82ccshorty
82ccshorty's Avatar
Those look really good on there.
1969 chevy camaro Z28 #matchin Factory 4wheel disc
1969 chevy cst10 big block overdrive 5/7 drop dog dishs
1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s
2004 gmc sierra dually 4/4 lowering daily driver
82ccshorty is offline   Reply With Quote
Old 08-23-2013, 06:19 PM   #5
bbbc10
Diggin The SquareLife
hell yea!!!!!! need more pics of them on the blue truck!!!!! whts the drop on it btw!!! I was gona get a set of these but didn't happen but now ima make it happen!! lol needs some ol school hub caps
bbbc10 is offline   Reply With Quote
Old 08-23-2013, 06:55 PM   #6
scary gary
I agree, they look awesome on his truck. He said it has 2.5" drop spindles with a coil cut up front and a flip kit in the rear. I dont know which brand of parts that were used.
I'm gonna get them fitted to my Blazer with the drop and then I'll paint em and figure out which cap to use..
Here's more pics of them on the blue 86..
Old 08-23-2013, 07:08 PM   #7
Redcap
That looks bad ass!
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 08-23-2013, 07:13 PM   #8
bbbc10
*****in!!!!!! have you thought bout running 6 lug rotors up front so you can have more room between the wheel and fender lip??? an thanks for the info!
Old 08-24-2013, 12:49 AM   #9
nheller76
nheller76's Avatar
Man I was totally skeptical when I first read all of this! But u have sold me on this they look AWSOME!!!!!! I now need to find a way for this to work on my 8 lug rear end!
Faith and Patience with my truck, that is what i pray for every day!
See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013
nheller76 is offline   Reply With Quote
Old 08-24-2013, 08:21 AM   #10
1slo_camaro
ok ok ok personally not a huge fan of it but damn you have a clean truck! just not my cup of tea
1978 2wd Fleetside, 350/th350 headers and 10 series mufflers
1998 Jeep ZJ 4.5 lift 32s full bolt ons awaiting axles
"Life is full of decisions, we make them and dont look back"
1slo_camaro is offline   Reply With Quote
Old 08-24-2013, 11:39 AM   #11
Redcap
I'm not a fan of big wheels most of the time either, but those big steels look really cool on there in my opinion.
Old 08-24-2013, 11:42 AM   #12
scary gary
It's too bad they aren't going on that truck. I'm putting them on my 79 2wd blazer today. It's getting lowered as well. I'll post pics when it's done.
But thanks for all the comments!
Old 08-24-2013, 11:56 AM   #13
lolife99
67-72 parts collector,…
lolife99's Avatar
Looks like they would tuck alot better up front without the adapter.
Just use an aftermarket 6-lug rotor on HD drop spindles.
My opinion,... run a 5-lug 22" Centerline Smoothie wheel (painted black) for the same effect.
Plus you don't have the gawdy "triple lip" that the GM transit wheels have.
Keith
Convert to disc brakes.
Old 08-24-2013, 12:35 PM   #14
TIM86
TIM86's Avatar
There really isn't much room to tuck up front. I was running 20" ss camaro rims for a bit. It had a pretty bad turn radius. The room in the feont wheel wells is non-existent.
TIM86 is offline   Reply With Quote
Old 08-24-2013, 05:37 PM   #15
scary gary
If I decide to keep these, I will work on a way to get a 6 lug rotor with enough clearance for the high offset of these wheels. At that time, I would also need to figure a way to get them to spaced further outward. That high offset will suck them way in without some sort of spacer.
and...
22" Centerline Smoothies - $2332.25 on Summit
22" GM steelies - $550.00 (what I felt was a fair price)
Even with adapters and tires mounted, I'm still $1,000 less than what the smoothies would cost new. I know they aren't in the same ballpark when it comes to construction and materials.. But I'm happy with what I have.
Plus, I want to paint the lips white when I get a chance...to give it a whitewall effect when rolling.
But thanks again to everyone who's chimed in. My k5 should be done tomorrow and I'll post some pics.
Old 08-24-2013, 05:44 PM   #16
bbbc10
right on!!!! cant wht for pics!
Old 08-24-2013, 10:28 PM   #17
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
I can get Mcgaughy's 6-lug rotors for the front ..... How about 4x4 rear axles in the rear housing ...? Then use a single spacer to move them out ...? Is that doable ....?
ksbrktracer is offline   Reply With Quote
Old 08-25-2013, 10:54 AM   #18
UKNOWME
UKNOWME's Avatar
and...
Where did you get them?
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 08-25-2013, 12:44 PM   #19
scary gary
Picked them up from a member of this board... they pop up in the 99+ parts section from time to time.
Here's a shot of them on my 79 k5. 2.5" McGaughy's drop spindles with the flat coil cut. Rear flip with notch. The front sits a little higher, but thats as good as it will get for now. It's my daily, so it's gonna have to be practical. I am happy with it. Looking forward to painting them and figuring out which cap to use.
Old 08-25-2013, 03:33 PM   #20
bbbc10
I was thinkn bout doing the 4x4 axles swap but all the axles I found are not the same length as the truck ones...would this make a difference?
Old 08-25-2013, 03:36 PM   #21
ksbrktracer
TNT-MOTORSPORTS
Yes it would as they are held in with C-Clips ...... I wasnt sure if they were the same length or not ....!
Old 08-25-2013, 04:00 PM   #22
bbbc10
they are c clips axles an they are they same spline etc but just different lengths....I heard they was I direct swap but never could get a good answer or wht axles. but he could have custom axles made or swap the whole rear end etc
Old 08-27-2013, 06:55 AM   #23
eldogg
eldogg's Avatar
Looks great!
eldogg is offline   Reply With Quote
Old 08-27-2013, 10:32 AM   #24
Redcap
Almost makes me wish I had something in 6-lug.
Old 08-27-2013, 02:39 PM   #25
bnoon
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
