08-10-2013, 01:14 PM | #1 |
F/S Wiper Delay
Ready to ship!
This is the "next gen" wiper delay. The first gen saw much success in the 67-72 forum. This revised model will fit 60-72 MY's. 100% reversible and installs in minutes. Gives you approx. 3-30 seconds of delay and does not require harness cutting, splicing or soldering. The video shows the "install" in my 72, installing it in your 60-66 will be very similar. Instructions specific to 60-66 are included. A big thank you to CaptainFab as he was instrumental in making the adaptation to the 60-66 MY's possible. http://www.youtube.com/watch?v=SWpj-...ature=youtu.be Please see this informative post from 67-72: http://67-72chevytrucks.com/vboard/s...d.php?t=593984 Last edited by twouvakind; 11-02-2014 at 09:06 PM. Reason: content |
08-10-2013, 03:21 PM | #2 |
Re: F/S Wiper Delay
Can I order two for payment on Friday? I don't get paid till then.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-10-2013, 05:21 PM | #3 |
Re: F/S Wiper Delay
08-10-2013, 06:04 PM | #4 |
Re: F/S Wiper Delay
Great! Thank you!
08-11-2013, 12:23 AM | #5 |
60-66 Nut
Re: F/S Wiper Delay
I'm glad to see that you have this for sale thread up Bill.
I'll add just a little to this for those interested in this delay unit. This wiper delay does give you a delay range as stated, with the wipers 'parking' every time, and is very easy to install. Also Bill doesn't mess around with shipping. You'll have your delay unit before you know it. And if anyone has any trouble installing theirs, I will be willing to help.
08-11-2013, 08:09 AM | #6 |
Re: F/S Wiper Delay
Thanks again John, now you are stepping up for tech support! This is a great opportunity to get that option that GM could only dream of back in the day.
What some buyers of the first gen from the 67-72 side of the house have said: "The workmanship & detail looks exc. I can't wait to do an install. thanks again" "Yes. works great. thanks again. Hope you sell many of them on the board. They are definately worth the money. Finally, someone has come up with a intermittent wiper that is easily installed and works flawlessly on our trucks" "BTW your wiper delay works great! I love it." |
08-12-2013, 10:42 AM | #7 |
Re: F/S Wiper Delay
Gotta have one, mine's daily driven. PM me some payment info.
08-12-2013, 12:24 PM | #8 |
Re: F/S Wiper Delay
08-12-2013, 08:01 PM | #9 |
Re: F/S Wiper Delay
08-13-2013, 02:12 AM | #10 |
Re: F/S Wiper Delay
ttt
Hi Bill, after a number of other side track projects got in the way and took precedence, i finally got my 1st Gen wiper delay installed today, it works great! Thanks again.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
08-13-2013, 10:39 AM | #11 |
Re: F/S Wiper Delay
Another success story, I thank you for that. $62 shipped for the "next gen". The next gen works just like the first gen.
08-14-2013, 09:30 AM | #12 |
Re: F/S Wiper Delay
To top
08-14-2013, 06:51 PM | #13 |
Re: F/S Wiper Delay
Works on single speed wipers too????
08-14-2013, 09:13 PM | #14 |
Re: F/S Wiper Delay
08-14-2013, 11:31 PM | #15 |
1961 crewcab
Re: F/S Wiper Delay
saving this thread.. will probably order some when I can afford it!!!
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
08-14-2013, 11:34 PM | #16 |
1961 crewcab
Re: F/S Wiper Delay
Heck!!! can't edit any more on posts!!!! curses!
... so my wiper is a 64 washer wiper... will the washer part still be able to work? does this use the original switch? thanks!
08-14-2013, 11:51 PM | #17 |
60-66 Nut
Re: F/S Wiper Delay
When the delay is turned off, your wipers and washers work as normal. I haven't tried the washer, when the delay is on, but usually when you have the delay on, it is because you have a certain amount of water on the windshield already.
Yes you keep the original wiper switch. You just unplug the light blue wire, and plug in the delay wires between the light blue wire and the terminal on the wiper switch. The control for the wiper can be mounted wherever you like. There is also a 12v and a ground to connect. This wiper delay is very simple to do.
08-14-2013, 11:51 PM | #18 |
Re: F/S Wiper Delay
The unit has no effect on the wash function or traditional wiper function. You keep your wiper switch, this unit comes with a variable control for you to mount in a 5/16" hole or bracket(included)hole.
08-14-2013, 11:54 PM | #19 | |
Re: F/S Wiper Delay
what he said! Quote:
08-15-2013, 10:13 AM | #20 |
Re: F/S Wiper Delay
To top
08-15-2013, 06:51 PM | #21 |
Re: F/S Wiper Delay
I will most definitely be ordering one of these very soon!!!
Where in Jersey are you?
_____________________________________________ Ray All my life, I've been told I'm a "Bad Influence" |
08-15-2013, 09:03 PM | #22 |
Re: F/S Wiper Delay
08-16-2013, 08:29 AM | #23 |
Re: F/S Wiper Delay
Payment sent, thank You!
08-16-2013, 02:24 PM | #24 |
Re: F/S Wiper Delay
08-17-2013, 06:36 PM | #25 |
Re: F/S Wiper Delay
To top
