should I c-notch
i am lowering my c10 5 inches in the rear.should i install a c-notch kit? I have heard some guys don't bother to do it .I will not be doing any heavy hauling just cruising,also will i need to get the special drop crossmember that the driveshaft goes through? thanks for the help.
#2 | |
![]() Join Date: Feb 2012
Re: should I c-notch
#3 | |
///Relaxed Atmosphere
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
Not needed. My tires sit .5" from the wheel well without and still have lots of bag for suspension.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I've built half a dozen of these trucks in the last 10 years, all lowered 6 inches in the back. Never notched a single one. Typically I haul motorcycles or drive unloaded. I don't see the need for it.
Posted via Mobile Device |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
^^Agreed^^, I dont think its needed if only dropping 5 inches.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
Moderator
![]() Join Date: May 2007
I put 5" drop springs in my truck and only had about 1/2" clearance from hitting the frame. It bottomed out going over bumps frequently. I ended up notching and no more problems. Try it without, and if you need it install it, not hard to do at all.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#8 | |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
What brand of rear springs are y'all using? You've all seen the stuff I put together and always use ECE springs. I do remove the tall bumpstops and cut them shorter with a hacksaw. Never an issue with excessive bottoming out, including hauling Honda GL1000 Goldwings. Unloaded, I can't think of a time I've ever bottomed out. There's a layer of dust on the axle where the bumpstops havent touched it in ages.
Moderator
I used 5" CPP springs, which I have found are the SAME as the 6" springs ECE offers. Board member Shawno72 has even swapped out his 5" springs for the ECE 6" springs and the truck actually sat higher...I am pretty sure the vendors get their springs from the same manufacturer and just put their name on it.
![]() Join Date: Jan 2011
For 5" rear spring, I wouldn't notch it. 6" + then yes..
The factory cross member will be fine. I would consider shock relocation brackets and an ECE super track bar (if you haven't already)
#12 | |
No
Mines dropped and has no had it done am I'm definitely going to get it done, all I do is cruze, trust me do it
#15 |
![]() Join Date: Jul 2012
4/6 ECE drop kit on my 71 with no notch. No problems at all, no where near bottoming out.
#16 |
thanks for all the replies,huge help i will post pictures of the build as soon as i figure out how to.
#17 |
![]() Join Date: Mar 2012
May as well do a notch then you don't have to worry. I had 6" springs in the back of mine and it was 1/2" from the frame. Bottomed out constantly.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
#18 |
2WD Jimmy
![]() Join Date: Mar 2005
Square-78...does your GMC have leaf springs? Because that would be a different result than coils.
#19 |
Leaf versus Coil
I am following this thread closely because I am on the verge of ordering a drop kit for my 1972 GMC LWB. It would help a lot to know the posters' experiences with leaf springs versus coils.
#20 | |
![]() Join Date: May 2013
ccp 3-5 drop kit |
#21 |
Moderator
Bottom line: Results will vary, use if needed.
#22 |
I and most others I believe assume , you have coils in back , if you have leafs its totally different than my truck
#23 |
I have CPP 3" drop springs and 2" drop blocks with no frame mods whatsoever. Factory frame from front to back, including cross member. No bumps or rubs anywhere. The PO cut the bump stops down a bit as he had 5" springs (I assume they where 5" because it sits the same with the spring/block combo I put in.) It definitely rides nicer with taller springs and drop blocks then it did with an all spring drop. I also have an adjustable panhard bar, and rear shock relocators.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
