Old 08-20-2013, 05:59 PM   #1
In The Ten Ring
Any tricks to putting fuel hose on?
Are there any special tricks to slipping rubber fuel hose onto metal fuel lines?
This step is coming up in about 3 weeks when it's time to put the tank back in and hook up the fuel system.
Thanks!
In The Ten Ring is offline   Reply With Quote
Old 08-20-2013, 06:20 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Any tricks to putting fuel hose on?
No tricks.
Make sure the rubber hose is for fuel and it is the same size as the steel line you are putting it on and use quality clamps. I would suggest the steel line has at least one barb on it to prevent the hose from slipping of. You can do this with a flaring tool. You can rent a flaring tool from many different parts stores.
To make a barb, just follow the instructions as if you were making a double flare on the steel line. Once you do the first step, you have a barb.
If you have questions on this, watch a you tube video about double flaring steel line.
TBONE1964 is offline   Reply With Quote
Old 08-20-2013, 07:17 PM   #3
jpmanyhearts
frankenstien Fabrications
also if you are having a hard time getting it to slip on use some wd-40 or some watered down joy dish liquid in a spray bottle
frankenstein Fabrications
jpmanyhearts is offline   Reply With Quote
Old 08-20-2013, 07:34 PM   #4
slikside
slikside's Avatar
Spit works too.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 08-20-2013, 08:31 PM   #5
In The Ten Ring
Originally Posted by slikside View Post
Spit works too.
That's what she said!
Sorry, couldn't help myself. I am actually keeping the original hard line, just replacing the hoses. I did use compressed air to blow out all hard lines (fuel, vent, and vacuum). I am replacing the original spring-type of connectors with the screw down type.
Thanks for the advice guys! That job is coming up week after next (assuming success on cab-to-frame bushing replacement).
Old 08-21-2013, 11:21 PM   #6
slikside
slikside's Avatar
Originally Posted by in the ten ring View Post
that's what she said!
lol!...
Old 08-21-2013, 11:26 PM   #7
Bruser
Vaseline work well also
Bruser is offline   Reply With Quote
Old 08-21-2013, 11:53 PM   #8
suxtobu65
suxtobu65's Avatar
Spit works too.
x2... Mechanics lube... LOL Small amount of spit inside the end of hose and it'll slide on easy..
suxtobu65 is offline   Reply With Quote
