Old 08-28-2013, 12:00 PM   #1
ksshane
ksshane's Avatar
Need rear shock location picture (leaf springs)
My truck started its life (as Im told by the PO) as a step side with leaf springs. But it now has a fleetside bed on it.
Upon further inspection I found that the shocks were either broken or cut at the top and are just hanging there. Holding up by the rusty bolt just waiting to work their way loose and cause some serious damage.
So the easy fix would be... replace the shocks right... Thats what I fully planned on doing, but then I realized the upper shock mount does not align with the lower shock mount. The lower mount is straight up and down, and the upper is at an angle.
So I did some searching and found a picture on here of someones rear shocks mounted with the upper mounts at an angle. These are for the trucks with rear springs.. Not leafs like mine.
Did the frames come with both styles of shock mounts and they just decide if they are springs or leafs as it went down the assembly line?
Could someone with rear leaf springs take a picture of their rear shocks so I can see how they are mounted. If possible I would like to see a step side and a fleet side so I can see what all has been changed (or not changed) on my truck.
71 swb 350/4sp manual 5/7 static drop
ksshane is offline   Reply With Quote
Old 08-28-2013, 12:44 PM   #2
C_Ruiz
Re: Need rear shock location picture (leaf springs)
You can always relocate it with the kit?
I know ECE and porter built sell kits to do so for the front and rear, if the front interests you?
I also have leafs in the rear and opted for PB shock relocator kits front/rear.
Unfortunately, they're not installed yet. Im also installing airbags so it was easier for me to just get the kits. Hope that semi helps.
C_Ruiz is offline   Reply With Quote
Old 08-28-2013, 02:09 PM   #3
ksshane
ksshane's Avatar
I just dont see where the shock would mount at the top. Unfortenatly the top of the old shocks are completly gone. The only thing I can think of is there are some holes in the frame itself that a bolt might fit in, but Id like to see a photo to see if thats the correct location or maybe if there is a bracket missing.
Old 08-28-2013, 03:42 PM   #4
ksshane
ksshane's Avatar
I have a picture at home (at work right now...shhhhh) that Ill post. Maybe it will help explain what Im talking about.
Old 08-28-2013, 04:41 PM   #5
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
If someone doesn't post one I will take one when I get home in a few hours.
I have a fleet side
"Instructions are just another mans opinion"
Become a Supporting Member
http://67-72chevytrucks.com/vboard/payments.php
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 08-28-2013, 04:50 PM   #6
ksshane
ksshane's Avatar
much appreciated
Old 08-28-2013, 05:36 PM   #7
ksshane
ksshane's Avatar
Here is a picture of the rear. On the drivers side I see a hole in the frame that might allow for a bolt to tie into the shock, but I don't see a hole in the passenger side to allow for a bolt.
As you can see I have 2 brackets at the top that there is no way my shocks will align to.
Old 08-28-2013, 05:40 PM   #8
no_rice
that looks nothing like the factory mounts on my 70 gmc shortbox leaf. something is wrong there.
no_rice is offline   Reply With Quote
Old 08-28-2013, 06:43 PM   #9
lolife99
67-72 parts collector,…
lolife99's Avatar
Are the leaf spring hangers bolted on or riveted on?
Keith
Convert to disc brakes.
Old 08-28-2013, 07:07 PM   #10
ksshane
ksshane's Avatar
Bolted on...
So you think the PO bolted in leaf springs, and this was originally a spring rear end?
Im starting to worry more and more about this truck
Old 08-28-2013, 07:11 PM   #11
68gmsee
Active Member
68gmsee's Avatar
Here's a couple pics of my 68 GMC. The right side and left side are identical.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 08-28-2013, 07:13 PM   #12
ksshane
ksshane's Avatar
I don't see a bracket like that in my frame.
Old 08-28-2013, 07:27 PM   #13
lolife99
lolife99's Avatar
Originally Posted by ksshane View Post
Bolted on...
Yes.
Because the upper shock brackets are still riveted on.
Is the trailing arm crossmember still in place?
Keith
Old 08-28-2013, 07:29 PM   #14
lolife99
lolife99's Avatar
If you could locate some factory "leaf spring" upper brackets,... You could bolt them on to your existing frame.
Keith
Old 08-28-2013, 07:33 PM   #15
ksshane
ksshane's Avatar
it does have a crossmember, but there are no brackets for trailing arms
Old 08-28-2013, 07:41 PM   #16
lolife99
lolife99's Avatar
You need leaf spring upper shock mounts,... or,...
trailing arms, brackets, coil springs, coil spring lower shock mounts, and a trailing arm rearend
Keith
Old 08-28-2013, 07:42 PM   #17
lolife99
lolife99's Avatar
Can you post some pics of the trailing arm crossmember?
Keith
Old 08-28-2013, 07:43 PM   #18
ksshane
ksshane's Avatar
Yea, Im looking online for upper mounts.
I can only guess why the PO replaced all of this. All he told me was the step side bed was rusted really bad and a friend found this fleetside bed so they changed it out.
Im thinking there is much more to the story now.
Old 08-28-2013, 07:44 PM   #19
ksshane
ksshane's Avatar
Oh, and thanks for your help Lolife99
Old 08-28-2013, 07:54 PM   #20
68gmsee
Active Member
68gmsee's Avatar
Might be a frame from a different year truck. Could still be okay if the proper location brackets are there and the proper shocks used or you could make or have someone make you the upper brackets.
btw: that are some heavy duty rear springs.
06 Trailblazer
Old 08-28-2013, 09:19 PM   #21
68 TT
Still plays with trucks
68 TT's Avatar
My 69 Chevy C10 was optioned with the leaf springs and I just converted it to trailing arm. It had the front trailing arm crossmember with the mount holes for the carrier bearing and front trailing arm mounts but no brackets on it. The upper shock mounts are just like the pics 68gmsee posted.
The leaf spring mount brackets have locating ridges molded into the frame rails that are not on the trailing arm frames too. See first pic.
The bump stop brackets on the trailing arm frame are in a different spot and the panhard bar mount is not present on the leaf spring frames either. See second pic. These are the trailing arm parts bolted onto my leaf spring frame.
You have the trailing arm shock mount/spring reinforcement crossmember in your frame so it was originally a trailing arm frame if the crossmember is riveted in. They may have removed the front brackets and crossmember for exhaust clearance.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
