#1 | |
![]() Join Date: Oct 2013
Re: Rat repair.
![]() Join Date: Aug 2012
Re: Rat repair.
At least you found it and it want cost a arm and a leg to replace. Good luck
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper |
Re: Rat repair.
Rear drive shaft is painted and drying, took notice that it has some arrows stamped on it, one on the end of the tube by the slip shaft, the other on the slip yoke, the arrows are at 90 deg to each other but the U joints are aligned up properly...... I figured the arrows should be in line with each other but i guess not...... I have not had the drive shaft apart myself but don't know about prior to 1994.
Time to get ready to go to a wedding now.. Not mine tho. ![]()
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Re: Rat repair.
Finally got both drive shafts on, the calibration unit back on and the new alternator back in, the noise is gone!~ Paid attention to the millage signs posted along the freeway and my speedo is pretty close.
EDIT: Forgot to add the drive shaft place and i had a miss communication, when i got there he said he said $180, i said i could have sworn you said $80.... Nope, but he decided to cut me a discount for the miss communication, knocked $20 off the price for me. Exhaust manifolds still on back order, i did order some Eastwood 1200 degree paint Saturday i decided to put some miles on it and drove to an auto body shops open house/car show in a neighboring town, my wife works with a guy who is good friends with the shop owners, of course the rat didn't compare to the cars and trucks their and i didn't take any pics, but i wanted to see about them doing some work, the friend showing us around said these guys are way out of the league of most of us, looking at 100,000. min to build most anything, yea that's out of my league LOL! I did end up parking next to another 72 K20 so i snapped a pic, this truck looked to be a survivor, paint a little ruff but way shiner than mine! I'll admit with summer here i have lost a little steam, plus not being a body guy i am getting a little bit of some cold feet. I know i am gonna have to start soon before rainy season starts, probably have to shoe both bikes to one side of the garage again and setup a small body area on the garage too.
Re: Rat repair.
Well i don't know what i'm doing but figured I'd start with 2 areas on my bedside. When i say i don't know what I'm doing first off i still don't know if i have enough hardener in it, its been a little over an hour and its still a little tacky......First i scuffed up the area to bare metal, wiped it off then mixed up the mud and spread it over trying to push it into the surface as i went, I did overlap beyond where i sanded but figure I'll sand most the mud off back to the painted area. Hopefully there won't be a bunch of air bubbles when i sand it down. Tried not to put it on too thick but hopefully enough that i'd only need a skim coat next? we'll see.
![]() These two areas are relatively small compared to the areas on the lower part of the bedside. I should have removed the door first, its off now. ![]()
#6 | |
![]() Join Date: Mar 2012
Re: Rat repair.
Victor 57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas |
Re: Rat repair.
Thanks for the tips Vic i really appreciate it. Just got home a little while ago, the filler is still tacky to the touch just like when i left for work, if you tap on it with your finder nail it does sound solid.
The guy at the paint and body supply said to put a golf ball sized glob of filler down then put a straight line of hardener across it, my concern lies in the fact that the cured filler sample at the store if i remember correctly has a lot of red (hardener color) making almost a pink color, as you can see in the picks i'm not any where close to a pink hue. but it was apparent that as soon as i got a coat on around the filler weld that i couldn't add any more as the stuff was no longer workable I didn't know you were able to vary the amount of hardener due to temp, nice to know.
#8 | |
Re: Rat repair.
The mixed color should be very pale to start and will deepen slightly as the hardener activates. I start by using a mixing stick to ladle out several dollops of filler onto a mixing board. Scrape the excess off the stick with your plastic spreader, set aside the stick and put the lid back on the can. Based on the size of the puddle on the mixing board, squeeze a bead of hardener across the top of the puddle. I then use the corner of a medium sized plastic spreader to quickly stir the hardener into the filler using a circular motion. As soon as the color gets somewhat uniform, I start using the long thin edge of the spreader to "fold" the mixture. Scrape it toward the center and keep folding it over until you see no streaks of hardener left. At this point, it's ready to apply. I usually start with a small portion of the mix and spread it slowly and evenly over the prepped area. Load up another small amount and continue spreading until the entire area is covered with filler and the low spots are gone. You'll need to work quickly to stay ahead of the catalyzing process. Smooth even strokes when laying down the filler will help minimize the bubbles. If the mixture starts to congeal, walk away and cleanup your spreader. Attempting to sculpt filler already on the panel will only ruin what's there. Knowing how much hardener to use comes with experience. Too much and the mix sets up before you can finish laying it down. Too little (especially in winter) can cause it to fail to take a set. In that case, all you can do is scrape it off the area with a putty knife and start over. Never try to cover it with a "hot" layer of mix. It ain't rocket science. Like most new things, after a while you'll wonder why you ever worried about it. Now let's see some bondo dust!
#9 | |
Re: Rat repair.
Yep the tacky surface is removed. I didn't get much done today, had a dentist appt, stopped at Home depot to buy a DA sander and some 40 and 80 grit disks, my hand held electric wasn't cutting it. My new DA is a 6", the bottom of the filler by the body line is kinda tight quarters, wouldn't mind a smaller sander, guess a sanding block will work. Don't know if anybody has experience with this glass filler, UPol can on left, i don't wanna start itching like crazy so after roughing off the surface i blew the dust off i hopped into a cold shower to rinse it off., leaving for work in 10... ![]() I have a lot more mud to apply yet.
SWB 4x4 Collector
![]() Join Date: Jun 2001
Re: Rat repair.
As Vic has previously said most of it, from my own experience, I run a bead down the middle of the putty with hardener just to make sure it has enough (lord knows when I first started with bondo on my truck years ago, if you didn't put enough in, that was a real treat. Just make sure you have uniform color throughout the mix. Also, don't try to spot, feather it out, as it will save you on sanding time, and you won't get the high ripple effect. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
#11 | |
Re: Rat repair.
I noticed you have some "euro" spot putty. Most of these products are little more than acrylic lacquer in a tube. If you squeezed out a glob in a cup and mixed in lacquer thinner, you could spray it like primer. Never have found any that doesn't shrink - big time. Use it sparingly. Works best with tiny pinholes. Once the filler is worked down and the edges feathered out pretty well, I spray several heavy coats of 2K primer and block by hand. It will fill any pinholes and eliminate the need for the acrylic spot putty. Primer out of a rattle can (even the "high build" stuff) has very little mil thickness. I recommend you invest in a $20 spray gun from HF, buy a quart of 2K primer and the activator and you'll see a world of difference. Don't worry about whether it comes out perfect, you're going to sand it anyway. Test the spray pattern on a sheet of newspaper taped to a wall and when it looks like a long narrow oval and doesn't run down the paper, you're good to go. A round pattern means too little air, a figure 8 pattern means too much. Both conditions are fixed with the top knob on the gun. The one below it controls the amount of paint coming out. Air pressure at the gun should be between 10 and 30 psi, depending on the material being sprayed and your other adjustments. Take a deep breath and watch the magic happen. You'll be an expert in no time flat. If you run into a problem, post it up and we'll sort it out. There is no problem you'll run into that I haven't experienced at one time or another. And some, I'm embarrassed to say, I've seen more than once. ![]()
Re: Rat repair.
Thanks Vic for the tips and link to the spray gun.
Round two: I forgot to take a pic after sanding the first application of filler, but its apparent that i really need to build up the inner area of the gas door opening as well as a couple other areas, i'm trying to build it up but with the inner area of the door being open its hard to put any kind of pressure on the filler when i lay it on. This is going to make the flip door quite a bit lower than the surface so i don't know if i'm going to have to mud the flip door or if i'll be able to tweak the hinge to raise it up. Its also difficult to get the mud right where ya need it at the opening. The area adjacent was a small crease, sanded after one application of mud, note the size of the pin holes and hope they are acceptable? This round is gonna teach me about sloppy application going beyond the area the mud was needed, Gonna spend a little extra time sanding on this one.. I think i need a mud file. Question, how long should i wait before i sand? this already seems to have kicked, but don't want to push it.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's Last edited by swamp rat; 08-28-2014 at 03:06 PM. |
#13 | |
Re: Rat repair.
Re: Rat repair.
Had a DR appt today so that killed my afternoon... only had time to stop at the body and paint store.
I have come to the conclusion that i'm gonna sand off the majority of this glass based stuff and go plastic based, probably leave a small layer around the weld area but want to be able to completely cover the glass with the new stuff. I talked to the body place down the street and she said this stuff is her most popular, some are more expensive and a bit more sandable and some are less expensive, this one is suppose to be pretty easy to sand as well. So i bought it. http://www.u-pol.co.uk/product-cat/9...ody-filler.htm she also highly recommended the Dolphin Glaze but i was not sure if i would want the glaze or possibly the Dolphin Putty instead after what Vic mentioned about shrinking..??? or just go ahead and try using the stuff i already have if i have pin holes to fill. http://www.u-pol.co.uk/product-cat/9...and-glazes.htm There is also a good video on mixing the filler as well; https://www.youtube.com/watch?v=v2oFFSkDNQM I'll try and get it sanded off tomorrow before work.
#15 |
Re: Rat repair.
Ok, sanded off almost all the glass, all that's left is level with the surface of the door opening, good riddance to that stuff.
I thought I'd post a series of shots with a straight edge to show what I'm up against and why i slathered on the glass as thick as i did, the heat from welding did cause a lot of shrinking, i didn't know about planishing each spot weld as i went to help keep the shrinking at bay. Keep in mind also this panel already had some body damage prior to welding in the door. I know its not gonna end up perfect but don't want it to be painfully obvious there was prior damage. First series of shots are from above, top to bottom, hard to focus when you cant see the screen but i think there is enough detail. starting at the top the panel surface has pulled in, you can see a lot of low spots as you move down, probably some about .100 deep.
#16 |
Re: Rat repair.
Heres a series of shots from the side, again sorry about the focus..
#17 |
Re: Rat repair.
Stupid question 101:
After block sanding you still have low spots and need to apply more mud, do you need to hand sand the low areas for proper adhesion? I'm assuming so. One thing i can say is i sure like working with Bondo better than that glass crap, i just assumed the glass stuff was regular Bondo with glass added when i got it, nope!
#18 | |
Re: Rat repair.
#19 |
Re: Rat repair.
Thanks Vic!
#20 |
Re: Rat repair.
Well i come to the conclusion that laying Bondo is an acquired skill when you have to build up around an opening, first i thought i may have been using a little too much hardner, i couldn't apply all the way around the opening without messing up where i started, but i just figured i'm not fast enough so i had to do 1/2 the opening then wait and do the other half after i rough sand the ridges.. My fingers are sore tonight LOL!
Still need to work the body line a bit. But as a whole it looks a lot better in person than in the pic's, this is all rough sanded, took forever to find and work out the high spots, glad i decided to reference the other side of the bed because i had way too much of a crown built up that i would have missed had i not looked, it would have shown up in the primer i think. These picks after i applied the last touch up coat.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's Last edited by swamp rat; 09-01-2014 at 11:28 PM. |
#21 |
Re: Rat repair.
looks great!
Dean 1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187 in God we Trust ![]() |
#22 |
Re: Rat repair.
As one machinist to another you do not need to hold that .0001 tolerance when doing body work. It sure looks great! Keep us posted!
#23 |
Re: Rat repair.
Thanks for the encouragement guys! Greatly appreciated. Didn't have time to do anything today, will get back at it tomorrow.
#24 |
Re: Rat repair.
Question for all you body experts. It decided to dump some rain after I left for work. My truck is under the car cover but the roof is old and I haven't had time to replace it yet. If by chance some water drips onto the Bondi will that ruin the work I did? Gonna have my wife check on it when she gets home and toss a folded up tarp over the area.
#25 |
Re: Rat repair.
Well the bondo work is mostly done on the filler opening, will probably need some final adjustment after the door hinge is in place.
Which leads to my current situation. Need to figure out the best way to raise the door to the surface, its got a ways to go to say the least and i knew this was gonna be an issue. Whats the best approach to bend the hinge to raise the door?? Help! ![]() Got a short stretch of sun yet before the rain starts, its already turning cold at night and i really need to get this bondo primed but am hesitant to prime until after the door is adjusted.
