09-17-2013, 12:57 PM | #1 |
What do you do to inner fenders?
I have a set of inner fenders I may put on my truck. They are from a 1967 (my truck is a 1972) but people on this site say they'll fit.
What do you guys do for inner fenders (the undersides)? Powder coat or paint and why? Thanks! |
09-17-2013, 01:14 PM | #2 |
Re: What do you do to inner fenders?
bedliner or undercoating is what I usually see.
09-17-2013, 01:31 PM | #3 |
This is what I used. It went on easy, and is holding up well
Posted via Mobile Device |
09-17-2013, 01:31 PM | #4 |
I am a Referee of life.
Flat black paint works well.It's easy to touch up.I think the ones I'm putting in the panel will get coated with DIY bedliner.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
09-17-2013, 01:48 PM | #5 |
i painted mine with rustoleum semi gloss black through a gun. worked good
My 71 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=548438 |
09-17-2013, 03:29 PM | #6 |
I've used rustoleum semigloss black on frame and inner finders, and under the hood for many years with vary good results. I always use the rustoleum rusty metal primer, it used to be called damp proof primer. I use a spray gun. Flat black doesn't clean well, and gloss is to shinny and doesn't touch up well.(MY OPINION ONLY)
09-17-2013, 04:16 PM | #7 |
i'm going to try the majic implement high gloss black. suppose to be really tough paint. haven't picked out an under coating to use i'm looking around at some different brands of bedliner.
1969 Chevy C10 2wd stepside longbox |
09-17-2013, 04:56 PM | #8 |
Well I bought this rust inhibitor in a can from NAPA just now and a NAPA brand of rubberized undercoating, also in a can. I want to spray the frame where my cab mount bushings go and then paint. The undercoating I'll try out on the underside of the inner fenders.
I found a local place for sandblasting and I might get them to clean things up and then me just spray this stuff on. |
09-17-2013, 06:11 PM | #9 |
this is the majic implement paint on my frame horns looks like powder coating very nice finish on it for 12.99 a quart and you can brush it on. just did my battery box and bumper bracket's as well looks really good.
09-17-2013, 06:16 PM | #10 |
Oh boy, that does look nice! I may look into that stuff.
I bought a can of NAPA "Rust Inhibitor" and NAPA "Heavy Duty Rubberized Undercoating." I haven't tried either. |
09-17-2013, 07:31 PM | #11 |
i scuffed them up with a green pad, then used POR-15 on both sides and topcoated with glossy black rustoleum, my whole engine compartment is POR-15 then top coated with rustoleum
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
09-17-2013, 07:40 PM | #12 |
WreckedChevy did you brush that on your frame horns looks really nice,Brian
1971 c10 custom deluxe fleetside swb LS3 w/BTR stage IV cam,4L85E w/3600 stall 67-72chevytrucks.com/vboard/showthread.php?t=558024 |
09-17-2013, 08:17 PM | #13 | |
Be sure to wire brush and or sand as much as you can forts. Be sure to post a pic of the undercoating if ya would.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
09-17-2013, 08:20 PM | #14 |
I used a product called rocker guard, IDK is it's still available but 18 years and 78,000 miles later it is still great.
It takes a beating from rock thrown by the tires.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
09-17-2013, 08:22 PM | #15 | |
I am still in the air about powder coating my inner fenders but will probably just use Rust Inhibitor and spray paint the tops and Undercoat the bottoms. |
09-17-2013, 08:47 PM | #16 |
Wreckedchevy where do you buy it? Looks 2 good to pass up.
09-17-2013, 09:34 PM | #17 |
My plan is to powder coat them and then Camoliner the underside to a semi-gloss finish. The rest of the underside will be Camoliner in body color.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
09-17-2013, 10:03 PM | #18 | |
Where did you buy that paint....cant seem to find black? |
09-17-2013, 10:29 PM | #19 |
Tractor Supply I believe carries the Majic brand of paint
09-17-2013, 10:30 PM | #20 |
09-18-2013, 12:11 AM | #21 |
yea I lightly wire wheeled the frame horns spayed them with the majic red oxide primer. then (the wife) brushed on the high gloss black with a $.99 cent foam brush.
09-18-2013, 12:12 AM | #22 |
09-18-2013, 03:34 AM | #23 |
US Army Veteran
Chassis Coat by POR-15. Lined the bottom of my '78 with it. Tough as rocks.
1972 C10 Highlander - The making of a daily driver |
09-18-2013, 03:44 AM | #24 |
Apparently, there are several ways to reach the same result! In fact, I've gotten so many replies and product reviews, I'm more confused than ever as to what to try! :-)
09-18-2013, 07:16 AM | #25 |
well i would go with what ever you can afford, the great things about our trucks, are if it dosent look good , you can always strip and redo with another product
