09-12-2013, 01:15 AM | #1 |
Need a quick favour from those of you who own centerline smoothies
Need a quick measurement from a set of centerline smoothies from the back (wheel mounting surface) to the outer most part of the CENTER area of the wheel. Not to the lip, but where some of you are mounting your clips for the centre caps.
My curiosity lies with how much room do I have to hide a hub assembly between the two areas. Anyone able to help a guy out next time you have a wheel off would be appreciated. That and if anyone has pics of a set of 20x10's or 20x12's would be great as well, and thanks in advance!
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s 1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater 1963 C10 reg cab long box 1970 Chevelle 1968 Biscayne 2dr post "...there is no excuse for what I am about to do, but dangit....it's gonna be fun!" |
09-13-2013, 07:38 AM | #2 |
67-72 parts collector,…
Re: Need a quick favour from those of you who own centerline smoothies
Anyone?
09-19-2013, 12:53 AM | #3 | |
Posted via Mobile Device |
09-19-2013, 01:09 AM | #4 |
Not sure I want to impose on someone that badly.....don't know him all that well. One of his old trucks (blackbird) is here locally and can ask him or pop over there and check it out to see if he is willing to pull a wheel off. Just figured someone might already have one off...
But thanks for the options though..appreciate it.
09-19-2013, 07:56 AM | #5 |
I think the radius for drilling the holes will depend on the clips you use.
I would practice on an old wheel or something else to get the clip diameter correct, before you drill your new wheels.
