Old 08-08-2013, 06:14 PM   #51
LEEVON
LEEVON's Avatar
Re: Project "Rebound" 2006 RCSB
Originally Posted by 68Stepbed View Post
Check the steering linkage. Mine does the same thing. These trucks were common for the linkage to rattle. A new steering arm set is around $100-130.
Thanks, at first I wondered about that but I quickly realized that it's a plastic box of some kind. If I jamb my foot up there it stops LOL. I did that steering shaft upgrade on my wife's Tahoe and it was like a new truck!
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 08-10-2013, 12:36 AM   #52
LEEVON
LEEVON's Avatar
Got the jump seat mounted. Cheap and easy mod, it bolted right in. The color is different but I suppose I could get Katzkin leather to match. BTW, what the heck is going on with the site's image hosting??? I can't upload anything larger than a nat's ass and it won't accept Imagur links...
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 09-11-2013, 03:33 PM   #53
LEEVON
LEEVON's Avatar
Truck has been fighting me lately. I thought the water pump had been squeaking, plus there is a 3" drip of coolant in the driveway every morning, then it nearly overheated so I replaced the pump (who wouldn't?), gaskets, coolant and a/c belt while I was in there. I have replaced lots of these around the same mileage, they just go bad. Then the squeak came back, which I think now is probably the a/c tensioner as it has gotten rediculous. Or it could be the compressor clutch. So I probably replaced the pump for no reason, and I could still have a bad compressor.
But the winner is the horrible knock/tick I got after a road trip. Sounded like a stuck lifter, but could be something worse. I shut the truck down, checked the oil and it was low. Added 1qt, knock went away. Checked the oil again the next morning and it was still low, so now I'm 2 quarts added. No leaks, or evidence of oil in the coolant (just drained it remember) and the oil was changed 2000 miles ago. Oil consumption issue? Stuck lifter? Low end knock!!!?
Yet somehow the last tank of gas netted 19 mpg after an average over 2500 miles of 15mpg.
Old 09-12-2013, 09:08 AM   #54
468BIGBLOCK
MEMBER OF THE JUNK MAN CLUB
468BIGBLOCK's Avatar
nice truck!
I LIKE 67-72 CHEVYS, I HAVE OWNED OVER 150 OF THEM IN THE LAST 25 YEARS..
468BIGBLOCK is offline   Reply With Quote
Old 09-13-2013, 09:38 AM   #55
LEEVON
LEEVON's Avatar
Thanks, she just needs power window conversion ; ) and to stop complaining!
Old 09-13-2013, 12:25 PM   #56
solidaxel
solidaxel's Avatar
Did you find the source of the "tick"?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-13-2013, 05:38 PM   #57
LEEVON
LEEVON's Avatar
No but seeing that it went away after adding oil, betting a lifter. My wife's 2009 suburban developed a lifter tick on a road trip, wasn't even due for an oil change. We stopped and changed the oil, went away. Same suburban had a lifter fail and wipe out the cam (warranty)
Old 09-18-2013, 11:26 PM   #58
solidaxel
solidaxel's Avatar
It looks like there is a leak in the water pump so I guess a change is in the near future.
Is there a pump that is beter than the stock one or just a oem pump?
LS 3 4L70E
Old 09-19-2013, 12:50 PM   #59
JD'S 69
JD'S 69's Avatar
What size tires are on your true blue. I read the thread but didn't see the size any where. That is a nice looking truck.
When I stand before god at the at the end of my life, I would hope that I would not have a single bit of talent left, and I could say," I used everything you gave me"
My 69 stepper http://67-72chevytrucks.com/vboard/s...d.php?t=601095
JD'S 69 is offline   Reply With Quote
Old 09-20-2013, 12:13 AM   #60
LEEVON
LEEVON's Avatar
The cardone pump I bought was supposed to be reman. However, it didn't have the recess for the factory steel/o-ring gaskets on the block, and the t-stat housing surface leaked immediately. I asked my neighbor who is a factory rep in the parts business, and he said most of the water pumps are made in the same factory in China and re-branded, even AC Delco. The lines he reps to O'Reilly are supposed to be better quality, but that does not include the one I bought.
255/60/15. Thanks!
Old 10-23-2013, 10:27 PM   #61
LEEVON
LEEVON's Avatar
SOLD. Dangit, I need to quit doing this. really.
Old 10-24-2013, 07:43 AM   #62
lolife99
67-72 parts collector,…
lolife99's Avatar
What???
Now what are you buying?
Keith
Convert to disc brakes.
Old 10-24-2013, 08:11 AM   #63
Low Elco
Good Lord, Leevon! What ya gettin' now?
Low Elco is offline   Reply With Quote
Old 10-24-2013, 08:45 PM   #64
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Congrats on the sale.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-26-2013, 12:02 PM   #65
LEEVON
LEEVON's Avatar
What???
I have a new business, and it requires me to get a 2010+ Dodge Durango, plus now I have a little cash infusion to get over the hump on my '50 "Popeye" project.
Thanks, this one didn't really make me sad so I'd say that's a win.
