10-18-2013, 01:25 AM | #1 |
Toe in.
I have been reading a few threads about setting the toe in on a straight axle, pretty straight forward and i have the spec in my manual. I also know that the toe in ideally will move to 0 while at speed.
With what i read nobody mentions if the wheels should be in the air, or on the ground, should you drive forward and stop, then check it with a little road surface tension?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
10-18-2013, 08:01 AM | #2 |
Re: Toe in.
Good questions. I've always done toe-in with truck on all fours. There is basically no camber adjustment,so things that go for independent suspension don't apply here. IIRC,I set toe to 1/8" in. Maybe that's so that with road tension it will be about 0.
10-18-2013, 05:58 PM | #3 |
Re: Toe in.
Thank you special K
10-19-2013, 11:30 AM | #4 | |
Re: Toe in.
There should be some consideration to tire diameter too. Tires that are much larger than original need a bit more toe. An 8th of an inch is fine in the 28"-32" range, but when you get to 35"and over 3/16" or even up to 1/4" for larger than that.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
10-19-2013, 11:48 AM | #5 |
Re: Toe in.
Good point, I'm running 33" BFG's, I guess I'll shoot for 1/8-3/16. Thanks!
10-21-2013, 01:18 AM | #6 |
Re: Toe in.
Longhair is right again. I had 35's on my burb and it drove best with a 1/4" of tow-in. 1/8" still road walked quite a bit.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! |
