08-24-2013, 07:20 PM | #1 |
69 K20
Swapping from 4spd to TH350 issue
I'm making the swap in my 69 K20 from the manual trans and Rockwell to a TH350 with NP205 that I got from a 72. I have the automatic crossmember from the 72 but the trans mount is 2 1/4 inches off from the bracket. Has anyone done this swap? I would guess that the easiest solution is to drill the holes for the bracket into the frame. Am I right or am I missing something?
Posted via Mobile Device Posted via Mobile Device |
08-24-2013, 08:01 PM | #2 |
Re: Swapping from 4spd to TH350 issue
Should be an easy swap. Do you have a 6 cylinder or 8 cylinder engine?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
08-24-2013, 08:11 PM | #3 |
Yup, drill new holes, easy as that.
08-24-2013, 08:20 PM | #4 |
69 K20
It's an 8 cylinder Jim.
Thanks 70-k5. Posted via Mobile Device |
08-24-2013, 10:06 PM | #5 |
You need to drll new holes, because of the Rockwell transfer case to the NP205 conversion. I had to do this on my 69 going from a 4 speed/Rockwell to a 4 speed/NP205. You will a also need different length driveshafts.
11-18-2013, 03:29 PM | #6 |
Will a 454 bolt up to the Rockwell with the 4 speed 4x4?
Does anyone know what changes are needed to make this conversion? We have a 71 GMC and want to put a 454 in place of the 350. Thanks, Willie
1969 GMC 4x4, 4 speed, 350 Fleet Side in progress. 1969 Camaro SS 427 Cortez Silver. owner since 1974 1964 Chevelle 4 Door, 427 Big block,Turbo 400 1/4 Mile 10.52 @ 125.85 mph. 1.39.1 60' 1982 Crew Cab 3+3, 2WD 3.21 Locker, 468/4 speed 1969 C30 4 speed (IL6) future build. |
