![]() Join Date: Jul 2007
power assist steering question
What years do power assist steering fit. I have a unit from a 1967 and it does not seem to fit my 1964 shortbed.
![]() Join Date: Aug 2008
Re: power assist steering question
if are you using the slave unit type . there is a difference from 1/2 to 3/4 larger tie rods ends on 3/4 .
It is a slave unit. Are the frame brackets the same? My steering was from a 67 GMC will they fit a 64 Chevrolet C10?
60-66 Nut
As far as I know, the steering box on a '67 GMC bolts up differently than on a '64 Chevy. The frame bracket bolts up to the same bolts as the steering box.
That seems to be our problem. The steering shaft to the column is longer on the 67.
