12-02-2013, 12:08 AM | #1 |
temp gauge pegged on high
So to begin with this is a project truck that has been sitting for 4 years and I have been chasing down poor grounds and corroded connections with great success so far, we got the engine running and noticed no temp reading and when I checked the sending unit it was broken so today I replaced it with a new one a felker brand and as soon as I turned the key on it went stright to the far right pegged at high, it comes down a 1/4 when its cold then right back up. The engine seems to be running a bit warm but no overheating at idle, new thermostat installed and changed the coolent too, the upper hoses are hot so fluid is moving through the system. Bad gauge? or ? it appears that everything is correctly connected but seems like a ground short. Any ideas??
Scotts72C10 |
12-02-2013, 12:22 AM | #2 |
I built it
Re: temp gauge pegged on high
sounds like the sender is the wrong type for the guage.
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
12-02-2013, 01:32 AM | #3 |
it looks correct for a gauge not a light, how do I tell? Can I test the gauge somehow? NAPA part#TS6469 By Ekhert
Scotts72C10 |
12-02-2013, 01:53 PM | #4 |
most times if the guage is pegged the wire is grounded or the motor is realy hot
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project Last edited by 67swb72klb; 12-02-2013 at 02:00 PM. |
12-02-2013, 02:53 PM | #5 |
Msgt USAF Ret
First off you need to verify if the gauge or the sender is the problem. Here's how.
Unplug the sender and turn the key on, With the wire not touching anything, the gauge should read dead cold, now touch the wire to a good ground and the gauge should go to full hot. If you get those readings then the gauge is good and you need the correct sender. If the gauge continues to read hot with the wire off then the wire might be grounded someplace by being pinched somewhere. If it reads cold then measure the resistance between the sender terminal and the body of the sender for very low resistance. If it reads less than 50 ohms then the sender is bad or it might be for a different year. Also check the resistance of the sender body to the block for very low resistance like 10 ohms or less. You must have low resistance between the sender body and the center terminal for the gauge to read hot and high resistance for it to read cold. If I remember correctly I read that the sender should read 500 ohms on the high end when the temperature should read cold and 200 ohms on the hot side when the temperature heats up. Of course the lower the resistance the hotter the reading. These readings may not be correct but I seem to remember those numbers.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
12-02-2013, 04:53 PM | #6 |
Thanks, I will check those tomorrow and post a follow-up, My guess is that the green wire to the sender is grounded somewhere, its missing most of the insulation on it.
Scotts72C10 |
12-11-2013, 03:34 PM | #7 |
Upate on the sender, so I replaced the heatsheild that covers the sender wire and replaced the wire lead conector and now it works but reads higher that it should, truck is not running that warm and it seems that the heater is too cold but tha is another problem I believe. Where would I get the ceramic resistor to replace the smaller on that is 90ohms? Then I think it will be fine.
Of course now I need to replace the fuel sending unit, it does not wook either, too bad it sat for so long but at least it all will be working when were done. Thanks
Scotts72C10 |
12-12-2013, 01:51 AM | #8 | |
Msgt USAF Ret
as you can see the resistor is about 60 ohms not 90 and I have two clusters with the temperature gauges and they both read near that. Have you read the resistor with an ohm meter? At 90 ohms the gauge will read hotter. I'm puzzled why the ceramic resistor is 90 ohms unless the gauge is for a 195* engine. Are you sure you got the correct sender for the engine?
12-12-2013, 12:51 PM | #9 |
Thanks Vettevet,
Im trying to follow all the suggestions and I have not tried the Ohm meter on the gauge but I will today and see what the reading is, Its the only sender that NAPA showed for the 72C10 with a gauge and this cluster was one that was not installed when we bought the truck as a project so I dont know what truck it had been in a 6 or 8 or even what year, just trying to sort it all out. Thanks for all your help, with it I have solved most of the issues and am leaning along the way. Ill post a update.
Scotts72C10 |
12-12-2013, 01:29 PM | #10 |
So with my ohm meter I get 44.8 post to post on the temp and 36.4 on the resistor granted I was upside down with a flashlight in my mouth and balancing the meter on my chest but I think I got it
Scotts72C10 |
06-18-2020, 05:44 AM | #11 |
So having the same trouble as the subject line, i ran the test as per post 5 and determined that i need a proper sending unit. BUT now the needle wont come off of pegged, even after i disconnect the battery!
Any thoughts or suggestions? |
06-18-2020, 09:28 AM | #12 |
Temperture gauge is pegged on high
As described in this forum some time ago, i disconnected the lead at the sending unit,turned the key on and the gauge read cold. This is qood. Then i grounded the lead and it pegged the temperture on hot. This is good because it tells me i have the wrong sending unit.
The problem now is the the gauge has remaimed on hot even after i disconnected the battery. Without power why does the gauge remain on hot? Help! |
06-18-2020, 09:38 AM | #13 | |
Msgt USAF Ret
The gauge will read at it's last point when power is removed so that is normal.
06-18-2020, 09:49 AM | #14 |
Hey VetteVet,
It is pegged on high. So if I hook the lead back up and connect the battery and turn the key on (not running the engine), the gauge should drop to cold since the engine has not been running, but the needle still sits on hot. Maybe I have to start the engine to get the needle to drop? I'm not sure. BTW, it was your thread that helped me to sort out the sending unit vs the gauge. Thanks for that advise. |
06-18-2020, 10:10 AM | #15 | |
Msgt USAF Ret
Re: Temperture gauge is pegged on high
Try reconnecting the battery and removing the sending wire without touching anything with it and the gauge should read full cold.
06-18-2020, 10:14 AM | #16 |
I tried that. Unfortunately the needle is still pegged on hot.
06-18-2020, 10:18 AM | #17 |
BTW, this all started after an engine swap, the temp gauge was constantly pegged. Prior to the swap the temp gauge worked just fine. Not sure how I managed to get the gauge to fall to cold during the testing but now again it is pegged on hot.
06-18-2020, 05:08 PM | #18 |
Already stated
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 06-18-2020 at 05:11 PM. Reason: Already stated answer |
06-18-2020, 06:49 PM | #19 |
The threads are the ground for the sensor. No tape and the gage will need a proper ground. I hope that helps and it may not.
06-18-2020, 09:12 PM | #20 |
What was it like before you touched the wire to ground? With the engine running and at normal operating temperature, did the gauge read cold all the time? I was just wondering what caused you to want to take loose the sending unit wire in the first place. I suppose you could have damaged the gauge, but I'm thinking they are normally pretty tough. If you connect the wire back to the sending unit on the engine and start up the engine, what does the gauge read now?
You can test the sender by using an ohm meter connected between bare metal somewhere on the engine, and the sending unit terminal. How many ohms do you get whit the engine cold, and how many when warmed up? |
06-18-2020, 11:57 PM | #21 | |
Msgt USAF Ret
I believe the range is 500 ohms when cold and 200 when the engine heats up.
06-19-2020, 01:14 AM | #22 |
I will give give it a try. So far I checked the ohmage cold and I got 450 ohms, pretty close to the 500 you mentioned. Tomorrow I will get it good and warm and see what I get. I will let you.
Thanks for sharing. |
06-19-2020, 01:38 AM | #23 |
Typically it has been pegged on hot ever since I did an engine swap. Before that the gauge worked just fine. I was hoping to resolve the issue when I put in my tachometer conversion kit as it came with a new electrical contact sheet for the back of the instrument cluster. During the course on installing the cluster I somehow managed to get the gauge to read cold, so that is when I decided to try testing as per VetteVet suggestions. They make sense. When I got to grounding the sending unit the gauge pegged to hot (as it should have) but now it will not come off of hot, even with the batter disconnected, the sending unit disconnected.
I understand the gauges on these trucks simply freeze themselves wherever they were when the engine is shut off, but the engine has been stone cold. At this point I got 450 ohms with a cold engine. I will measure the ohms tomorrow after warming it up. I will be starting it up tomorrow and let you know how it goes. Thanks |
06-19-2020, 08:55 PM | #24 |
I took it for a spin today and got nice and warm then checked the ohms and got 350. I expected less than that but for today that is what it was.
As per post #8 above, i'm going to check the ohms on the gauge it self and see what I get. Thought/comments are welcome. |
06-19-2020, 09:12 PM | #25 |
After the engine was nice and warm I measured 350 ohms on the temperature sender. Thought it would be more. At this point I will check the ohms on the temp gauge it self and see what I get.
Its a struggle. |
