Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 10-22-2012, 08:32 PM   #176
donut
donut's Avatar
Re: The Good, The Bad and Ugly from Harbor Freight
I've got a few HF tools, some good, some not.
Wrenches and sockets have held up well. Ratchets, hit or miss.
What I won't recommend to anyone is the 3/8" drive impact. Read the reviews at HF and believe them. I actually used mine for about a month. When it spit the socket twice in 20 minutes (last time socket flew about 35 feet) I was mad enough that I financed a gun off of the tool truck. (truck was sitting there when all this went down).
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 10-22-2012, 09:23 PM   #177
MadManAndrew
I bought a set of socket drive adapters from Harbor Freight and they've all twisted off the very first time I've used them. I also bought a cut-off wheel and it's great though.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 10-22-2012, 10:22 PM   #178
71K20chevy
71K20chevy's Avatar
I tried my SAE ratcheting wrenches ($26.99) today, they worked great. Definitely handy for tight areas. I put strain on them and none of them broke.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 02-08-2013, 06:14 PM   #179
chillware
I bought their CO2/Argon Regulator Gauge on sale + 20% coupon = $25. It works great on my 25/75 co2/ar bottle.
http://www.harborfreight.com/regulator-gauge-94841.html
My build thread: '66 Chevy
chillware is offline   Reply With Quote
Old 02-10-2013, 03:56 AM   #180
donthekawguy
donthekawguy's Avatar
My GF got me a 20 gallon compressor 3 years ago and it has worked great. No problems at all. In 1996 I picked up a pretty big tool set from Fingerhut of all places. I have yet to break a ratchet, socket or wrench. They are mastercraft brand made in China. I guess China used better steel back then.
66 shorty
donthekawguy is offline   Reply With Quote
Old 02-14-2013, 11:25 AM   #181
truckster
truckster's Avatar
I'll jump in.
Good:
20 ton press
Transmission Jack
Soldering gun
Ratchet extensions
Heat shrink tube
Bearing separator plate
Bug zapper
Bungee cords
Useable, but not great:
Sand blaster (I think it's a 50 lb)
Die grinder (uses a lot of air and doesn't grind much. Maybe it's not so useable after all.)
Bad:
Pitman arm separator (cracked on first use)
Exhaust tubing spreader (stripped threads on first use)
4" grinder (first one lasted 2 hours; replacement lasted 10 minutes)
Impact wrenches (what good is an impact if you have to use a breaker bar first?)
Band clamps (worm drive type)
That's all I can think of right now.
truckster is online now   Reply With Quote
Old 02-14-2013, 11:48 AM   #182
Lattimer
Lattimer's Avatar
I've had good and bad with them.
Good:
I actually have a 4" angle grinder I've beat the crap out of for over 10 years that still works great.
Earthquake impact gun has worked well for many years
Offset box end wrenches----don't use them a lot, but have been handy and no issues
Heat gun---got it on sale for like $9 and it works great
Heat shrink tubing---cheap and works great
meh
Manual tire changer----had to re-weld it in a bunch of places, works good now. Mostly use for motorcycle tires
Hardware----some of the sheetmetal screws and stuff are ok, some are not
Pipe threader---just barely ok
Sockets---just ok
Electric cut off tool---works ok but trips out easy. Have to keep resetting it.
Bad
Screwdrivers
Flashlights
Haven't tried much else.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 02-17-2013, 10:13 PM   #183
hjewell2
hjewell2's Avatar
Originally Posted by blitz'd View Post
One item to avoid is thier air powered trim nailer, it jammed on me last weekend several times and screwed up some expensive trim when it miss fired a few times. It met my mini sledge to it after about 2 hours of messing with it. I could have returned it but at that point it was worth the $29 to relieve my frustrations on it. LOL.
Hey I did the same thing with a weed whacker made by Brand name TORO from HF.
I had it about 7 yrs it ran great but the spool was a piece of ####.Anyway one day in a hurry and very hot outside it tried to use it, of course spool messed up. The guy next door was laughing so hard my wife was in tears. I smashed the s*** out of it right in the front yard. oh we still laugh to this day about it. The guy next door said he would never ever get me mad after watching that episode, of course he steers clear from the barn out back at times also.
hjewell2 is offline   Reply With Quote
Old 12-04-2013, 11:34 AM   #184
71K20chevy
71K20chevy's Avatar
I've found that the quick setting epoxy seems to hold better than JB weld...
71 K20
64 GMC mud truck
Old 12-05-2013, 01:13 AM   #185
ole dollor
ole dollor's Avatar
a few weeks back I bought the $40.00 HVLP paint gun... it works great.
ole dollor is offline   Reply With Quote
Old 12-05-2013, 01:52 PM   #186
NONHOG
NONHOG's Avatar
Happy (so far) with this.... http://www.harborfreight.com/18-gaug...ear-92148.html
Cuts pretty clean, fairly easy cuts.
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 12-08-2013, 02:44 AM   #187
Mr-Jack
Beer Drink'n Knuckle Dragger
Mr-Jack's Avatar
that work on stainless?
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US
- 67 GMC Long-Wide 350/SM420
My BACON Wrapped Meatloaf Recipe
Mr-Jack is offline   Reply With Quote
Old 12-08-2013, 03:31 PM   #188
dirtyjim
dirtyjim's Avatar
their ratcheting crimpers Central-Forge - item#97420 also work well once you get the tension adjusted right. just make sure you put the terminal in the correct direction, the wire needs to feed in from the side of the crimper with the three colored dots. accel spark plug crimping heads also fit.
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 01-18-2014, 02:52 PM   #189
meatwagon83
meatwagon83's Avatar
Originally Posted by blime81 View Post
Here's another
Good
Heavy duty 36" pry bar $9
Worked great to help "assist" removing a crossmember after I got the rivets out.
i had a prybar from there and as soon as i put some ass to it it broke!! the onlly time i have even seen a prybar break!!
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 01-20-2014, 03:25 PM   #190
MadManAndrew
Originally Posted by FrankieD View Post
My cousin had to turn his 36yro Snap On tool box so I told him to look at the 54" one at HF he ended up buying it he said it is 3X better than the Snap On box I have the 44" bottom box makes the Craftsman box look like a tin can
Biught the $20 sand blasting helmet works great
My dad has that 54" box and I'd have to agree. It's a quality unit. If you google the brand they're actually an old American company with a great reputation. I think it's American General or something like that. Definitely nicer than my Craftsman box.
Old 01-20-2014, 03:46 PM   #191
Fatherof3
Fatherof3's Avatar
Bought one of their cars, didn't work out so good
65 C20 292 4spd 4:56 Eaton HO52
Fatherof3 is offline   Reply With Quote
Old 02-18-2014, 08:28 PM   #192
midniteblues
midniteblues's Avatar
some items are hit an miss
i bought both sets(standard&metric) of 1/2" dr impact sockets a few years ago they are awesome for the price.
then i got both sets of 3/4" dr sockets and broke one the first time useing it.
I try too stay away from the power tools there.
but i got two items i have my eye on and i'm looking for some feedback on them.
the retractable air/water hose reel with 50' hose. lot #93897/69265 i can imagine the hose is crap but i'm curious about the spring in the retractor does it last?
and there
5lb.vibrator/tumbler lot#67617
of course i'm lookin at this too clean nuts&bolts blastin them is a pain
oh an i've gotten there industreal air compessor filter/regulator and the reg blows the diaphram in a few weeks(i've had two) the filter...its better than nothing.
just curious if anybody has these two items?
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 02-18-2014, 11:36 PM   #193
Kim57
Kim57's Avatar
I've had the retractable air hose for years.
Can't complain one bit about it.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-19-2014, 06:19 AM   #194
midniteblues
Kim
great thanks kim57
Old 02-19-2014, 06:34 AM   #195
As you mentioned in your initial post, the hose in mine started cracking/drying/leaking out after about 2 years (I think may have been closer to 3). I replaced it with another hose and it is good to go again. I can't complain though, and the reel works great.
Old 02-19-2014, 09:02 PM   #196
midniteblues
2-3 years isnt bad though for a hf tool.
i had gotten a manual hose reel from there years ago its been holding up just fine after rewelding the handle back on. i use that one too reach outside.
picking up an coiling air hose just becomes a pita all the time.
