![]() Join Date: Nov 2013
My 1985 K30 build, swapping original c20 to K30
I bought a 1985 c20 all original truck with a 454 in it and 98k miles, the truck had a camper in it most of its life which actually preserved the truck. And prevented it from being driven in the Iowa salt. I got this truck for a donor body to go onto a 1984 K30 that was shot.
Heres a few pics of when i got the c20 when i got it. Heres the c20 pulling home my K30 The Rats nest i found in the cab i had to clean out before attempting to remove column and pedals. |
Re: My 1985 K30 build, swapping original c20 to K30
Removing the column and the cab
Forgot to mention that the K30 is an original 454 4spd truck.
Worked a little today on it removing bad brake lines. Picture of the Cab lights installed last weekend. |
![]() Join Date: Oct 2006
454,4spd,np205 K30......
![]() Jealousy is setting in BAD! Nice truck! looks like you're doing a great job!
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
Make sure you cut the trans tunnel out of the 4x4 cab its taller on a 4x4 vs a 2wd.
I've seen your posts here before and i'm so jealous of how clean your truck is. I'm not that far away i live over in ottumwa.
Rust is better than rice. ![]() |
I saved my 4x4 cab for that reason and other parts i may run into, I'll have to try and salvage the hump because it seems to have sustained an incedent causing the rh side to be dented in. If i cant use it ill just junk yard search for another.
I'm currently attempting to clean my frame to be painted. I do have a few questions if anyone could help me out. I would like to know what is the most efficient way of cleaning a frame, without sandblasting? And after cleaning whats the best paint to use keep in mind its not going to be a "Show Truck" just a nice driver that can go to car shows and still be used as a truck.
Yea truck shopping around here is a completely different ball game, i lucked out with my find. And thanks I wasn't crazy about the color at first but it's really grown on me since.
#13 | |
#14 | |
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
#15 |
Ephesians 2:8
You will really like this once your done! I'm looking for a clean 73-80 to do the same with.
72 Suburban making it mine My 79 C10 story 79 C10 LS swap 94 LS swapped Daily Driver Tahoe Limited Instagram - @piersonclassics 83 K20 Farm Truck Build |
#16 |
What are you going to do with your old frame? I've been wanting to turn my c10 into a c20 for awhile.
#17 |
I just used a wire wheel on a grinder and cleaned mine up after power washing all the gunk off, then burch painted it with por15 and then top coated it with duplicolor acrylic enamel semi gloss black spray paint for uniform finish on my dually
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
#18 |
Had not yet made plans for the old frame means my c20 is currently running driving shape the frame wont be available till i get swap done. I however would like to sell it when im done and would be happier it goes to good use, The frame is in great shape with most of its original paint still on it.
#19 |
I might be interested in when you finish the swap i'm not a big rush to do my swap.
#20 |
I'm planning on ordering my lift kit next week and I know i want to go with a 6 inch, originally i planned on a Rough Country but am considering SkyJacker. Does anyone have any input on which would be better? I assume SkyJacker means its a few hundred extra, but is it worth the extra money?
#21 |
i would put the other body and on the 2wd frame and resell it. its not that bad of truck to me.
#22 | |
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 ![]() |
#23 | |
#24 |
It was pretty bad there wasnt a straight panel on it, I fell thru box floor It had been a rat/mouse nest so long none of the wiring was any good and even if you could get past all that the smell was so terrible no one would ever wanna drive it lol. Besides i only have the cab left of its body the rest went to scrap.
#25 |
i've had a blazer and a suburban both with skyjacker lifts and both were excellent as far as ride and for off roading.my blazer had 8'' lift and my suburban had 6'' lift [bought suburban already lifted].but imo skyjacker is a better lift.my suburban road like a cadillac down the road,blazer had a nice ride also.
