Old 12-09-2013, 12:54 PM   #1
Elliot949
Elliot949's Avatar
Looking for a No Spin Sticker
I am looking for the No Spin differential Sticker that goes inside the cab behind the drivers seat... it looks like this or can someone duplicate this Sticker/decal
Elliot949 is offline   Reply With Quote
Old 12-09-2013, 07:05 PM   #2
fisherman56
fisherman56's Avatar
Re: Looking for a No Spin Sticker
Yours is behind seat? Mine is above drivers door. Yea I am wondering too were to get one becuz when I start my resto I will have to remove it, too hard to paint around.
fisherman56 is offline   Reply With Quote
Old 12-09-2013, 07:47 PM   #3
Elliot949
Elliot949's Avatar
I had a bear of a time getting the Sticker off without tearing it... Someone should be able to reprint one from this... Just not sure who...
Old 12-09-2013, 08:36 PM   #4
nightmare
nightmare's Avatar
I'd like to know where to get one too
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 12-09-2013, 08:40 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
I think it would be pretty hard with the foil background...
LockDoc
Leon
Old 12-09-2013, 08:52 PM   #6
Elliot949
Elliot949's Avatar
Well they did it once.. surely it can be done again...
Old 12-09-2013, 10:08 PM   #7
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The foil is doable. Here's an example of the 1972 aux fuel tank decals I reproduced as compared with an OEM example:
Old 12-09-2013, 10:12 PM   #8
67ctener
67ctener's Avatar
I would also like to find one of those
67ctener is offline   Reply With Quote
Old 12-09-2013, 10:18 PM   #9
LockDoc
LockDoc's Avatar
No doubt about that if price is no object...... You might contact DeadheadNM (Pete). He had the Aux fuel tank decals made and they have a foil background. He indicated that they were very pricey to do and they are smaller than the no-spin...
Edit: I type way to slow... Or Pete types too fast
LockDoc
Leon
Old 12-09-2013, 11:16 PM   #10
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Leon is correct - the minimum order I had to place for these made the run cost ~$275. I'm still in the hole actually but it was fun.
Old 12-10-2013, 12:57 PM   #11
flyingtim01
I'd be in for one too, if someone found a source...
1971 Chevy K20 350/SM465/NP205
flyingtim01 is offline   Reply With Quote
Old 12-10-2013, 06:57 PM   #12
Elliot949
Elliot949's Avatar
What kind of source did you use to do this...
Old 12-10-2013, 07:32 PM   #13
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
One more factor is the No Spins are two color with a couple of font sizes....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 12-10-2013, 10:02 PM   #14
DeadheadNM
Carpe manana
DeadheadNM's Avatar
PM sent
Old 04-02-2014, 07:51 AM   #15
Elliot949
Elliot949's Avatar
Can somebody reproduce this???
Old 04-02-2014, 08:37 AM   #16
westong
Mine was on the radio delete
westong is offline   Reply With Quote
Old 04-09-2014, 10:38 PM   #17
LockDoc
LockDoc's Avatar
OK guys, I may have come up with something on this. It is almost impossible to take a picture of it because of the reflection. I will try again tomorrow in the natural light.
I am going to send one of them to Dan to check out since he is the one that started this thread. He can post his thoughts on it here. I put an adhesive back on it as well as laminating the front. I do have a lot of hours in the project and I do not have a magic wand to mass produce them. I can print multiples but applying the adhesive backing and laminate front is a one at a time process.
Please do not post that you want one here. Once Dan has a chance to look it over and give it a thumbs up or down I will post a thread in the classified forum and update this thread, or not.... ..
LockDoc
Leon
Old 04-09-2014, 10:44 PM   #18
BADAZ chevy guy
BADAZ chevy guy's Avatar
Just about any good sign shop can make those. I worked at one in Colorado Springs for a while and they use to make all sorts of stickers on foil background.
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline   Reply With Quote
Old 04-09-2014, 10:50 PM   #19
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Leon - thanks for your effort on this.
Old 04-09-2014, 10:55 PM   #20
LockDoc
LockDoc's Avatar
We know that. Have you read the whole thread? DeadheadNM had some AUX TANK labels made and it was pretty expensive. He said he is still in the hole on his project... I'm not looking to put myself in that position. Thanks for your input though.
LockDoc
Leon
Old 04-09-2014, 10:58 PM   #21
LockDoc
LockDoc's Avatar
Thanks Pete. I think they look a lot better in the flesh. The picture makes it look pretty washed out.
LockDoc
Leon
Old 04-10-2014, 08:21 AM   #22
Elliot949
Elliot949's Avatar
Leon... Looks real good from the picture... I will let you know once it gets here... Only thing that looks a little off in the picture is the KS-10 looks like it needs to be more Bold Print... But overall it looks AWESOME!!!... Guys I will be in contact with Leon over this just as soon as it gets here but I have no reason to believe that this will be any less quality than the lock sets he sells... People that work in perfection tend to do everything with the same level of perfection... Dan
Old 04-10-2014, 08:59 AM   #23
I have an unused one. They didn't come installed,but were in the glovebox packet. I'm not sure mine is the correct model#,it's been a while since I've had it in my hand. But,I considered having these made by my sign shop buddy. The problem is the model#. A K/10 with require a different sticker from a K/20. I would have the K/20s done because that's the factory device they came with.
Old 04-10-2014, 09:11 AM   #24
LockDoc
LockDoc's Avatar
Thanks Dan,
As soon as the P.O. opens it will be on it's way. Please post any differences you find here, after you check it with your original. The hardest part was trying to find fonts that matched the original ones.
LockDoc
Leon
Old 04-10-2014, 09:14 AM   #25
LockDoc
LockDoc's Avatar
Hi Tim,
It wouldn't be that hard to change the 10 to a 20 on these. It would just take a little time. Thanks for your input.
LockDoc
Leon
