Re: LSx Lessons Learned.
i think the biggest trend is to make sure the engine/trans/ecm is out of the same vehicle.... most problems i have seen is because trans/motor/ecm were from different years and thats when the problems started.
Ed will be known as the Tiger Woods of the integration business |
meowMEOWmeowMEOW
lol. Hence why I specified beer. I wouldn't have accomplished anything in the last 12 years without herbal encouragement. Everytime I start drinking in the garage, I have to pee before I get anything done, and when I get back...I forgot what I was doing before l left.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Hey all, Here is a helpful part number list and location to buy that really helped me. I got it from board member Glock.
![]() ![]() I hope this helps others as well. |
I posted a similar list on my build thread. I'll see if I can post it here too...
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
![]() Join Date: Jul 2012
to the top
![]() Join Date: Apr 2005
Build your air intake or pick whatever breather/intake tube you are going to use BEFORE you have your motor tuned.....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Sub'd for future reference!
![]() Join Date: Apr 2010
Subscribed
Wade |
Just as an FYI because the original post mentions it, but you can almost always find coupon codes for ALLDATADIY. Most of the time you can get it 50% off or better for a few month or year subscription for a vehicle.
Just Google ALLDATADIY coupon code and the first few hits usually have good ones. |
Bump...Just starting my collection of items and the lists mentioned are great---thanks
GOD BLESS AMERICA! |
![]() Join Date: Dec 2013
anyone know the physical positioning differences between the cpp sliders......standard and low ac mount style?
![]() Join Date: Sep 2014
Is the engine and tranny year match the same on the 4l60e trannys the same as the 4l80e ones? I already picked up a 4.8l from a 2000 truck but no tranny, so now I'm on the search for a 4l60e. I know that it should be out of a 2000 + and 2wd but didn't know about matching the year, defiantly makes it harder to find the right tranny.
Thanks, Rich |
#13 | |
'07 & '08 4L60E's from behind Gen IV engines will work with a Internal Harness swap (Using a '03-'06 harness). In '09 the 3-2 downshift solenoid was eliminated, Will not work with your set-up. 4L60E production stopped soon after this. |
#14 | |
How about using a 4l60e from a v6 vehicle? Rich |
#15 |
If you don't have V8 mounts to begin with, just slam it as far back as you can. It'll make setting up a cooling fan a lot easier.
If you are going to mod your own wiring, two steps: One, pick your computer location first. Two, giving yourself enough reach from engine to computer, cut / solder / stretch / shorten your wires with the engine & trans out of the truck & on a pallet. It *sucks* trying to make it lay flat & look good while it's in the truck and you can't reach much.
"Over my head" 1957 Chevy 3200, big rear window & 6 lug. Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina. |
#16 |
meowMEOWmeowMEOW
Input shafts are different, so that and the convertor would need to be changed. At that point its better just to source the correct trans.
#17 |
Thanks.
