Old 01-18-2014, 04:36 PM   #1
Djstvns
Tubular A Arms
What brand of tubular A Arms do you recommend for a 69 C10? CPP, DJM, POL, or Porter's?
Djstvns is offline   Reply With Quote
Old 01-18-2014, 10:21 PM   #2
mooseknuckles
mooseknuckles's Avatar
Re: Tubular A Arms
ride tech..
mooseknuckles is offline   Reply With Quote
Old 01-18-2014, 10:50 PM   #3
78f1hundo
Re: Tubular A Arms
Porterbuilt!!!!
65' Chevy C-10 Shortbox
78f1hundo is offline   Reply With Quote
Old 01-18-2014, 11:06 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Tubular A Arms
Bags, coils springs, or coilovers?
DJM shouldn't even be on your list.
Keith
Convert to disc brakes.
Old 01-19-2014, 11:53 AM   #5
Djstvns
Re: Tubular A Arms
Thanks for the heads up! After talking to a couple of other people, I'm gonna go with Porterbuilts.
Old 01-19-2014, 03:15 PM   #6
Dano69c10
Dano69c10's Avatar
Re: Tubular A Arms
I'm pretty sure PB's are the only tubular CA's that will center your front wheel in the fender...
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 01-24-2014, 11:04 AM   #7
knomadd
knomadd's Avatar
Re: Tubular A Arms
Assuming you purchase their 1" forward series control arms. I've got their 1" forward lowers on mine and it's not a full inch since I don't have the uppers, but the wheels are much closer to centered.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 01-24-2014, 11:57 AM   #8
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
Re: Tubular A Arms
Hotchkis arms also do this:
http://www.hotchkis.net/6372_c10_tub...trol_arms.html
chevyguy_72 is offline   Reply With Quote
Old 01-24-2014, 02:03 PM   #9
SCOTI
SCOTI's Avatar
Re: Tubular A Arms
Originally Posted by chevyguy_72 View Post
Yep... but @ a significant cost increase.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-24-2014, 07:01 PM   #10
65Gregg
65Gregg's Avatar
Re: Tubular A Arms
Scoti, you are a master of the understated.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 01-24-2014, 07:24 PM   #11
SCOTI
SCOTI's Avatar
Re: Tubular A Arms
I nearly pooped my shorts when I went to purchase their front shock relocation 'kit' (2 tuned Fox shocks + 2 relocation brackets).... only $481.
I already had Bilsteins so I made my own relocation brackets for < $20 in steel.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-24-2014, 07:35 PM   #12
Jonboy
Slots go on anything!
Re: Tubular A Arms
Darn it. the Hotchkis arms won't work on my '74.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 01-24-2014, 07:39 PM   #13
SCOTI
SCOTI's Avatar
Re: Tubular A Arms
Why is that?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-24-2014, 07:43 PM   #14
Jonboy
Re: Tubular A Arms
The website says they only work up to '72. That, and the same website says they are $1800. That's really the main reason.
Old 01-25-2014, 01:42 AM   #15
SCOTI
SCOTI's Avatar
Re: Tubular A Arms
Pre-73 arms will interchange if you really feel the need to drop the coin.... Just tryin to help.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-26-2014, 03:36 PM   #16
Blackpony
Blackpony's Avatar
Re: Tubular A Arms
Why not djm?
Blackpony is offline   Reply With Quote
Old 01-26-2014, 04:24 PM   #17
lolife99
lolife99's Avatar
Re: Tubular A Arms
Originally Posted by Blackpony View Post
Why not djm?
DJM only sells "drop pocket" style a-arms.
This is old technology that can't be combined with drop spindles due to scrubline issues.
It's basically like drilling a hole in your lower a-arm and letting the spring hang out the bottom,... to lower your truck.
This "low hanging pocket" is very close to the ground on lowered trucks.
Have a flat with this combo (and 15" wheels, or short profile tires on bigger wheels),... and you will be riding on the a-arm pocket.
This takes braking away from your front tire.
Look at this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=486090
Keith
Old 01-26-2014, 04:31 PM   #18
lolife99
lolife99's Avatar
Re: Tubular A Arms
DJM a-arms,... don't buy these!
Keith
Old 01-27-2014, 10:49 AM   #19
chevyguy_72
Vintage Evil
Re: Tubular A Arms
That is interesting... especially considering that the crossmember they bolt to are identical and they accept 73-87 drop spindles... Maybe they move the wheel too far forward in the wheel well? So basically it centers it on the older models but actually pushes it off center to the front on the 73-87 models? Just a thought...
And also... anyone interested in buying Hotchkis parts... check out Summit or Jegs or board vendors...(including Hotchkis) they all sell the parts way cheaper then what they are listed on hotchkis site....
http://www.summitracing.com/parts/hss-11390l/overview/ = $1500 and $8 shipping...
Old 01-27-2014, 01:21 PM   #20
SCOTI
SCOTI's Avatar
Re: Tubular A Arms
The Hotchkis arms should work on later trucks if they bolt up to 67-72's; they just most likely haven't been 'validated' under the later trucks. I've swapped 67-72 arms to a post-73 & swapped post-73 arms to a 67-68 so they'll interchange. But even @ $1500 for 2 lower a-arms, that's still pricy unless there are additional benefits beyond what other mfr's a-arms offer that justify the increase.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-27-2014, 01:53 PM   #21
Jonboy
Re: Tubular A Arms
You're a real pal.
Old 01-27-2014, 02:05 PM   #22
SCOTI
SCOTI's Avatar
Re: Tubular A Arms
You're a real pal.
I never realized how easy it is to spend others money (well compared to spending my own coin ).
Personally... I'd do PB's & get all 4 for less than the $1500 for 2 lowers.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-30-2014, 07:51 PM   #23
olrosa
olrosa's Avatar
Re: Tubular A Arms
Porterbuilt, no question
olrosa is offline   Reply With Quote
Old 02-08-2014, 04:22 PM   #24
GEARBOXGARAGE
Re: Tubular A Arms
Actually the Hotchkis arms will work up to '87 even though their website says '63-'72. They come pre-install with '73-'87 ball joints.
This is taken directly from the install sheet: Ball Joint Info: Before you install this product, please verify which front spindles you have. We have designed the upper A-arms to utilize the 73‐87 style spindles. This type of spindle was widely used in disc brake conversions due to its easy interchangeability and readily available replacement parts (e.g. ball joints, tie rods). If you have original 71‐72 style disc brake spindles, you can order ball joints from us to convert the Hotchkis upper a‐arms to work with that spindle.
I used them on my build and was extremely satisfied with the quality. Yes, they are a bit pricey, but I felt you also get more for it as well. The lowers come with HD adjuster sleeves and an updated center link that reduces bump steer. The spring cups have a deeper design to better locate the spring and also include a poly spring isolator and 1/4" shim to fine tune ride height. The uppers have offset cross shafts for a better camber curve and together they provide up to 9Ί of caster and center the wheels in the well. Just my 2cents...
GEARBOXGARAGE is offline   Reply With Quote
Old 02-08-2014, 04:39 PM   #25
lolife99
lolife99's Avatar
Re: Tubular A Arms
That sucks that Hotchkis makes you buy 73-87 arms and then offers to sell you 4 new balljoints that are correct for your truck.
The 60-70 trucks can't just simply swap the outer tie rods like the 71-72 trucks can.
They should sell them bare and include the correct balljoint.
I understand they are trying to hit the "biggest market",... but that info should well known before purchase.
Thanks for adding this info!
Keith
