Old 01-28-2014, 03:36 PM   #1
CST10
CST10's Avatar
Hedman Headers? Any good?
I need a set oh headers for my 70 CST10 with a 454 BBC. Anyone have recommendations on a set that will fit without any body/frame mod's. Someone said the set from lmc would fit just fine.
What do you recommend?
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 01-28-2014, 05:20 PM   #2
Lee H
Lee H's Avatar
Re: Hedman Headers? Any good?
Can't help with your 454. I have Hedman Elites on my 350 and like them a lot, I would buy them again. Nice thick flange, ball & socket collect, ceramic coated, sealed right up.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 01-28-2014, 05:26 PM   #3
68RAT540
I have Hooker Super Competitions with 2 inch primaries and 3 1/2 collector. They fit with no mods, just have to lift truck about 3 foot off ground to install from underneath. They come with really detailed instructions.
68RAT540 is offline   Reply With Quote
Old 01-28-2014, 05:38 PM   #4
CST10
CST10's Avatar
are the hookers long tube style?
MyToys:
Old 01-28-2014, 05:43 PM   #5
68RAT540
yes,long tube and ceramic coated. I
o
yes, long tube and ceramic coated
Old 01-28-2014, 05:48 PM   #6
68RAT540
I run a Tremec, so they should clear your automatic linkage with no issues i would think.
Old 01-28-2014, 06:24 PM   #7
Pro Performance
Pro Performance's Avatar
I like the Hedman's, and they have a few options that are made for the C10's. Are you looking for a long tube or mid length?
Here is a mid length for the C10 w/ a BBC. Btw, we are a Hedman dealer.
Pro Performance is offline   Reply With Quote
Old 01-28-2014, 08:31 PM   #8
CST10
CST10's Avatar
Some recommend mid length for low and mid range power increases. Others say there is no differance between mid and long tubes? Those Hedman's in the picture, does that coating burn off.
Debating between painted or coated? And long Vs mid length?
Any recommendations? What is the advantages and disadvantages of each?
MyToys:
Old 01-28-2014, 09:55 PM   #9
big_al_71
big_al_71's Avatar
Doug thorleys is always my choice//
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-29-2014, 12:02 AM   #10
The Headmans on my '72 fit perfect and are now ten years old with and doing fine
Old 01-29-2014, 01:33 AM   #11
kwmech
My opinion would be to keep the cast irons and run a single 3'' exhaust, more than enough for the street
Old 01-29-2014, 09:37 AM   #12
CST10
CST10's Avatar
Running the ol cast iron manifolds currently with a 2 1/2 out threw some magnaflows with a H pipe. If ya stand by the exhaust pipe you can feel it blowing out about 2 feet away, maybe more.
Kinda wonder if there is much to gain at all with headers compared to the current exhaust system????.
MyToys:
Old 01-29-2014, 11:46 AM   #13
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
If you want the some of the best built headers, you can't go wrong with Sanderson.
http://www.sandersonheaders.com/Sand...y-Pickups.html
TobyArnot is offline   Reply With Quote
Old 01-29-2014, 11:57 AM   #14
Pro Performance
The picture shown is a paint and in my experience, will eventually burn off. I would suggest the coating. It is more money, but nicer in the long run.
As for mid vs. long, it all depends on personal preference. As mentioned, the performance gains are different for each one, the full lengths providing more mid to high power, and the mids offering a little more down low. I just prefer the mid's because of the ability to tuck the exhaust better, and I am not particularly concerned with high RPM power.
Old 01-29-2014, 11:57 AM   #15
c20pickup
had a set of hedmans for my sbc from lmc, fit perfect
c20pickup is offline   Reply With Quote
Old 01-29-2014, 03:42 PM   #16
CST10
CST10's Avatar
So either Sanderson or Hedman's headers seems to be the most recommended brands. The coated sets add so much to the price, but I don't mind spending the $$$$ if the coating holds up long term. I have a set of coated long tubes on my camaro, which over time has started to peel.
MyToys:
Old 01-30-2014, 11:33 AM   #17
I have taken older headers,sandblasted them,THEN sprayed with VHT primer & paint,and it held up remarkably well. The paint that comes on headers will pop off as soon as you run the engine. Paint doesn't do what ceramic coatings claim,but that paint stayed on there after sandblasting. The Hedmans on my '72 I had ceramic coat "primed" only when new because I wanted flat black (and was cheaper). That has held up just fine (since '04).
Old 01-30-2014, 12:09 PM   #18
CST10
CST10's Avatar
I was thinking of using the VHT high temp paint. It should hold up for a few years at least. Several hundred cheaper too. I might go that route.
Special K, is that the set you ordered thru LMC?
MyToys:
Old 01-31-2014, 03:33 PM   #19
ZombieWeinerDog
ZombieWeinerDog's Avatar
i used these. http://www.summitracing.com/parts/ho...1hkr/overview/
1972 longbed- 454
1967 shortbed- 355
ZombieWeinerDog is offline   Reply With Quote
Old 01-31-2014, 05:13 PM   #20
CST10
CST10's Avatar
Those are nice for the price. Thanks for the tip.
MyToys:
Old 01-31-2014, 06:06 PM   #21
ZombiePopper
ZombiePopper's Avatar
100% agree!
The Doug thorleys are long tube, heavy duty suckers!
Won't save much weight between them and stock exhaust manifolds, but they fit like a glove and no leaks, no grinding, no beating them with a hammer.
ZombiePopper is offline   Reply With Quote
Old 02-01-2014, 11:42 AM   #22
Can't remember where I got these headers,but whoever has the best price will sell you the same headers. If you go the VHT route,definitely hit them with the sand blast. That stuff will not "cling" otherwise...nothing will. t least that has been by experience. Even if you have to pay for the sandblast,it's worth it. Just make sure you use someone who will be careful to just hit them lightly. They just need some "texture"
Old 02-01-2014, 11:58 AM   #23
kxmotox247
kxmotox247's Avatar
I've got Hedman's but haven't run them yet. Here's some photos. Part #69170 They look like a really good fit. I bought them plain because I know by the time I get my truck together I would have scratched up a coated set. They tell you that the black coating is not intended to be permanant.
http://www.67-72chevytrucks.com/vboa...4&postcount=33
kxmotox247 is offline   Reply With Quote
Old 02-01-2014, 07:42 PM   #24
CST10
CST10's Avatar
That fit up looks nice. Did you have to notch anything to make them fit?
MyToys:
Old 02-01-2014, 09:39 PM   #25
kxmotox247
kxmotox247's Avatar
I had to clearance my frame for POL's motor mounts since it's a 67'. Driver's side is really close. The passenger side has tons of clearance. It only gets close back at the collector and the toe-board.
