Old 01-28-2014, 10:23 PM   #1
am0254338
Bucket Seats...Are these correct?
Found these on craigslist. Do they look year correct?...i thought they might not be but he claims they are 68-72...i knew someone on here would be able to tell. Thanks ahead of time.
Andy
am0254338 is offline   Reply With Quote
Old 01-28-2014, 10:24 PM   #2
29od1
Re: Bucket Seats...Are these correct?
73+
29od1 is offline   Reply With Quote
Old 01-28-2014, 11:04 PM   #3
SS Tim
SS Tim's Avatar
Key to remember is what you want to do and how expensive they are.
69-75 bucket seat frames are the same.
69-70 uses 69-70 foams and covers.
71-75 seat foams are the same, with 71-72 covers or 73 up
IIRC
the adjusters are 69-72 drivers then 73 up
pass brackets, pickup are 69-72 then 73 up
pass blazer brackets are 69-72 then 73 up
SS Tim is offline   Reply With Quote
Old 01-28-2014, 11:12 PM   #4
tommys72
tommys72's Avatar
I'd have to get you a pic or two Tim, but I found a 67 swb stepper with buddy buckets, i forget exaxtly what the spid says, but it is a cst. owner says they are original buckets....but they look just like these above. So frames and console could be right? Just wrong seats I guess?
Dont mean to jack your thread...found the same exact seats though
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 01-28-2014, 11:26 PM   #5
71swb4x4
71swb4x4's Avatar
Tommy, if the buddy buckets look just like those above they are not original. A lot can happen in 46 years. Buddy buckets are on one frame that holds both seats and the console. They are entirely different from the 73+ seats shown above.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-28-2014, 11:36 PM   #6
tommys72
tommys72's Avatar
Ok...I definitely remember that silver square on the seats
Old 01-28-2014, 11:57 PM   #7
am0254338
So these are not even 71 to 75 seats either correct? Because the top foam on these is not like the 71-72. The 71/72 have a a listing channel all the way around, and are upholstered completely different. I do upholstery and its obvious there not the same in that way. Thought there might have been some seats available in 67-72 somewhere i did not know about. Thanks for the clarification.
Andy
Old 01-29-2014, 12:04 AM   #8
SS Tim
SS Tim's Avatar
Not sure where this is going but 67-68 buddy buckets are completely different as 71swb4x4 said.
Now 67 CST trucks came standard with the buddy buckets and they were optional in 68 on CST and all other trim levels.
Nothing in that picture above would be correct for a 67 or even usable without modifications and duplicating the 69-72 bucket seat installation.
The owner may be seeing buckets on the SPID and seats installed later like the square body seats above and not realize or care they are incorrect.
Old 01-29-2014, 12:38 AM   #9
SS Tim
SS Tim's Avatar
Andy
Looked at the picture again and realized they are not the 73-75 pickup seat.
As you noted they do not have the same foam shape as the 71-72 pickup seats.
Below is a set of 73 seats clearly showing the 71-72 shape under a revised cover.
At this point I'm beginning to think they may be 71-75? G-van seats or even motorhome built takeouts. If they have wood bases then you know they probably came from a motorhome.
Sorry about the confusion by mistaking them for 73-75 stock pickup seats.
Old 01-29-2014, 12:46 AM   #10
too much stuff
Roadtrip!
too much stuff's Avatar
Look like the set i pulled from a 76 gmc pickup. Console also.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
