Old 02-01-2014, 04:30 PM   #1
theredmeadow
shaking! what is it?
So I think I finally found the problem to my truck vibration. It'll start vibrating around 45 subtly but then when I start getting over 55 it gets REALLY bad. I've checked my torque converter/flywheel and it's fine. I started shaking the driveshaft and this is what I found.
WHat do you guys think? What do I need to replace?
Here's a video link
http://youtu.be/sKIlJWftoeQ
theredmeadow is offline   Reply With Quote
Old 02-01-2014, 04:47 PM   #2
geezer#99
geezer#99's Avatar
Re: shaking! what is it?
Pinion bearing.
geezer#99 is online now   Reply With Quote
Old 02-01-2014, 04:55 PM   #3
jjzepplin
jjzepplin's Avatar
Rear-end rebuild. So what gears have you always wanted? Now's the time.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 02-01-2014, 04:57 PM   #4
theredmeadow
does it need to be a rebuild? can't I just replace the pinion bearing?
Old 02-01-2014, 05:15 PM   #5
Elliot949
Elliot949's Avatar
sound like it needs balanced
Elliot949 is offline   Reply With Quote
Old 02-01-2014, 05:16 PM   #6
geezer#99
geezer#99's Avatar
Maybe!
Depends on other damage. Might be pinion is damaged and needs replaced.
Old 02-01-2014, 05:32 PM   #7
theredmeadow
could the pinion bearing be the cause of my vibrations at higher speeds?
Old 02-01-2014, 05:40 PM   #8
geezer#99
geezer#99's Avatar
Yes it could.
Old 02-01-2014, 05:46 PM   #9
theredmeadow
how difficult is it to replace the pinion bearing and seal?
Old 02-01-2014, 05:52 PM   #10
geezer#99
geezer#99's Avatar
Not hard to do if you've done one before.
I'd take it to a pro.
With that much play you might need to replace everything in the rearend.
Pinion, the bearing, the bearing race, the seal, maybe the ring gear too.
The pinion moving that much could have chewed on the ring gear too.
You'll need someone look in there for you.
Find a pro or swap out the whole rearend.
Old 02-01-2014, 05:56 PM   #11
theredmeadow
or could it be the yoke?
Old 02-01-2014, 06:05 PM   #12
imjeff
imjeff's Avatar
The yoke attaches to the pinion gear with a seal and crush sleave between them. The adjustment is made with shims, but the crush sleave is crushed each time. This is the most critical adjustment in your rear end and involves some specialized tools and methods to make sure the gears mesh correctly. I would definitely go to a rear end shop,
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 02-01-2014, 06:06 PM   #13
geezer#99
geezer#99's Avatar
Yoke is attached to the pinion. Pull the driveshaft off and see how much it moves.
Old 02-02-2014, 01:29 AM   #14
theredmeadow
so I bought a used functional used differential. is it easy to replace the axles because this one was a 5 lug and I want to use the 6 lug.
Old 02-02-2014, 02:40 AM   #15
9teen69
9teen69's Avatar
Swapping axles is easy. Go buy a magnet for the c-clips and also replace the axle seals while you are there. AZ rents the seal puller to make it that much easier. Not sure if there is a tutorial here but search Youtube or Google..otherwise know as Skynet.
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
Old 02-02-2014, 02:42 AM   #16
9teen69
9teen69's Avatar
Also a good time to make sure all your wheel studs are in good shape.
Old 02-02-2014, 02:50 AM   #17
theredmeadow
actually one of my wheel stud is broke so I guess I can replace it now!
Old 02-02-2014, 02:53 AM   #18
theredmeadow
are the 70 c10 auto a C-clip style axle?
Old 02-02-2014, 03:28 AM   #19
frank69
The 70 diff should be a c-clip axle, be sure to check axle length, depends when diff was built, some 5bolt and 6 bolt axles are different lengths
frank69 is offline   Reply With Quote
Old 02-02-2014, 04:58 AM   #20
theredmeadow
actually i haven't bought the differential yet. i said i was interested in buying from a craigslist seller. he said it's a 373 gear ratio. i was looking around and from what I'm seeing the 373 is for a manual? I've got an automatic so I'm assuming this won't work for my truck?
Old 02-02-2014, 05:07 AM   #21
theredmeadow
I've got a 1970 c10 with 350 5.7L engine automatic
Old 02-02-2014, 05:09 AM   #22
jjzepplin
jjzepplin's Avatar
Well what have you got for a drive train? Engine - transmission - Daily driver or highway cruiser?
Old 02-02-2014, 05:16 AM   #23
theredmeadow
this is a daily driver that does get onto roads that are 65MPH
Old 02-02-2014, 05:21 AM   #24
jjzepplin
jjzepplin's Avatar
What kind of trans? And what tire size makes a difference too.
Old 02-02-2014, 05:27 AM   #25
theredmeadow
I'm assuming it's the stock trans and could that be a th350? I have 15 inch rims with 235/75/15 tires
