02-14-2014, 03:15 PM | #1 |
Hazards don't work with headlights on
All my lights work but the hazards with headlights on if you cut headlights off they work anyone had this problem
02-14-2014, 03:45 PM | #2 |
1968 gmc hazards dont work with headlights on
all lights work hazards work with headlamp off when i turn them on the hazards stop working anyone had this problem
02-14-2014, 05:08 PM | #3 |
Msgt USAF Ret
Re: 1968 gmc hazards dont work with headlights on
I would check all the battery to frame grounds, and add some if necessary.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
02-14-2014, 05:11 PM | #4 |
I did that and changed the headlight switch it's just when I turn headlights on when they stop working
02-14-2014, 07:29 PM | #5 | |
The Older Generation
Re: Hazards don't work with headlights on
Most problems like that at ground related (or lack of). Read this thread. http://67-72chevytrucks.com/vboard/s....php?p=4200642 LockDoc
02-14-2014, 08:12 PM | #6 |
Msgt USAF Ret
Do the brake and rear turns work when the headlights are on? They use the same filaments as the hazards.
02-24-2014, 05:21 PM | #7 |
I redone all the grounds at turnsignals and still no turnsignal with light on
02-24-2014, 06:00 PM | #8 |
Try a different flasher. The voltage drop may be enough to cause it not to flash.
02-24-2014, 09:20 PM | #9 |
I sanded all the grounds and changed all fuses and bulbs the passenger side turn signal works with lights on but the driver side doesn't work with the headlights on and the flashers work with headlights off and don't when it's on
02-24-2014, 09:28 PM | #10 |
Project Junkie! Fishing Poor!!
Do you have trailer wiring? If so, I suspect thats your problem. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
02-24-2014, 10:07 PM | #11 |
No trailer wiring
02-25-2014, 05:06 PM | #12 |
This is what I have working :
Turnsignals with headlamp off both side front rear Hazards with headlamp off front and rear Parking lights work passenger turnsignal work with headlamp on Don't work: Driver side turn signal with headlamp on front or back Hazards with headlamps on What I've done : Added ground to cab removed all lighting grounds and sanded and cleaned ground to tail light housings replaced flasher relays sanded fuse panel connections and changed all fuses |
03-02-2014, 07:59 AM | #13 |
03-02-2014, 12:46 PM | #14 | |
Do you have ground straps from battery to engine, back of engine to cab, engine to frame, frame to core support, frame to bottom of cab, frame to bed? All ground connections to bare metal? Is the small black ground wire still clipped onto the pinch weld behind the instrument cluster? (It should be on the bottom right hand side) Couple of other things you might check is the bulb socket contacts. I had one that was rotated in the housing once and the socket contacts were shorting out on the base of the bulb. Also, unplug both headlights, turn on the headlight switch and try the turn signals and hazards again to see what happens. Report back. LockDoc.
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-02-2014 at 01:08 PM. |
03-02-2014, 03:46 PM | #15 |
Ok I put a ground from bed to frame I didn't have one there because bed was bolted directly to frame metal on metal contact. I unplugged the headlamps and same problem hazards or driver turnsignals not working with head lights on
03-02-2014, 03:52 PM | #16 |
Ok have another thing I just noticed to ad also I turn the truck off leave headlams on and turn the driver turn signal on the flasher blinks/ clicks and the turn lights come on but don't flash. The hazards still don't work in this situation
03-02-2014, 07:42 PM | #17 | |
What year is your truck? Are the turn signals in the bumper by any chance? LockDoc
03-02-2014, 07:44 PM | #18 |
1968 gmc the lights are in the grill don't have the a bumper on it
03-02-2014, 07:50 PM | #19 |
Corroded headlight switch? It might have power out issues when it's in the headlight on position.
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
03-02-2014, 08:15 PM | #20 |
New headlight switch new dimmer switch and cleaned all the fuse holders
03-02-2014, 08:36 PM | #21 |
I had a similar problem, changing the turn signal switch on the column cured it.
03-02-2014, 08:37 PM | #22 |
I had hooked a new one up and it still done the same thing with the new one but I'll buy another and try it
03-08-2014, 02:35 PM | #23 |
I put a new turnsignal switch in the column and still same probl everything works until I turn headlights on then the driver side turn signals don't work and the hazards don't work if I turn headlight switch off everything goes back to working
03-08-2014, 09:01 PM | #24 | |
I'm out of ideas. I'm still thinking it is ground or connection related though. What do you think of having the thread moved to the electrical forum to see if anyone there can come up with a solution? LockDoc
03-08-2014, 09:05 PM | #25 |
I have one and no one responded
