Re: 61K10 build
Matt--it will be finished when i sell it! Jason--sense i am rebuilding my springs, wasn't thinking about my spring bushings. had a press years ago, left it at a friends when i moved. also some new ft brake backing plates and hardware (newer style shoe adj) hope they fit.
some more pics as the site froze up last post.
1961 chevy K10 my build is------------61K10 build |
Re: 61K10 build
I hear what your saying...I bought a new carb for mine and some new hubcaps. Still having some issues oh well..
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
Re: 61K10 build
Randy---i'm on my way out as age goes--so enjoy! I like the feeling that i accomplished something while working on my tk. Yours is looking good with all the work you have put into it. Good build. Are you missing the old chev?
Re: 61K10 build
Thanks Kimble Yea I am missing the ole chev for the last few yrs I've driven it in the CHRIST-mas parade, The new carb took out the hestitation issue but now it's still not 100%, Think I'm going to check for vacuum leaks around the intake and carb, replace the ole insulator gasket below the carb..I'll have to get me some carb cleaner and start spraying.
Re: 61K10 build
you guy's interested in my front axle gear change? the process of the gear install and spring/shackle rebuild? can post up.
![]() ![]() Join Date: Jul 2002
Re: 61K10 build
I am always interested in things I haven't tried yet.
![]() Join Date: Aug 2008
Re: 61K10 build
More posting, not less!
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
Re: 61K10 build
Well i squeezed it into my shop side of my garage. it's jacked up, and i started to take it apart (again) got some new longer wheel studs in one hub. wanted to know if they fit as i needed more. turned cold here so shops cold (I don't live in LA) crawling around on concrete seams to make the Bud taste better, at least at my age lol! also the old jeep type brake backing plates will be replaced with the newer style adj hardware.
Re: 61K10 build
Looks nice and clean! Stay warm!
Re: 61K10 build
new brake backing plates don't work. Hub wheel studs rub on the wheel cyl as plate is not recessed enough. need about 3/16 to 1/4". On the hunt again for some chevy 64-70 4x4 ft backing plates. Might just go with a open knuckle and be done with it. just pissed at the moment--------------
Re: 61K10 build
Here is some pics of my mock-up of disc brakes on the closed knuckle dana44. (Danw210) did this on his 3/4t dana hd44. It works for the 1/2t axle also. also rebuilt my lesf springs with new bushings. don't buy the bronze bushing from LMC as they are too short, and there u-bolts don't fit either. you can use the big one but the smaller ones are 3" wide but need to be 2-3/4 for the dana axle tubes. I am also using Captianfab's master/booster /hyd clutch plate. will post some more step x step later.
#12 | |
Re: 61K10 build
Re: 61K10 build
Did you just swap all the disk brake parts form the spindles out?
Re: 61K10 build
couple of more----the rear shackles are fine, you can see the difference in the front bushings. to correct this i used a small piece of the old bushing which was in good shape.
#15 |
Re: 61K10 build
Jason---every thing including the spindles out. I figured if it didn't work i would just find an open knuckle d44 and have all new parts for it. the outer stub axle bearing surface needs to be turned down a few thou to fit the later spindle bearings. they have needle bearings instead of the brass bushing. I have some after-market poly bushings to replace the needle-b ones. maybe they could be reamed out some way so i wouldn't have to turn the shafts down? Everything could be put back to org by doing it that way. I guess we will see.
#16 |
Re: 61K10 build
pic of gear set-up. (the red paint was a mark for me, disregard) Not fun at all, very time consuming. new master cyl, one of the calipers with line, booster and Capt-fabs mounting plate. (thanks Capt) don't know if a 9" booster is enough? also clutch master and linkage. adj proportioning valve for the rear.
have to re-do the front brake lines which is the easy part. I have a hyd flaring tool which makes it easy, with professional double flairs. pic of re-built ft springs. have either 2 degree or 4* wedges to give the axle more caster. (hope it gives the steering a little more road feel)
#17 |
Re: 61K10 build
Hey 61K10 in that picture before the springs is that some type of proportioning valve or a line-loc...
#18 |
Re: 61K10 build
Randy--It's a proportioning valve for the rear drum brakes. don't know if i will need it but it will be in the rear line.
#19 |
![]() Join Date: Mar 2011
Re: 61K10 build
Where did you get the after market poly spindle bushings?
63 k20 with cummins 4bt, owned sence 1982 |
#20 |
![]() Join Date: Mar 2013
Re: 61K10 build
Checking in finally. lol Boy have I been missing out. lol New disc brakes...P/B and new leafs...dang. lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#21 |
Re: 61K10 build
TJ--you have enough going on with your own stuff lol!
#22 |
Re: 61K10 build
D-dude---google longfield--or i got them from trail gear. not going to use them, found some bronze bushing to replace them that the id fits my axles.
#23 |
Re: 61K10 build
TJ--the springs where just taken apart cleaned painted and new bushings.. they are worn pretty good, but should be ok for me.
#24 |
![]() Join Date: Oct 2013
Re: 61K10 build
61K10 great description on what you are doing.
I am moving toward doing the same to front and rear spring in 64K10. Was it hard to drive the spring eye shafts out? any special technique, spraying/soaking mine now. May get back to you on where you got your parts if ok, once mine are apart and see what I need. Your lock outs look the same or similar to ones on '64 front axle. Les |
#25 |
Re: 61K10 build
Interested in your thoughts on going to 3.31 gears if I read things right, with SM420 trans. I am in process of deciding which gear ratio to use, as will be rebuilding both front and rear axles soon. Planning to look at 3.08 to 3.73.
Need to look at first and second trans ratios to see what my minimum speed will be in each, e.g. 1500 to 2000 rpms in first and 1000 to 1200 in 2nd. Changed gear in '86 with LY6 over drive 4 speed, from 3.08 to 3.73, because it was to fast in first at idle, minimum speed was 8 to 10 MPH with clutch out. Hard to drive in traffic. Les |
