Old 02-24-2014, 10:36 AM   #1
Magnus-stepper
Unhappy drilled hole in transmission
Like the title say, I managed to drill a hole in the transmisson housing.. Now im frustrating and dont know what to do. The hole is about 7 or 8 mm. I used a 13 mm but it did not go all the way thru.
What to do? Can i use som kind of sealing og press something in there. I dont think much metal got in the hole.
Is there any pressure in there?
Magnus-stepper is offline   Reply With Quote
Old 02-24-2014, 10:38 AM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: drilled hole in transmission
You need to give more info.What kind of transmission?Where is the Hole?Cast iron or aluminum?And most of all,everyone's going to be curious as to how you did it?
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-24-2014, 10:52 AM   #3
Magnus-stepper
Oh i forgot. Its a 350 automatic. The hole is on the top Ca 380 mm from the engine. Aluminium
I was installing the shifter and was drilling a hole for the shifter wire. Everything happend so fast, to much pressure on the drill maybe...?
Im thinking to press a bolt in with sealing on?
Old 02-24-2014, 12:03 PM   #4
1968k10blue
1968k10blue's Avatar
I would say to find someone who can weld aluminum
Austin
2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked)
2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l
1968k10blue is offline   Reply With Quote
Old 02-24-2014, 12:26 PM   #5
hugger6933
Is it in the bellhousing part? Or is it back farther than that?
hugger6933 is offline   Reply With Quote
Old 02-24-2014, 12:35 PM   #6
stepsider
stepsider's Avatar
I would use JB weld. After its sets up run it to a tranny shop & ask them.
stepsider is offline   Reply With Quote
Old 02-24-2014, 12:44 PM   #7
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
380mm back from the engine = 15". He's probably past the bellhousing and into the main body.
Once you get the trans out and locate a welder of aluminum, a good fix would be to find aluminum round stock and open the hole to that size (8mm, 10mm...) Cut a piece maybe 50mm long and locate it so that it's just flush with the inside of the casting (no new material extending into the case). Weld the pin to the case, filling up your drilled area and cut the long part of the pin flush with the outside.
If the case is thick enough to cut at least 3 threads, I might drill and tap to M8x 1.0 or even M8x 0.75 and install a short bolt as a plug. JB weld the bolt into place. No welding needed, but not as complete of a fix either.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 02-24-2014, 02:50 PM   #8
Fldawg
Fldawg's Avatar
I would dolike stepsidder said jb weld it see what happens, if it works cheap fix ,if not than theres plenty of turbo 350 out there. good luck
Fldawg is offline   Reply With Quote
Old 02-24-2014, 03:14 PM   #9
solidaxel
solidaxel's Avatar
I have used lead ball flattened to the size of the hole "tapped" it into the hole, and for a bit of insurance you could scuff up the outside around the hole and as suggested cover all with some JB Weld.
I may try to open up a larger hole in the sheet metal floor to get a better shot at sealing the opening.
As mentioned you can always find another 350, or R & R and repair!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-24-2014, 03:30 PM   #10
pwdcougar
pwdcougar's Avatar
Screw in a short bolt or screw with teflon tape?
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 02-24-2014, 03:33 PM   #11
mr48chev
mr48chev's Avatar
Gents, he is in Norway and may not have easy access to a turbo 350 core to get a case like many of us do here.
Magnus-Stepper the best way to fix it is to replace the case. That isn't hard and if the trans was in great shape would only require a few gaskets and some time. You pull the whole inside assembly out of one case and put it in another.
There probably isn't room on the inside to be able to tap the hole with pipe threads and put a pipe plug in the hole but that would be an option along with driving in a plug like the round one suggested and sealing over it with some epoxy or JB weld.
Another option may be to pull the trans, pull the internals out and have the case welded, touch the inside up with a die grinder, clean it up and reassemble it. I think you can get by with just a front pump gasket and a valve body gasket if you don't disturb anything else. We pulled the drive assembly out of a Buick transmisson and put it in my brother's Chevy transmission one time when he was broke and I had a good Buick turbo 350 laying in the corner getting in the way.
The last time I heard the "drilled the hole in the top' story It was a customer who came in the Pontiac dealership I worked in in Waco, TX bringing a car he had sold a few days before bringing it back because the trans had sprung a leak. Yes sir, the person who had bought the car had drilled a hole through the transmission hump to mount some sort of electronic device and had drilled through the top of the trans case. A new trans case and gasket set for that one.
My ongoing truck projects:
Old 02-24-2014, 04:19 PM   #12
Gumby
Gumby's Avatar
Ya know there is already vents holes up in that area, all you did was nearly make a new vent. If it ain't puking fluid out stock vent hole...........
Chevy GMC Trucks Find Of The Day
https://www.facebook.com/ChevyGmcTrucksFindOfTheDay or http://ChevyGMCTrucks.com
Gumby is offline   Reply With Quote
Old 02-24-2014, 04:43 PM   #13
Eddie H.
Eddie H.'s Avatar
I knew a guy who shot a hole in his transmission, but that 30.06 round did considerably more damage than a drill bit would.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 02-24-2014, 05:47 PM   #14
Lattimer
Lattimer's Avatar
JB Weld
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 02-24-2014, 05:58 PM   #15
Wrenchbender Ret
Put a sheet metal screw in it with epocy sealer or RTV.
Wrenchbender Ret is offline   Reply With Quote
Old 02-24-2014, 06:42 PM   #16
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
There you go.^^^ easy fix.
Tom Vogel is offline   Reply With Quote
Old 02-24-2014, 07:09 PM   #17
mmiddle
mmiddle's Avatar
JB Weld! There is no pressure on the case.
The best way would be to weld it back up. The second best is to tap it for a pipe fitting. A lead plug would also be a great fix. But, JB weld is cheap and easy and probably be a semi-permanent fix.
What ever you do... MAKE dang sure it does NOT extend past the wall of the case. Critical internal damage will quickly ensue.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 02-24-2014, 09:22 PM   #18
Carl Spangler
Carl Spangler's Avatar
If the hole "did not go all the way thru" then I would just fill the hole with JBweld. That stuff is crazy strong.
cheers
JohnG
Carl Spangler is offline   Reply With Quote
Old 02-25-2014, 02:29 AM   #19
desertnick69
desertnick69's Avatar
Originally Posted by Lattimer View Post
JB Weld
simple and easy, mixed correctly last a long time!
desertnick69 is offline   Reply With Quote
Old 02-25-2014, 04:04 AM   #20
Magnus-stepper
I put a little metale plate in the hole so the sealing wouldnt go down in the transmission. Now it will sit for a few days and dry up!
Old 02-25-2014, 04:13 AM   #21
solidaxel
solidaxel's Avatar
Mercy, what did you use to cut the floor sheet metal?
LS 3 4L70E
Old 02-25-2014, 04:17 AM   #22
Magnus-stepper
Used a pair of bad metal scissors. The metal wil bend down again, no prob
Old 02-25-2014, 09:40 AM   #23
bigmac73
bigmac73's Avatar
geez brother invest in a good body saw or a cut off tool
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 02-25-2014, 09:45 AM   #24
Gumby
Gumby's Avatar
not like he drilled 100s of holes close to each other, then used a wire cutter to snip the tiny piece left inbetween.
Old 02-25-2014, 05:25 PM   #25
Eddie H.
Eddie H.'s Avatar
If it is available in your area, I would recommend some of the thick JB weld epoxy putty
http://www.jbweld.com/product/j-b-steelstik/
