Old 03-04-2014, 11:27 PM   #1
hotsy
hotsy's Avatar
307 engine, who is keeping ? and why
I recently purchased a 70 c10 lwb with 51,000 org miles,has a 307 with a 3 speed on tree,runs excellent and with low miles iam tempted to leave it in and run it till it dies, has anyone else ever kept their org 307 engine opposed to putting a stronger engine ? I do have a 350 4 bolt with 45,000 miles on a stand and runs good but at the same time I hate to pull a good engine out ...anyone got any input , if you left your 307 in yours lets hear your story.
hotsy is offline   Reply With Quote
Old 03-04-2014, 11:30 PM   #2
In The Ten Ring
Re: 307 engine, who is keeping ? and why
If it runs, why "fix" it?
When I was 18, all I wanted to do was dump my 250 3 ott and get a 327 4 in the floor.
Now, that I'm 39, all I want to do is keep it as close to original as possible. It's not a show truck, it's not a hot rod, and what it has works just fine. The 3 ott is hugely cool and works as a theft resistor since nobody under 25 has ever seen one. Winning! :P
In The Ten Ring is offline   Reply With Quote
Old 03-04-2014, 11:49 PM   #3
dajn
That's great advice. I've had to learn the hard way when trying to "improve" things on vehicles that didn't need it. Usually fueled by alcohol and boredom. If it is isn't broke, don't fix like they say. If you have a lot of money and/or your very mechanically inclined than it's a different story but if your like most of us, don't touch it.
dajn is offline   Reply With Quote
Old 03-04-2014, 11:51 PM   #4
67_C-30
I have a radical idea!
67_C-30's Avatar
There's nothing at all wrong with a good running 307. They are usually pretty decent on fuel and the 3.25" stroke buzzes a little easier with stock gears and no OD. You can change out the stock 4 blade fan and put a clutch fan on it, and the old 307 will feel like its got 20 more HP.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 03-04-2014, 11:54 PM   #5
imjeff
imjeff's Avatar
I ran the stock 307 in my 69 Chevelle driver for 12 or 13 years. It was a great little motor and would twist the tires on demand. Same block as the 327 and 350, just a shorter stroke. Sold the car last summer and the new owner loves it , even with a little blue on start up. Sounded great as well. People used to point at the 307 badging and say "yeah, right". They never believed it was a 307...always suspected I had built a sleeper. If it ain't broke, don't fix it.
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 03-04-2014, 11:57 PM   #6
truckster
truckster's Avatar
Here's another vote for leaving it alone if it works...
UNLESS you plan to haul or tow heavy loads with it. In that case, the 307 might be a little weak.
truckster is offline   Reply With Quote
Old 03-05-2014, 12:19 AM   #7
67_C-30
67_C-30's Avatar
Jeff
No, the 307 is a different block than the 302/327/350. Same stroke as 327, but with a 283 bore (3.875").
My trucks
Old 03-05-2014, 12:57 AM   #8
DBaker
DBaker's Avatar
Still runnin mine in the 68! And i plan on runnin it till it blows up then ill think about a 383. If it runs and works for what you use it for then leave it alone.
DBaker is offline   Reply With Quote
Old 03-05-2014, 06:44 AM   #9
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
A 307 is a very good engine if I had a truck with that low miles and a 307 no way id change it they are very dependable and just tough !
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 03-05-2014, 08:01 AM   #10
hamjet
hamjet's Avatar
Mine has the 307 with 3 OTT also. It survived 40 some years unmollested so I just cant be the one to change it. It has 76000 miles on it and it runs great. Unless your'e looking for H.P. to do wheel stands the little 307 is a great engine. You probably have 373 gears in the rear so it's a peppy setup already. It's a nice looking truck too by the way have fun with it...
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 03-05-2014, 09:30 AM   #11
tommys72
tommys72's Avatar
My dad had a 72 with a 307 3OTT and that motor ran good. I dont want to say it was fast, but for a truck it was quick and it was all original. I always did want that truck
Btw, that color combo is awesome
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 03-05-2014, 09:36 AM   #12
jjzepplin
jjzepplin's Avatar
I have the original 307 from my 1970 4x4 going in my 72 2wd Blazer. I put a new timing chain and freeze plugs and front and rear seal. I have a Holley and aluminum intake for it as well as hei after it proves to run ok. I will then run it till it pukes. I have a 4spd Saginaw and 3.73 geared posi so it should be a blast. They came with nylon timing gears so change that first! Had to clean out the debris from the oil p/u and it was all nylon...
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 03-05-2014, 10:28 AM   #13
ho70
ho70's Avatar
307 is a engine that will run forever. If tellin people it is a 307 and that bothers you, then tell 'em it's a 350. IF you want to race around, then do some mods (headers etc) 307's are respectable engines. they are like a loyal dog. But itis your truck, so only you know what is right for you.
ho70 is offline   Reply With Quote
Old 03-05-2014, 11:00 AM   #14
dmartin1
dmartin1's Avatar
we had a 307 in a 86 shortbed 1/2 ton pickup and that dam thing just would not die. we hauled a huge fifth wheel with it, with quads stood up in the rear and a huge amount of water and gasoline and it just kept running, tranny completely burnt before anything, we abused it for hauling for like 3 years,the carb was crap, none of the vacuum was hooked up correct, ont know if there was a pcv valve, 2" of grease and leaked everything it had,
when we sold it, it was still running like a champ and the guy drove it 150-200 miles to vegas to be restored.
keep the 307,if you wanna do wheelies ditch it, if you wanna drive it id keep the old 307
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 03-05-2014, 02:34 PM   #15
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
It looks like you have a stock original truck and for my thinking you shoukd be asking yourself what you want from the truck. That 307 ( as has been said already ) will run and run and if its anything like the one I had in a 69 I bought you could put a glass of water on te engine when it running and there'd be no ripples, that is how smooth they run. If you just bought the truck My suggestion is to drive it as it is for a while and get the feel of the truck and peruse the threads on tis site and figure out what you want from the truck. Your truck will only be original once.
One last thing, please post more pictures of your truck as we all love pictures.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 03-05-2014, 02:41 PM   #16
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Keeping my 307 in my 70 K10. I'll run it until it goes. No need for me to change it out. I guess you need to look at your wants/needs and then decide.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 03-05-2014, 02:42 PM   #17
kentucky_smith
Someone went to some trouble to remove the 307 sticker under the hood and the SPID on my truck, PO thought it was a 350. Someone before him put hooker headers and a 650 Holley on it. Runs great, sounds good and gets better than 15 mpg. I'm more than happy with it.
kentucky_smith is offline   Reply With Quote
Old 03-05-2014, 03:21 PM   #18
KEL
72 GMC
KEL's Avatar
From the pic up top, it looks like you have a very nice truck that you just check the oil and then drive. Why do you want to make issues when it is so much easier to just sit back and enjoy the ride. Just my approach to it all. Have fun with it.
KEL
Members I have met :
2014.02.01: bruceman1968, Mr Handy, colgad, RenoKeene, CaptRMW
KEL is offline   Reply With Quote
Old 03-05-2014, 03:42 PM   #19
Fatherof3
Fatherof3's Avatar
I have one that I have only driven the 23 miles home from purchasing the truck. I'm going to do a compression test and if it's good will run it and spend my time and money else where on the truck. I'm looking forward to some non towing road trips with truck so the smaller displacement is a plus.
65 C20 292 4spd 4:56 Eaton HO52
Fatherof3 is offline   Reply With Quote
Old 03-05-2014, 04:22 PM   #20
EdB
My 70 came with the same set-up. I drove it to a little over 160K. It did not smoke
much but the compression got weak and it would creep down an incline if the
parking brake was not set. It was a 2bbl and the mileage was around 10 to 11.
I mounted a stock quadrajet manifold with a Holly 450 econocarb and it was a
great set-up for that engine. The mileage went to around 14 and it had more power.
I bought the truck second hand and it already had headers. It is on its fourth engine
now (350) and still has the original Saginaw 3 speed on the column. Everything
has been rebuilt or changed out at least once except for that 3 speed. I have never
had to work on it and it is still going strong.
EdB
EdB is offline   Reply With Quote
Old 03-05-2014, 05:05 PM   #21
Sloan66
I have the original 91k mile 307 in my truck. Drive it daily, get 13.5 mpg. Love it would not change it!
Sloan66 is offline   Reply With Quote
Old 03-05-2014, 06:24 PM   #22
54blackhornet
54blackhornet's Avatar
Speaking of 307's, I have one in a 71 C/20 that is all original. It's a low mileage truck I picked up, just to haul firewood once a year. The engine starts up fine each spring after sitting under a tarp with a couple of feet of snow on it, because I only run non ethanol gas in it. The problem is it has a bad miss ? Single exhaust pipe sounds like it is missing bad on at least one cylinder ? The truck is perfect for what I need to haul wood, posi 456 rearend, overload springs and disk brakes but the engine needs work ! I was thinking of trying a set of rebuilt heads ? But then I no nothing about the cam or timing gear ? Should I just scrap it and go with a 350?
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 03-05-2014, 08:53 PM   #23
C10 - C90 Bill
C10 - C90 Bill's Avatar
Still driving my all original '72 C-10 Longbed with a 307, 3-Speed. It now has about 163,000 miles on it. I bought it at 95,000 miles back in 2000. The only "major" thing I ever changed on it was the Timing Gear and Chain. Changed it around 120,000 miles for preventive maintenence measures only. Still runs great.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 03-06-2014, 02:58 AM   #24
RManson
I will tell you that bolting on a decent 4bbl carb and manifold, upgrading the ignition to electronic and replacing the 3-speed with a T5 will transform that 307 into a totally different beast.
RManson is offline   Reply With Quote
Old 03-06-2014, 11:29 AM   #25
Already Gone
Hi Ryan, that sounds like your ideas would make a great upgrade feature for Custom Classic Trucks Magazine especially if you did before and after specs on a dyno.
