Back from the Dead
Custom Center Console...What to put in it?
I just got done building a custom center console for my 72' to go between a set of Honda Bucket seats and I'm trying to firure out what to mount in it before I begin carpeting it. I already want mount my Airbag Switches in it...but what else? Maybe a set of cup holders, Ratchet Shifter? Any ideas or where to get cup holders at for cheap?
Any suggestions would be great, I'll post pics when its done. Kenny
The only Carb that matters to me is the one under my hood! Salem, Oregon |
Out of the carpool lane.
Kenny, someone on here used pencil holders for cupholders. I think they got them from Target, but I looked once and didn't find them. I've got a picture somewhere, but it'll be several days before I'm back at my own computer.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
go cyclones
You can have a flower holder like on a VW bug. Someone on this board put some speakers in the bottom
![]() Join Date: May 2002
Try an RV supplier for cup holders----------
Stepsides look like real trucks! Smitty ![]() |
Brad
I believe you are thinking of Boardrider52's Jimmy. Here is a pic of it with the factory console
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
and here it is after he built a custom one with the pencil cup holders.
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Mandrin also built his with pencil cup holder's..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
PROJECT 7DEUCE
What did these guy's do for the lower heater vent? I just noticed they don't appear to have any vent's in them?
Self-proclaimed LED man
It might look good to take two a/c balls and a center vent unit out of an a/c truck. Figure out some way to mount the center vent housing onto the bottom of the heater outlet, and run some duct work to the a/c balls. Mount the a/c balls on the sides of your console. I thought about doing this, but i have an a/c truck so ill just run the air through the a/c outlets all the time, and i wont have to worry about that.
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once ![]() Norwood Survivor |
How about a CD player in a hidden compartment with a lid? I ve always wanted to do this but i'd like to keep my bench seat. Another thing- you could find a small 6 can cooler and put it in there to keep your beverage of choice cool.
Hello everyone, new guy here. This is off of the subject, but do you know where to get the seat covers that are in the pictures Dubie posted? I could use them on my blazer. Any body have front pictures of them?
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel Charleston, South Carolina |
GM ONLY BABY!!!
I built a custom console for my 66 Chevelle about 10 years ago and I put 3 guages in the top then a cd player below it. Then I took a pop (beer) can and traced a circle on the wood then cut them out. I am also building 1 for my 72 which I will do the same and put speakers in the side of it as well.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
PROJECT 7DEUCE
Those seat cover's look like wet oklie's
#14 | |
SKINNY TIRES RULE!
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
#15 |
I put some cup holders in mine. Got them from a conversion van company. Also included in mine is an amp, 10" sub, and rachet shifter. I originally was going to put a tranny temp guage on the flat panel below the a/c controls, but haven't yet. I've also thougth about putting a 10 disc changer there or a bling bling LCD screen
#16 |
PROJECT 7DEUCE
Ackattack do you have a bigger pic???? And what did you do about the lower heat vent???
#17 |
i want to build one of these! they look great imo! i want a ratchet shifter or one that goes thru the floor sincei already have a hole in the floor. for the lower heater vent i would run ducting to the sides of the console from the vent. maybe when i get buckets i can put some in!
70 longbed 496/th400/Ford 9" |
#18 |
Could you make a console out of sheet metal and maybe some small round or square tubing to brace it? I want one that will run from the lip right below the rear window to the bottom of the dash with a big curve in it.
1967 Chevy truck, R1 racing seats, 4 point racing harness, 4/6 drop, primered blue, soon to be shaved, 350- 060. over, flat top pistons, Eagle rods, Edelbrock Aluminum heads, 1.5 Scorpion roller rockers, Lunati 515" cam, mallory ignition, Holley 750 double pumper carb, Built 350 turbo trans, 2500-2800 boss hog stall, 20 gallon aluminum fuel cell!!! |
#19 |
SKINNY TIRES RULE!
Found this console on e-bay. (http://cgi.ebay.com/ebaymotors/ws/eB...tem=2451535077). It would be great, especially for a Blazer or Burb.
#20 |
cupholders
Don't laugh because it has worked quite well. I built mine using black plastic flower pots from Home Depot. I wanted bigger cup holders that would hold a larger drink. I put a support below them and they flush mount with the top. Works great and you can't tell that they are flow pots.
Tom |
#21 |
Back from the Dead
I actually finished my console up the other nite, yet to get pictures though. I ended up mounting some rocker switches for my bags' and found a couple pencil holders to use as cup-holders at th elocal Office-Max store. The carpet was from Walmart. Cost me about $20 to amke (crarpet, switches cup-holders) I used wood from around the house. I'll post some pics when I get the chance but I don't feel like goin out in the 20 degree weather we're having
#22 |
What type of fabrication did you have to do to put in the honda seats? Are those the best seats to use?
Glenn Cumming, Ga (68 C/10 Fleetside LWB 307 (64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty) (2001 Porsche Boxster S - 168 MPH of fun) (2005 Chevy Avalanche Z71 1500) |
#23 |
#24 |
Swevin Irvins over in the 73 up section. Nice job on this.
http://www.73-87.com/7387garage/interior/console.htm
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
#25 |
I didn't do anything with the floor vent yet. I thought about cuting holes in the lower part of it and putting some sort of defuser on it, but haven't gotten to it. It doesn't seal up against the heater box anyways, so the hot air escapes from where ever. My truck isn't my daily driver so being cold for awhile isn't a big concern for me. Oh, I don't have a picture of it, but the console also covers the gas tank. Pretty cool I think. Kinda looks like the "waterfall" out of a C5 corvette convertable. |
