View Poll Results: What exhaust do you think?
Duel 7 31.82%
Crossover 6 27.27%
H Pipe 11 50.00%
Y Pipe 0 0%
Multiple Choice Poll. Voters: 22. You may not vote on this poll
Old 03-25-2014, 10:44 AM   #1
mattcrp1
mattcrp1's Avatar
Exhaust, duels, crossover, H pipe, or Y pipe?
Hi all, I am starting to look into exhaust for my 76 4.8l swap. What are people running? Are there advantages to running one set up over another? I am not anticipating any thing but a daily driver with this set up, cost is a factor and if possible I would like to do it the system myself with a universal type kit.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 03-25-2014, 11:37 AM   #2
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Re: Exhaust, duels, crossover, H pipe, or Y pipe?
I'm running an H-Pipe currently and think it's great. Sounds good idling, WOT or regular driving.
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 03-25-2014, 03:54 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Dual (not duel, thats fighting people at dawn with muzzle loading pistols) should probably be changed to True Dual.
The h-pipe (x-pipe would be the third option), is on a dual system. True dual is individual pipes from the manifolds back. I run true dual, which is probably the less popular as its a bit noisier and doesn't scavenge.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-25-2014, 04:03 PM   #4
mattcrp1
mattcrp1's Avatar
Darn spell checker came up on dual. Maybe I should be a little more specific:
1. True dual exhaust, no cross over or H pipe, balance pipe, etc..
2. Crossover or X-pipe
3. H pipe, like on a late 80's mustang.
4. Y pipe, similar to stock.
IG mattcrp1
Old 03-25-2014, 04:49 PM   #5
Jmiller022
Jmiller022's Avatar
true duals in 2.25" with either a H or X pipe. Im running an H pipe because its easier to fab in.
don't go too big on your piping. Bigger is not better, atleast in this case
68' c10 stepper 5.3/4L60e
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578917
Jmiller022 is offline   Reply With Quote
Old 03-25-2014, 05:53 PM   #6
crazy longhorn
Fabricate till you "puke"
Mine is true dual/H pipe, complete system out the back. I am running 2 1/2" pipe (it was already on the truck before the LS swap)....longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-25-2014, 05:57 PM   #7
JNJchev77
Registered Cruiser
JNJchev77's Avatar
I should clarify, mine is this as well, true dual with H-Pipe
77' Chevy SB
5.3/4l60e combo
Old 03-25-2014, 07:02 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Yall are gonna make me eat a bullet.
TRUE DUALS MEANS NO X-PIPE, H-PIPE, OR ANY FORM OF CROSSOVER. TRUE DUALS MEANS SINGLE PIPES FROM HEADERS BACK, WITH NO FORM OF SCAVENGING!
Duals is any 2-pipe system that uses a merge, collector, h-pipe etc etc etc.
True duals are like you would find on a motorcycle, or my truck. Individual pipes only!
I don't mean to yell, but after my initial post regarding clearing this up, 5 more pop up with the usage.
Are we clear, better yet, are we CRYSTAL?
Old 03-25-2014, 07:12 PM   #9
mooseknuckles
mooseknuckles's Avatar
Im runnin true dual, x-pipe, cat back with quad tips.....lol.
mooseknuckles is offline   Reply With Quote
Old 03-25-2014, 08:06 PM   #10
71chevystep4x4
71chevystep4x4's Avatar
mines TRUE DUAL, even though I told the guy to put in a H pipe and he didn't, but I let it slide. Although it does bring up a question,,,,,,,,,,which is whenever I'm roaring down a step hill in a lower gear, or under any heavy deceleration, it will pop a time or two, and I was wandering if that had anything to do with being TRUE DUAL??? It's not a huge backfire or anything, just a annoying pop that makes my awesome sounding truck look bad.
71chevystep4x4 is offline   Reply With Quote
Old 03-25-2014, 10:39 PM   #11
crazy longhorn
Some of the sound on decel, can be due to Muffler type/placement, & tail pipes (full length, or dumped?). As a rule, an H or X pipe will help with taming the exhaust note, both on acceleration & deceleration. Its a cleaner sound, & flows better , with the crossover! After I did the 1st H pipe....lets just say, I will NEVER run a "TRUE DUAL" again Longhorn
Old 03-25-2014, 10:56 PM   #12
crazy longhorn
Its not that big an issue? "TRUE DUALS", as you stated is what it is...but often "loosely used". Example..."no its not a cat back, its true duels"....but it may have an H or X in the system. Oops, I spelled that wrong....not that big an issue in my book? If I can read & make sense out of a post, even tho the spelling is not spot on....it does not rattle me? No issues, just my thoughts Longhorn
Old 03-25-2014, 11:00 PM   #13
ls1nova71
ls1nova71's Avatar
Ahh, Crystal Pepsi, I actually liked that stuff. However you're showing your age if you remember it.....
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-25-2014, 11:42 PM   #14
solidaxel
solidaxel's Avatar
............. O K, what do I have ?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-25-2014, 11:48 PM   #15
crazy longhorn
That be a dual exhaust, with crossover Nice shot btw Longhorn
Old 03-25-2014, 11:58 PM   #16
K10 STEPSIDE
K10 STEPSIDE's Avatar
Just my 2 bits.
I run a true dual now with side exits, and I would say a H or better jet an X pipe is very important with side exits, as you only get half the engine out each side it doesn't sound as good as both pointed in the same direction.
_______________________________________________
A project can be finished, but a car is never done.
1967 chevy K10 step
2002 chevy Impala
Latest Project http://67-72chevytrucks.com/vboard/s...d.php?t=605308
K10 STEPSIDE is offline   Reply With Quote
Old 03-26-2014, 12:57 AM   #17
JNJchev77
Registered Cruiser
JNJchev77's Avatar
This made me spit my Crystal Clear Pepsi all over the screen!
Didn't mean to heat you up BR3W,
77' Chevy SB
5.3/4l60e combo
Old 03-26-2014, 01:24 AM   #18
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Hehe, I'm a nazi for nomenclature.
Ok no one quote the first part of that out of context....
Anyway, I just get on people for it because its one of those "buzzwords" that gets thrown around out of context and leads to further misuse. As an example, there is a difference between manifolds, and headers tho the terms are used interchangeably. The use of "true" in terms of dual exhaust has no reason to be used, if in fact, it isn't actually a true dual.
I'm not upset with anyone, nor is it that big a deal...but since I have a platform, I'll run with it. FWIW, the reason it began to get misused is the prevalence of "dual exit" exhausts. They are NOT true dual, nor are they actually "dual" at all. Instead they are a single pipe exhaust with a y-pipe on the a$$-end, making two seperate exits. SRT4's, v6 mustangs and others are extremely guilty of this.
Old 03-26-2014, 02:19 AM   #19
crazy longhorn
No "quote"....don't worry about the spell check, or the "buzz words', spend your time sharing what you know on the gen III ? Hell, I am 57 yrs old, spent 40 yrs playing with the gen I small block! The gen III is new to me, but I still have time to listen & learn I thank you, & the rest of the guys for showing this old man a new way Longhorn
Old 03-26-2014, 07:39 AM   #20
DjS71
I heard there was a Crystal Pepsi flashback party?
I'll run 2.5" system with an X if its in the budget once i get the motor in, if not its true duals out just behind the rear tires. Not sure I'll ever tweak it enough to need 3", especially with the '10 Camaro manifolds.
1971 C10 Short/Fleet 307-2BBL/3OTT
1999 Silverado 2500 ECSB 6.0/4L80
DjS71 is offline   Reply With Quote
Old 03-26-2014, 08:49 AM   #21
solidaxel
solidaxel's Avatar
So I have Dual Exhaust, down in the So West, and in some parts of town, there were known to as "TwicePipes"
LS 3 4L70E
Old 03-26-2014, 09:30 AM   #22
mattcrp1
mattcrp1's Avatar
You guys are awesome, I love a good discussion. The H-pipe definitely seems to be leading the pack. Thanks for the pic solidaxel, that is what I am looking for. I wanted some opinions from those that had actually run the different types of exhaust systems on trucks with this swap.
I had totally forgotten about Crystal Pepsi, wasn't it in between the TAB and JOLT cola's at The Stop And Go?
IG mattcrp1
Old 03-26-2014, 09:40 AM   #23
solidaxel
solidaxel's Avatar
As far as the H pipe I dropped the truck at the Exhaust store and he asked me what type of muff. I wanted and I told him I wanted quite, as everything I have is "loud" he put on a set of Walkers and it is mellow and no drone.
This is what I got back, so I guess it will work!
LS 3 4L70E
Old 03-26-2014, 10:09 AM   #24
mattcrp1
mattcrp1's Avatar
I had a mustang 5.0l with flow masters a long time ago and I hated the drone. I want a nice sound with no DRONE. I don't know if I have ever heard walker mufflers before. Ill look into it. Thanks
IG mattcrp1
Old 03-26-2014, 10:30 AM   #25
solidaxel
solidaxel's Avatar
Walkers, I think are the "less expensive" ones !!
LS 3 4L70E
