Old 03-29-2014, 06:15 PM   #1
fredhlynch2
66 C10 Trailing Arms
Need some help with trailing arms for 66 C10. Bought the truck with a 77 C10 leaf spring rear end bolted on....needs to go. The frame mount for the trailing arms on my 66 are still there. My question is this.....is there any difference in length of trailing arms between long and short bed trucks? I have access to trailing arms from a 72 C10 long bed....will they fit?
Any help on this is much appreciated!
fredhlynch2 is offline   Reply With Quote
Old 03-29-2014, 06:44 PM   #2
B17CRX
B17CRX's Avatar
Re: 66 C10 Trailing Arms
Trailing arms are the same between long and short bed trucks. They are made from two channels riveted together and water can collect and rust them out from the center out so make sure to inspect them. I got a pair that looked great until I scraped off the undercoat and they were full of holes. HTH
-Joel
B17CRX is offline   Reply With Quote
Old 03-29-2014, 08:08 PM   #3
PGSigns
PGSigns's Avatar
You will need the trailing arms, springs, spring plates and a panhard bar along with a rear end setup for trailing arms. The 72 would be a good donor for all this if you can get it.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
