#1 | |
Re: New: Porterbuilt Inner Frame Structure
I was under the impression that a two piece drive shaft was needed to make this work without angles that are going to hit something. I would also like to be convinced that I want to replace to upper and lower tubular control arms. Would there be a huge inprovement in steering and cornering with a static 4/6- 5/7 that it would be worth it for me. Im on the fence of going tight suspension with motor build or air ride and mild build. We need to eventually talk because I spend a lot of time on AZperformance. Thank You Ulysses |
Ulysses,
Feel free to call anytime. They do have a 1-piece driveshaft version now. In regards to the arms, I think you would see an improvement in the performance. On static drops, we usually recommend going with a 1" forward lower, and a standard upper. This will put more caster into the front geometry, which will improve the steering feel and performance. - Travis |
Thank you, Travis!
There aren't very many pictures of this top notch product, I wanted to share a couple installed pictures. Anyone on the fence, you will not be disappointed. You literally can't go wrong with Porterbuilt products and Travis' customer service. Thanks again! ![]() ![]()
You remember when drinking too many beers was a bad idea? Me neither. |
Frame looks great! Thanks for sharing the pictures and good words.
![]() Join Date: Mar 2014
Do you have these available and are they still $995?
These are still available, but the $999 was an introductory price. They are $1,199 now. I did have one in stock, but am now out, but can definitely order one for you.
- Travis |
I’m running a full RideTech strongarm coilover setup. I want to use one of these stiffeners to help strengthen my frame cuz I’m running an LS3 stroker motor. Do u think the trailing arm mounts will work with the RideTech trailing arms?
Posted via Mobile Device |
