Old 04-08-2011, 01:07 PM   #1
70chevykidd
70chevykidd's Avatar
remove shift nob
can anyone tell me the best way to remove an auto shift nob in my 70 cst
70 c10 350 with headers, noisy gear drive, .450 lift cam and 4bbl carb w/TH400 hope to get a another Big Block in its lifetime
70chevykidd is offline   Reply With Quote
Old 04-08-2011, 05:11 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: remove shift nob
i have never had any success removing one without destroying it in the process
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 04-08-2011, 06:28 PM   #3
68gmsee
Active Member
68gmsee's Avatar
I tried to remove one long time ago and ruined it. Those suckers must be pressed into place while they're still warm from the mold. Either that or they glue them in place so they won't come off.
68gmsee is offline   Reply With Quote
Old 04-08-2011, 07:21 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
Take the handle off and put in boiling water for about 10 minutes then clamp the handle in a vise and quickly wrap a rag around the knob and pull it off.
Old 04-09-2014, 04:25 PM   #5
Beefy Norm
The knob itself isn't meant to come off. If you look down the shaft to where it mount to the column you will see a pin that needs to be punched out and that will allow you to replace the entire arm. Check LMC truck.com for a replacement part. I've had a lot of luck finding parts with them.
Beefy Norm is offline   Reply With Quote
