Old 04-20-2014, 09:56 PM   #1
Mayhem.Evol
First square. 1980 GMC
Hey guys, I finally got this project home this Saturday. Bought it a week ago, but couldn't get it back here. I'll include pics at the end of the text
I have a bunch of questions because i picked this thing up really cheap and know it needs alot of work. I have no mechanical experience or fabricating. I've wanted a 73-87 since I was 15 so I went for it. I know I'm jumping in way over my head but I want to learn every single thing I can..
So it's pretty rough, bed is rusted through and damaged on the side. I suppose I can try to find another bed to put on it. I haven't got to get completely through the cab yet to see what the deal is there. The hood is obviously bent, but closes somewhat. I'll find another for it if I can. There is some weird wiring done I think, and i'll have to try to sort that out.
My biggest questions is where do i start?? It doesn't run.. supposedly needs new head gaskets. I don't think the carb was functioning right, so I just pulled it off tonight, with tons of pics of everything how it goes. Going to try to find out a model on it for maybe a rebuild if possible... all I can see on it now is Rochester Quadrajet.. So ill clean a bit and see if there is anything else written on it. Hmm there is the numbers 17080206 on it, a quick google search brought me to some pics and rebuild kits.
Well here are the pics, just an Imgur album. I can upload them right onto this post if y'all would prefer.
http://imgur.com/a/f7hBv
Mayhem.Evol is offline   Reply With Quote
Old 04-20-2014, 10:02 PM   #2
Sodell
Sodell's Avatar
Re: First square. 1980 GMC
First order of business is to buy a repair manual... and get to know your local pick n pull, and craigslist...
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 04-20-2014, 10:06 PM   #3
Mayhem.Evol
Yeah i didn't even think about that even though I just got one for my dodge. From the vin, I'm pretty sure it came with a 305 and it has an older gm 350 in it right now.. or according to the valve covers and what the guy said haha.
Old 04-20-2014, 10:15 PM   #4
BADAZ chevy guy
BADAZ chevy guy's Avatar
Welcome to the forum! You'll find everything from A/C to Vacuum here and a lot of guys to ask questions from.
Does the VIN start CCL (350) or CCR (400)? I don't see an option for a 305 on my VIN spec sheet.
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline   Reply With Quote
Old 04-20-2014, 10:21 PM   #5
mrolds88
Check the block numbers, directly in front of ta passenger side head stamped on the block surface. That will tell you what it is Other than the hood, the body looks nice. One of the first things I would do that I noticed that needs to be undone is the fuel line. Truck came from the factory with steel line the whole way from pump to carb. I would put it back that way. As far as the head gaskets, check your compression before you do anything. Not terribly difficult.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 04-20-2014, 10:23 PM   #6
Mayhem.Evol
Thanks! I've browsed these forums for years and saw N2TRUX's truck a few months back at a show 5 miles from my house. He's helped me out alot with looking back when i was 15 and now again at 20.
My VIN starts w/ TCG I'm pretty sure(don't have it on me right now) and the decoder i looked at said T = GMC C = conventional cab and G = 5.0L 2bbl.. however I think it has a 350 in it? I haven't looked up how to really tell, it says 350 on the valve covers and thats what he said was in it.
Okay, I'll look up how to check the compression and try it out this week.. I'll also find out which lines you're talking about. I wasn't lying when I said I literally know nothing at all lol
Old 04-21-2014, 07:25 AM   #7
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
Welcome to the forums, from a fellow Texas guy, that does not live to far from you. The truck is a little rough around the edges, but that is how mine started to, to there is lots of hope for the old girl. Looks to me that the person before you bought a GM Target Master engine and did a swap, I would bet money that is not the original engine.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 04-21-2014, 10:36 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
nice score,looks solid
I'd lube up the hood,that can happen when the hinges seize up,
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 04-21-2014, 01:22 PM   #9
Mayhem.Evol
Yeah he said it wasn't and the vin says it came w/ a 305 not 350. and thanks for the welcome! Cool to see members somewhat close.
Also to anyone reading this, when you try to start the truck, you have to have it in reverse... how can I fix this? I have the carb off and whatnot right now but I'd like to know why I have to go from park to reverse to get it to even attempt to start and maybe fix it before putting the carb back on after cleaning/rebuilding(if I can haha).
Old 04-21-2014, 03:50 PM   #10
mrolds88
Here's the lines I'm talking about. As far as starting in reverse, your neutral safety switch needs adjusted. Its on the lower end of the column, on top.
93 K2500 xcab 6.5TD
Old 04-21-2014, 09:37 PM   #11
Mayhem.Evol
Ah thanks. I'll see what I can do about switching that line back to what it should be and adjusting the neutral safety switch if I can find it =p. Also have to find out what all the wires under the hood go to. I think the green one that is electrical taped into the battery and runs up the fire wall was for an amp/subs.
There are also random wires in the interior that I am not sure about.
I took the seat and carpet out today, not so pretty.. but I think it's not all horrible(if we forget about the floorboards)
Old 04-22-2014, 08:57 PM   #12
Mayhem.Evol
I pulled off the dash pad thingy today and it was filthy underneath it. I also pulled the paneling under the steering wheel to look at the wiring.. I have no clue what any of it is lol. Any ideas?
Sorry for bad pictures, they didn't look that blurry on my phone.
The first pic is the radio. I'd like to remove it, but I'm not sure how to go about doing that. Can i just remove all wires completely that are connected to it? without messing anything else up.
The 2nd pic is a clump of wires hanging down. I don't know how to deal with these.. the orange and blue ones were running to the back of the seat for speakers/subs I think.
Any suggestions? or can someone point me in the right way to getting that mess cleaned up.
Also, is there a way to check if gauges work w/o the truck being on? probably a stupid question
And one last thing this post.. Any suggestions on a good way to clean up the metal of the floor in the cab? its just dirty and greasy and has rat crap on it. Not sure on the best way to get that up.
Old 04-22-2014, 09:28 PM   #13
mrolds88
Looks like the radio is held in by the two nuts on the tuner shafts and there looks like there is a silver metal strap from the back of the radio to the lower dash. There should be a plug on the back of the radio. That should get your radio out. As far as the floor, I would wire brush and then use some POR 15 paint on it.
93 K2500 xcab 6.5TD
Old 04-22-2014, 09:48 PM   #14
thefraze_1020
thefraze_1020's Avatar
If you have any rust that you need to deal with. I highly recommend that you do what I did for my floor. Put a wire brush head on a drill and clean up the floor. Then vacuum the debris out. For the rust, I used a product called Conquest. Not sure where you'd find it around there, because I bought mine from a boatyard. Conquest is really expensive, but you shouldn't need much. Pour it into a pint bucket, yogurt container, etc. Mix it up and apply with a paintbrush to the rust. When it's converting the rust, it should turn the rust black. Allow at least a day for it to dry. Then you can prepare to paint the floor.
Cameron
1984 Chevy C20 Custom Deluxe
thefraze_1020 is offline   Reply With Quote
Old 04-22-2014, 09:51 PM   #15
thefraze_1020
Btw, I'm glad to see there's another young guy on here. I'm 21, and figuring my '84 out as I go as well.
Actually, from what I can tell, your floorboards don't look bad at all. Mine were rustier than that. And I have a golf ball sized rust hole just inside the driver's door on the vertical part of the hump the seat mounts to.
Cameron
Old 04-22-2014, 11:42 PM   #16
Mayhem.Evol
20 here, so just 1 year shy of you. I might try that out on the floorboard.. biggest problem though is the pictures don't really show that the floorboard has random pieces of sheet metal screwed on top of it. Which I'm kind of scared to take off because it's solid enough now and I can't move it to someone who could weld new stuff on until it's running.
I'm going to try to get it running and whatnot first, I'm just ripping the interior out right now because teardown/cleaning is somewhat free haha. I'm having to do it pretty slow for now because I spent a few grand on my 2010 dodge.
I think the wiring will be my biggest issue. There also seems to be trash all in the vent system which I'll try to clean out tomorrow, and maybe get some cleaning equipment.. brushes and whatnot later this week along w/ carb cleaner and rebuild kit.
I'll have plenty more questions for everyone by the end of the week.
Old 04-22-2014, 11:57 PM   #17
thefraze_1020
If you need seatbelts, I have the shoulder belts with the plastic retractor covers. There are in excellent condition, just need to be riveted back together. And the driver's side warning buzzer works if that matters to you.
I also have an AM radio that works pretty well. Anything else I can do to help, let me know.
Cameron
Old 04-23-2014, 12:11 AM   #18
Mayhem.Evol
I'll definitely have some questions for you I'm sure! I took the driver's side seat belt off. I'm going to replace them because they look pretty worn.. I just don't really trust them. The bolt into the floor of the cab on the passenger side seems to be stuck, I didn't mess with it today though. Not quite sure how to get it out. It does a lot of popping when you turn it and it takes alot more force to turn than the driver's side did.
Watching videos on headgasket replacements right now just to see what I'm in for.
Old 04-23-2014, 12:17 AM   #19
thefraze_1020
I experienced the same thing when I removed the seatbelts out of the 1972 I parted out.
Spray it with lots of penetrating oil. Tighten it back up, then out again. That way you can work it out without damaging the threads.
Cameron
Old 04-23-2014, 12:44 AM   #20
Mayhem.Evol
Sounds like a pretty good idea, I'll have to try that out.
Happen to have any suggestions as to where I should get a rebuild kit for the quadrajet I took off of it?
I've looked up a few threads on here, just wondering if you had any experience w/ them.
Old 04-23-2014, 12:56 AM   #21
thefraze_1020
I have yet to rebuild my Q-jet, but when my dad rebuilt the carb on our International Scout, he went to Mike's Carburetor Parts for the rebuild kit.
He's located between Seattle and Portland. His kits aren't the cheapest, but the service is unbeatable, and there are videos and demos on the website.
If all you care about is price, NAPA should have the kit you need. First, I suggest you get the numbers off your carb, and look them up on Mike's to identify the kit you need.
Here's the website: http://www.carburetor-parts.com/
Cameron
Old 04-23-2014, 12:59 AM   #22
thefraze_1020
Do you have the number on your carb handy?
Cameron
Old 04-23-2014, 01:08 AM   #23
thefraze_1020
Never mind, I saw the numbers on your first post. I'm not 100% (hopefully someone can confirm this), but I believe this is the kit you need:
http://www.carburetor-parts.com/Roch...Kit_p_742.html
Cameron
Old 04-23-2014, 07:10 PM   #24
Sodell
Sodell's Avatar
[QUOTE=Mayhem.Evol;6641627]
Those all look like speaker/stereo wires. I would take the stereo out, it should have a plug behind it with the wires...
Scott
Old 04-23-2014, 08:02 PM   #25
Mayhem.Evol
Thanks! I'll check that out tonight
When I wire brush the floor, should I use some sort of chemical with it to help or just straight brush to metal?
ah I'll see what I can do about it then. I wasn't sure if they'd run right to the radio or what and didn't wanna start pulling haha
