04-29-2014, 12:36 PM | #1 |
Where to buy pulleys?
I have misplaced the engine pulleys that came off my truck and I really don't know what I need.. 72 model truck newer block.. Dipstick on passenger side.. Has power steering and aftermarket air.. Any help would be appreciated..
04-29-2014, 08:08 PM | #2 |
Re: Where to buy pulleys?
Bump
04-29-2014, 08:13 PM | #3 |
Knuckle Buster, Instructor
Pulleys are usually determined by the water pump (short or long)
Current classic fleet: 72 K5 Blazer CST, unrestored factory Orange paint...mostly 69 C10 factory SWB, 454, TH400, Saddle tan, Rust-o-ration 53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue |
04-29-2014, 08:18 PM | #4 |
Cheapest place would be a wrecking yard but Summit and Jegs sell billet and anodized aluminum ones but they can be pricey You could also go to a dealer, you should have the long water pump so they would be easy to find.
69 Chevy 4x4 383 Power |
04-29-2014, 08:21 PM | #5 |
Alan Grove Components is where I got mine.
04-29-2014, 08:28 PM | #6 |
Moderator
Junkyard, Craigslist, etc. As stated above they will be different depending on your water pump.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
04-29-2014, 09:30 PM | #7 |
Give us a picture of your pump so we can see if its a short or long pump
04-29-2014, 09:58 PM | #8 |
Are you looking for stock type pulleys or aftermarket? If stock type let's figure out what you have and where you need to be.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
04-30-2014, 08:25 AM | #9 |
I just want the stock pulleys..
04-30-2014, 08:26 AM | #10 |
Long pump.. Power steering
04-30-2014, 08:46 AM | #11 |
oh boy this can be fun. Took me three orders back and forth to get right. Your truck is a small block? Must be newer than 73 if it is a long water pump. you running a stock alternator set up? I bet you need a 3 pulley bottom and single top, but you could buy a 2 groove top also. I had to use a 3 pulley bottom, which comes in 2 pieces, and I had to shim the outer one a bit to line up to the power steering. post pics.
04-30-2014, 08:49 AM | #12 |
OK, these trucks came stock with short water pumps. That's OK. Did you ever have it all together and running? Do you have the power steering brackets, alternator brackets? What side of the motor is your alternator set up for?
04-30-2014, 08:49 AM | #13 |
You know as soon as you buy some you will find yours right! Happens to me all the time.
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
04-30-2014, 10:25 AM | #14 |
you chould check out the serpentine setup ups they are selling on the parts forum also
04-30-2014, 10:43 AM | #15 |
04-30-2014, 06:01 PM | #16 |
Watch out for your cornhole !
There's no shortage of pulley sets for long water pump applications. Every sad sack 305 and 350 from the mid 70s through the mid 80s used them. Cars, vans, trucks, Suburbans.... What I'm trying to say is, I can't imagine the need to buy new ones when there's so many out there in junkyards, Craigslist, etc.
04-30-2014, 08:48 PM | #17 |
x2. I kept blowing the single V-belt at higher rpm's so I switched to serpentine setup and long water pump from a 1986 Caprice. Never looked back.
1971 Bone Stock C10 project "Jake" 1997 Sierra SLT factory short bed "Silver Bullet" |
