Old 04-30-2014, 07:02 PM   #1
davepl
davepl's Avatar
The impossible air conditioning connection
So I'm hooking back up all of the AC during reassembly of my restoration, and I've run into something I just can't figure out.
On the line in the picture below there is no tubing nut. I've followed the line up and down and it's just not there. Yet I don't know how it would have ever come off, because the flare is still on the end of the pipe.
In the assembly manual it seems to show the pipe without a tube nut, but that's hardly authoritative.
Could someone with AC (ideally a big block, but probably doesn't matter) check theirs and see how it's connected?
Many thanks for any help! The second photo is just a quick snap of where I'm at. It's still all the original lines and so on (which hopefully do not leak) plus a lot of scuffing, polishing, scotchbrite, and so on.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 04-30-2014, 07:16 PM   #2
Andy4639
Old member
Andy4639's Avatar
Wink Re: The impossible air conditioning connection
Is that the line to the dryer? If so look under the dryer and see if it slipped all the way back to the front side of the radiator support when you installed it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-30-2014, 10:21 PM   #3
FirstOwner69
FirstOwner69's Avatar
Here it is in my 69 with a 350.
FirstOwner69 is offline   Reply With Quote
Old 05-01-2014, 08:00 PM   #4
davepl
davepl's Avatar
Thanks! Are those new lines? If so, do you know where you got them?
Andy - good thinking, and I did already check that. But last night I woke up in the middle of the night wondering if it got stuck inside the grommet - I'll check when I get there!
Old 05-01-2014, 08:48 PM   #5
FirstOwner69
They are new. I got them from Classic Industries. See promo code thread for latest 20% off sale. Here is a pic that shows all the lines.
EDIT: Added second pic at a slightly better angle.
Old 05-01-2014, 09:19 PM   #6
Andy4639
Old member
Andy4639's Avatar
Talking Re: The impossible air conditioning connection
A good AC shop should be able to get the hoses made for you. When I ordered the fittings for mine I had the local place make them up. He charged me $25.00 to do it.
Old 05-02-2014, 02:08 AM   #7
frank69
If u can't find one pm me I've got an xtra 1 I'd send u for a few bucks plus shipping
frank69 is offline   Reply With Quote
