01-05-2004, 02:57 AM | #1 |
Need help w/3spd columns....
My 3spd column shifter has given up the ghost. I got another column from a 70 model (thinking it was the same), yanked mine only to find the steering shaft on my 68 is uncoupled & the newer column is coupled/splined immediately after the linkage.
Basically, my column is 1 solid piece (except for where it's designed to collapse) to the steering box. The newer column consists of 2pcs. between the box & the linkage. I don't have the 2nd piece that would connect @ the column base near the linkage (this would be the 'male' part of the collapsable shaft/s). Anyone more familiar w/these column differences? My only guess is the 67-8's were closer design wise to the 64-6 models (as far as steering columns go).
01-05-2004, 09:01 AM | #2 |
Scoti, I have the other piece. Sorry about that I should have given it to you when you came over. I'll get with N2BILLET and get your number.
01-05-2004, 09:22 AM | #3 |
Thanks. I didn't realize they were different. The only columns I've personally swapped were 68 & earliers.
Scot
01-05-2004, 10:16 AM | #4 |
I PM'd you
Jeff |
