Old 05-10-2014, 10:08 PM   #1
Hiluxxulih
Hiluxxulih's Avatar
No adjustment hole for rear brakes
I have a 1985 Chevy 4x2 long bed truck and there is no hole in the backing plate to adjust the brakes how do I adjust them ? I know about the backing up thing but they should have a hole there to manually adjust them shouldn't they ?
Hiluxxulih is offline   Reply With Quote
Old 05-10-2014, 10:12 PM   #2
mrtoni
Re: No adjustment hole for rear brakes
you know, I just ran into this on my 67 camaro. The driver side had the access on the backing plate. The passenger had the access on the outside of the drum. Which I found by removing the wheel. This was new to me and made it interesting because that brake was froze up. I had to push the car to rotate the drum to 6 o'colock to get to the release.
Hope it helps. Matt
mrtoni is offline   Reply With Quote
Old 05-10-2014, 10:18 PM   #3
Hiluxxulih
Hiluxxulih's Avatar
I had the drum off a few weeks ago and there is no access hole in it either I am stumped .
Old 05-10-2014, 11:46 PM   #4
asphaltburner
asphaltburner's Avatar
Outside of the drum, huh?! And NO access on the '85 truck! Geeze, I've never heard of that in all my years!
My Camaro, and FRANKENTRUCK, both have the standard access on both sides, as do all my other vehicles.
Learn something new everyday,...
I'd guess Hiluxxulih will be doing a gross adjustment with the drums off and then utilizing the backup technique to complete the adjustment to the rears.
How strange,...
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 05-11-2014, 09:56 AM   #5
geezer#99
geezer#99's Avatar
I thought you was hallucinatin' till I looked at mine.
No holes on mine either!
But a little quality time with a drill and files and a new plug will fix that.
Old 05-11-2014, 09:58 AM   #6
Oldriginal86
Have seen this before. Clean the backing plate real good at the bottom where the slot would be located. There should be 2 scored areas, use a chisel and hammer to knock out the slot needed.
Oldriginal86 is offline   Reply With Quote
Old 05-12-2014, 08:12 AM   #7
Keith Seymore
Keith Seymore's Avatar
Correct. There should be a "knock out" that needs to be knocked out and plugged with a rubber plug.
There are two because the backing plates are common and that way the same part can be used for both sides.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-12-2014, 05:28 PM   #8
Hiluxxulih
Hiluxxulih's Avatar
This must be an oddball truck no knockouts to be found ., maybe Canadian trucks did not have them .
Old 05-12-2014, 06:42 PM   #9
geezer#99
geezer#99's Avatar
What makes you think your truck is from Canada?
Old 05-12-2014, 07:13 PM   #10
Hiluxxulih
Hiluxxulih's Avatar
The Vin says its made in Canada , I was just thinking the Canadian built trucks had different backing plates for some reason the drum even says made in Canada .
Old 05-12-2014, 07:29 PM   #11
geezer#99
geezer#99's Avatar
Could be, but maybe just certain optioned trucks where like that or just for a couple years.
My 84 is an Alabama truck built in Flint.
Old 05-12-2014, 07:47 PM   #12
Tom
driving is in my blood
Tom's Avatar
Shouldn't be too confusing as its extremely common. Niether of my current trucks has the hole nor did my previous 79. The 79 was american built, both my currents are canadian built. You adjust with the drum off, then put it on and check, then re-do if needed. Or drill the hole lol.
Old 05-12-2014, 08:15 PM   #13
Hiluxxulih
Hiluxxulih's Avatar
That's what I did I was just making an observation .
Old 05-12-2014, 08:48 PM   #14
54Caddy
GM Addicted
54Caddy's Avatar
my truck doesn't have them either, even searched for knock outs when I just did brakes none found. I always adjust them before I put drum on so there tight then do the reverse procedure
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is online now   Reply With Quote
Old 05-12-2014, 09:50 PM   #15
GM-power
GM-power's Avatar
I drilled my adjustment holes in my new drums...
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 05-12-2014, 11:15 PM   #16
bnoon
Same thing on my 76 Julius when I did the brakes last summer. The really odd part was there were adjustment slots on the TOP side like the backing plates were used from another application and just flipped hpside down. I couldn't back off the adjusters to remove the badly worn shoes and had to break the pins and pull the whole assembly off with springs flying. Was something like 4 hours to do the whole job including the stuck wheel cylinder lines.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 05-13-2014, 11:27 AM   #17
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
No adjuster access in the backing plate or drum face is not that uncommon in the industry. You need one of these shoe adjuster gauges where you flip it one way to gauge the drum then flip it around to adjust the shoe up to that dimension. This works great but if your drum has a wear lip on the edge you’ll never get them adjusted correctly. I use this tool even on vehicles with an adjuster screw access hole just to get the shoes adjusted up close to the drum then I do a few clicks of the start to run them a bit tighter. I find the tool usually gets you right on the money.
As mentioned above, most of the older 1/2 ton trucks without access in the backing plate have a knock out in the drum to punch out for adjusting however, if the truck has received a set of China's finest aftermarket brake drums in its life they probably do not have the knock out provision.
DirtyLarry is offline   Reply With Quote
Old 05-13-2014, 01:33 PM   #18
mrtoni
its a real bummer when you discover that the wheel is frozen due to rust and you need to release the brake to even get the drum off. then you discover no adjustment hole to release it.
got er done and home but decided to not invest any money in the old front drums and ordered power disc kit.
matt
Old 05-15-2014, 09:38 AM   #19
Desert1957
Desert1957's Avatar
Has anyone checked their drums to make sure the "knock Out" is there?
Desert
Desert1957 is offline   Reply With Quote
Old 11-25-2016, 11:37 AM   #20
ChevyC102007
ChevyC102007's Avatar
When I had a flat earlier this year I decided to check the drums on the rear of my '80 C-10. I looked on the back for an adjustment hole so I could back off the self adjuster, nothing.
I was beginning to think it was just my truck, until I read this thread, so now I know what to look for. Thankfully if there is a knock out in the drum itself it should still be there, looks to be the original drum.
Thanks again for all the info, save me alot of cussing trying to get the damn things off.
"When you were born, you cried and the world rejoiced.
Live your life so that when you die, the world cries and you rejoice."
[Cherokee saying]
2001 Dodge Ram Sport 1500 4x4. (old ride)
1987 GMC V1500 Sierra Classic ("new" ride)
ChevyC102007 is offline   Reply With Quote
Old 11-25-2016, 12:22 PM   #21
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
Are the two recessed rectangles I can see at the bottom of the backing plate not the knockouts? I've always seen oval ones, but it looks like there is something there????
Mike
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
Old 11-25-2016, 07:45 PM   #22
100%Chevy
My 78,C-10 had the adjustment holes in the drums.
When I got the new drums to put on it---No knockouts on them at all!
Had to make my own holes.
No knockouts in the backing plates either.
I don't understand the reason for this.Some have them and some don't?
Mike.
100%Chevy is offline   Reply With Quote
Old 11-26-2016, 12:47 PM   #23
Hiluxxulih
Hiluxxulih's Avatar
I was wondering if it is Canadian built truck only thing not having adjustment holes .
1985 Chevrolet Custom Deluxe
4x2 , 305 v8 , 700R4 transmission
Old 11-27-2016, 08:49 AM   #24
ChevyC102007
I think it has something to do with the brakes being automatically adjusted as you drive, but that dont make any sense though as most rear drums do that anyways if I remember correctly
[Cherokee saying]
Old 10-18-2018, 01:04 PM   #25
Savary
K
I have a '76 Chevy G-20 van, same deal. There is an indentation where the slot should be, but it doesn't look like a knock-out to me, looks like part one continuous piece of metal. These have never been touched. 33K original miles. Van sat in the guys back yard for 40 years with a bent axle.
Savary is offline   Reply With Quote
