Old 05-24-2014, 05:50 AM   #1
JointTech
JointTech's Avatar
rear end hanging from shocks
will it break the shocks? I have jack stands under the frame now and no wheels on so the rear end is hanging from the leaf springs. (just put it back in today).
The shocks wont fit unless I jack up the rearend a little. But if I release the jack the weight of the whole rear end is hanging from the shocks. is that a problem?
what happens when you lauch over a train track and get airborne? rear end would be hanging from the shocks at that point as well right
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 05-24-2014, 10:01 AM   #2
Lee H
Lee H's Avatar
Re: rear end hanging from shocks
The suspension will bottom out before the correct shocks are fully extended.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 05-24-2014, 10:10 AM   #3
TBONE1964
Cluster King
TBONE1964's Avatar
If that is a concern, you can use limiting straps like off road trucks use.
You can buy them in any length you need
http://www.quadratec.com/products/16...FagWMgodVDgAKQ
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 05-24-2014, 12:31 PM   #4
swamp rat
swamp rat's Avatar
"What happens when you lauch over a train track and get airborne?"
The shocks will top possibly damaging the internal valving, limiting straps may work but its a band-aid approach, finding proper length shocks would be better, they should extend about an inch further than the mounts when hanging by the springs and the body small enough to allow the shocks to compress to about 1/2" shorter than the shock mounts when fully compressed.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 05-24-2014, 02:55 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Seems like they should maybe extend a bit longer than that. Not so much what the measurement is when the axle assy is hanging free, but more like how long does the shock need to be when fully articulated. As in off-road, one side fully compressed & the other side fully extended. I'm thinking that might require a longer shock than just the hanging weight of the rear axle.
Not a good description but hopefully gets my point across. I understand we're probably talking about a 2WD truck, but some of us have been known to offroad with a 2WD. And it might ensure the shock is long enough for any circumstance.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 05-24-2014, 03:26 PM   #6
JointTech
JointTech's Avatar
so the answer is: no don't let it hang from the shocks while putting it back together in the shop? Im not going to be 4wheeling. Just a dumb joke at 3am.
72 C20 Long Bed
Old 05-24-2014, 04:07 PM   #7
Wrenchbender Ret
Cars & light trucks with coil springs have been hanging from the shocks for many years. It doesn't seem good but I have never seen it hurt the shocks.
Wrenchbender Ret is offline   Reply With Quote
