06-04-2014, 09:37 AM | #1 |
64-66 wiring harness in a 62
Has anyone tried converting a 64-6 wiring harness into their 62 or 63 truck. I have the most butchered up harness I have ever seen and have a box of good original 65 style to replace them with. I know the cluster will have to be altered but that's no big deal, figure I have nothing to lose.
06-04-2014, 09:40 AM | #2 |
Re: 64-66 wiring harness in a 62
Don't know personally, but I need a few of the accessory clips for the fuse box if you have any extras on an old fuse block. Both of the right side ones are missing on my fleetside.....I can get pics.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
06-04-2014, 12:14 PM | #3 |
LT1Burb--should work with a few mods. I added a new aftermarket fuse block to my org harness. post up some pics 1963c-10.
1961 chevy K10 my build is------------61K10 build |
06-04-2014, 01:37 PM | #4 |
Will do, thanks. Bad part is I had a spare fuse box for parts a few months back, sent it to a member to help out on his project and then picked up the other 63.
06-05-2014, 07:17 AM | #5 |
I just installed a new 14 circuit universal wiring harness/ fuse box in my truck, that was the best thing i could have done to my truck. i am going to do a frame off starting fall of 15' and will put a new painless wiring harness in at that point. But for $139, the universal harness is great. 2 full days to install but it sure is nice and neat.
06-05-2014, 08:33 AM | #6 |
you need the clips that are attached to the fuse box that hold the fuses? cuz i have a few extra fuses boxes
06-05-2014, 08:35 AM | #7 | |
06-05-2014, 08:39 AM | #8 | |
06-05-2014, 08:50 AM | #9 |
Yeah, its the clips on the right side. Got off late last night so wasn't able to get pics. I'll get some tonight.
06-05-2014, 08:50 AM | #10 |
Thanks Winston, let me pull this old harness out and I will snap some pictures of it, don't know if its save-able or not. What does the universal harness consist of Bullett.
06-05-2014, 03:30 PM | #11 |
is this the clip u need?
06-05-2014, 03:40 PM | #12 |
Yes and at least the one under it also. With out looking at it I don't think there were any others. I can't remember if the bottom one was there or not. I'm inclined to think all three on the right side were gone. I will have to go over my harness with a fine tooth comb.....PO just tapped in all over the place.....bet I removed 20 different wires. Have the truck down to factory wiring only right now.
06-05-2014, 03:43 PM | #13 |
hey LT1 this is the starter, coil,temp and oil sending unit i redid, correct terminal ends and heat sheild loom and correct colored wire and gauge, i follow'd the wiring diagram in the yellow book.
06-05-2014, 03:45 PM | #14 |
Nice job....looks great. Who did you order the loom from?
06-05-2014, 03:55 PM | #15 |
06-05-2014, 04:01 PM | #16 | |
06-05-2014, 04:08 PM | #17 |
all i need is the connector ends and whatever you got, i just untape it,trace all the wires with new correct stuff. crimp,heat shrink the repaired ends with butt connectors and retape it all
06-05-2014, 04:34 PM | #18 |
06-05-2014, 04:39 PM | #19 |
just send me whatchu got and i'll take it from there. i start with this little gem
06-05-2014, 04:46 PM | #20 | |
06-05-2014, 08:32 PM | #21 |
its the lower 3 outside pieces. the 2nd from the bottom has both pieces for the fuse, so it looks like all the lower 3 auxilliary ports are gone. i can get a pic up tomorrow...haven't masteres doing that off the phone yet.
06-05-2014, 11:20 PM | #22 |
ok once i see the pic i will send it out, and i wont change ya.. just PM ur info
06-06-2014, 09:02 AM | #23 |
Here you go pimpston65. Auxilliary ports on the lower three right side
06-06-2014, 03:12 PM | #24 |
The looming in post 13 is asphalt covered cloth loom available in several sizes at napa.
http://67-72chevytrucks.com/vboard/s...d.php?t=620707 |
06-11-2014, 08:44 AM | #25 |
is this what you need?
