![]() Join Date: Sep 2007
removing emissions
I have an 84 blazer all stock. 4wd, 305 4 barrell carb. 700r4 tranny. Engine runs well for a 305 but i dont need the emissions on it. Does anyone have a rundown on what and how to remove the emissions and re-route vacuum and what all to plug up?
1967custom |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: removing emissions
in most states its illegal to remove emission controls from a vehicle
I believe you only have the EGR, AIR pump and the Cat tho
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Yup only those 3 and hardlines going to the exhsust manifolds. I am mainly wanting to know how to reroute the vacuum system
1967custom |
Getting Old; Going Broke
Just chase any existing lines back to where they start and cap them off with a plug. If it goes to a T or something, remove the T and put a straight connection in.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
Be carefull what you plug off!
If your tranny has a lockup convertor it's vacuum controlled. |
That would not be part of the emissions now would it.
It isnt, but a lot of people would remove every vacuum line they could, thinking they are only there for emissions reasons.
Remove all the delay pots and nonsense between the distributor vacuum advance and the carburetor, hook the vacuum advance line to manifold vacuum (not "timed" or "ported" vacuum), and then set the base timing to 14-16 degrees BTDC. You might be able to go as high as 18-20, but if you get knocking, back it off 2 degrees. That will be the point where you get the best horsepower and mileage.
Rich Weyand 1978 K10 RCSB DD. |
Good iformation. Now i have a weekend project. Should i plug the exhaust manifolds also?
1967custom |
