Old 06-13-2014, 03:17 PM   #1
Amr84ss
My 68 5.3/4l60E swap
I have been working on this for about three months. I am at the point were I hope to hear it run this weekend. I figured I would start a little thread about it. This is my first time to do an LS swap and it has been fun to do it.
The motor is a 5.3 that has been bored .30 over, custom cam, little bit of work on the heads, TBSS LT headers, car intake, return less fuel system, 3600 stall, and built trans. This should be a fun truck.
I have rebuilt the whole front suspension using poly bushings, new ball joints, new tie rods, new 1in lowering springs, and a sway bar. The truck already had a disk brake conversion on it. The rear suspension will be rebuilt after the truck is moving on its own power.
Here are some Pictures of my progress:
Before
Motors Out
Suspension apart
Frame Cleaned and painted
Suspension back together
Motor in it
Motor ready to start (almost)
Thanks for looking, cant wait to drive this thing.
Amr84ss is offline   Reply With Quote
Old 06-13-2014, 03:22 PM   #2
Bigdav160
Bigdav160's Avatar
Re: My 68 5.3/4l60 swap
Is the transmission an "e"? What engine management system are you going to use?
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 06-13-2014, 03:25 PM   #3
KMC3420
KMC3420's Avatar
Re: My 68 5.3/4l60E swap
Wow nice project, it looks like progress was fast, but 3 months is longer then 9 pictures does justice. Looks like a pretty straight truck as well.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is online now   Reply With Quote
Old 06-13-2014, 03:26 PM   #4
Amr84ss
Yes it is an E. I have edited that on my title. I am using a factory ECM and a PSI harness. I am running a DBC TB on it.
Old 06-13-2014, 03:44 PM   #5
Amr84ss
There has been a few delays on the progress. It has actually gone pretty quick when I have been able to work on it. Its been fun. The truck is pretty straight, we uncovered a few bad spots when it came apart.
Old 06-13-2014, 04:55 PM   #6
KMC3420
KMC3420's Avatar
No big deal on the bad spots, from the looks of it you can handle it. What oil pan are you running with it?
Keagan
Old 06-13-2014, 06:18 PM   #7
Amr84ss
I am running the H3 pan. I bough the muscle car pan kit.
Old 06-13-2014, 10:19 PM   #8
KMC3420
KMC3420's Avatar
That's my exact plan also. $194 or so on eBay.
Keagan
Old 06-14-2014, 04:17 PM   #9
Amr84ss
The pan fits great.i got a good deal on it sraight from GM.
Old 06-16-2014, 04:55 PM   #10
Amr84ss
Couple more pictures.
Fuel set up
My first time making AN hoses. It was not the easiest to do for the first few, but I got pretty good at it by the time I was done.
Old 06-17-2014, 11:16 AM   #11
littlevictories
yeah that's a fun learning curve. I had a couple leakers. not at the hose side but the flare side. keep an eye peeled for any drips. also make sure your tank is vented, that will exacerbate any potential leaks
littlevictories is offline   Reply With Quote
Old 06-17-2014, 02:57 PM   #12
Amr84ss
Yeah i have a small leak that I found last night when I went to start it for the first time. It is on the filter. I need to find it during the daylight and tighten it up.
Old 06-17-2014, 03:03 PM   #13
Amr84ss
It ALIVE!!! After not getting spark the first time I tried, i realized I had not hoked up the ground from the harness to the back of the head. Started right up after I hooked it up. I need to get another MAF sensor, mine set a code. It was awesome to hear it start for the first time.
Old 06-17-2014, 03:41 PM   #14
siggyfreud
siggyfreud's Avatar
Awesome man! Almost no better feeling than getting all the plumbing and wiring in place, and having it start up.
I remember my first fuel injection swap. I spent a week trying to get it started and couldn't figure it out. Turned out I was using an 85 computer with an 86' harness which had a different pinout. Swapped to an 86 computer and PRESTO, fired right up. Man that felt good.
Once you work out the MAF issue record a video and post it up!
siggyfreud is offline   Reply With Quote
Old 06-17-2014, 04:19 PM   #15
uxdesigner
Nice! Motor sounds strong, great work!
uxdesigner is offline   Reply With Quote
Old 06-18-2014, 10:42 AM   #16
Amr84ss
Power steering is hooked up. Used the lines off my my other motor, with a couple of modified bends. I took the big nut out of the back of my other pump and put it into this one. That way i didn't have to put different end on the hose.
Old 06-19-2014, 02:36 PM   #17
Amr84ss
Cool new use for this hole in the dash, Check Engine light.
Old 06-30-2014, 04:24 PM   #18
Amr84ss
Engine all cleaned up.
Old 06-30-2014, 04:45 PM   #19
Amr84ss
Little sound clip of motor with the exhaust made up. I hope this works from YouTube, this is my first shot at using it.
http://youtu.be/REtFgHY58oE
Old 06-30-2014, 05:50 PM   #20
claytonisbob
Lookin' good. For anyone looking for that muscle car pan kit, several people sell it for ~ $155. Part number 19212593.
claytonisbob is offline   Reply With Quote
Old 06-30-2014, 11:17 PM   #21
KMC3420
KMC3420's Avatar
Is the LH8 and muscle car pan the same?
Keagan
Old 06-30-2014, 11:34 PM   #22
Amr84ss
Yes it is the same pan. The kit comes with the pan, dip stick, windage tray, pick up tube ant all the bolts to install it. It is nice to get all the parts in one box, and it fits great.
Old 06-30-2014, 11:46 PM   #23
KMC3420
KMC3420's Avatar
Awesome. I was thinking they were 2 different pans. I can get one for 145. Thanks for the info.
Keagan
Old 07-01-2014, 08:09 AM   #24
powerline84
Greasemonkey
powerline84's Avatar
tell me about it man..it was my first time to and my fingers where hurting after doing a complete fuel system lol
1970 cst-10 longbed
speed
My Baby
http://67-72chevytrucks.com/vboard/s...=1#post3113923
powerline84 is offline   Reply With Quote
Old 07-01-2014, 08:12 AM   #25
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
A mallet works great for AN fittings. I made AN connections for my extra trans oil cooler.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
