Old 06-17-2014, 11:24 PM   #1
jrigheimer
jrigheimer's Avatar
ece disc brake conversion
im looking to do a drum to disc conversion, ece has come highly rated. I was wondering if the master cylinder would bolt right up to my current brake booster? im not very knowledgeable about this. doesn't seem stock, most likely installed by PO.
jrigheimer is offline   Reply With Quote
Old 06-17-2014, 11:31 PM   #2
michael bustamante
michael bustamante's Avatar
Re: ece disc brake conversion
Youll need to get a master cyl for disc/drum setup as well as a prop valve for the same. The booster looks like a 73+ full size truck( but i could be wrong) so maybe get a master cyl for something in that era
1967custom
michael bustamante is offline   Reply With Quote
Old 06-17-2014, 11:37 PM   #3
jrigheimer
jrigheimer's Avatar
It comes with this master cylinder in the kit and has prop valve as well, just wondering if it will bolt up without any problems
Old 06-18-2014, 12:29 AM   #4
michael bustamante
It looks like it will. The new prop valve will have diiferent size brake line inlets though. Youll have to replace those too. But thats not too bad.
1967custom
Old 06-18-2014, 12:32 AM   #5
jrigheimer
jrigheimer's Avatar
thank you
Old 06-18-2014, 07:46 AM   #6
Fitz
I installed that kit and the master bolts right up without any problems.
Fitz is offline   Reply With Quote
